DP7 first impressions
ssfm
GUI element sizes
Post by ssfm »
There was a lot of discussion about all the tiny interface elements in DP6, especially given all the empty white space within the windows. Is there any evidence that MOTU has responded to this issue and increased the size of the GUI elements in DP7?
tommymandel
Re: DP7 first impressions
Post by tommymandel »
David Polich wrote:Anyone running DP7 on a G5 under Tiger?
Inquiring minds want to know.
Not yet David, but I will be installing it on a DualCore 2.3 running Tiger with 3GB RAM as soon as mine arrives.
Believe it or not, I just found out about the upgrade - I'd been moving, etc.
So it may be a few days before that happens.
Re: GUI element sizes
Post by Shooshie »
ssfm wrote:There was a lot of discussion about all the tiny interface elements in DP6, especially given all the empty white space within the windows. Is there any evidence that MOTU has responded to this issue and increased the size of the GUI elements in DP7?
Those things are highly subjective and really don't matter. What matters is that it works beautifully, and it's already making my life easier, as it will yours or anyone else who uses it. I'm thankful to have it.
ssfm
Post by ssfm »
It absolutely matters when I need to work fast, and keep missing the interface elements because the target is so small!
ramadev
Post by ramadev »
I'll be installing DP7 on a G5 running Tiger on Tuesday when it arrives (according to UPS tracking).
Nehalem Dual QuadCore 3.2GHz/8GB/828/MTP AV/10.6.8/DP8.0-DP7.22/Altiverb6.3.5/ChannelStrip2.2.23/T-Racks/AutoTuneEvo/GuitarRig4/Drumagog/bx_XL/FG-X,RC-Tube,VTM/EventideOmnipressor/MelodyneStudio-Cre8 3.2
MacBook Pro Intel Core 2 Duo 2.66GHz/2GB/Traveler/10.6.8/DP8.0-DP7.22/Altiverb6.3.5/ChannelStrip2.2.23/T-Racks/AutoTuneEvo/bx_XL/MelodyneStudio-Cre8 3.2
Neumann,AKG,Earthworks,Soundelux mics/ManleyVoxBox/Avalon737/Amek9098/Genelec1031As
Post by Shooshie »
No need to worry. It works great. You may have a valid point, but there are so many ways around it that you should be able to get by until they see fit to make a change. It's hard to please so many people. It took me a few weeks or months to grow to like the GUI changes in DP6.x. Now I wouldn't have it any other way. A number of people modify the GUI. Perhaps if you try one of their modifications you'd find it easier.
FMiguelez
Post by FMiguelez »
ssfm wrote: It absolutely matters when I need to work fast, and keep missing the interface elements because the target is so small!
Option Command =
Option Command -
(with zoom on)
waterstrum
Post by waterstrum »
Did they fix the Toontracks 'drag and drop' MIDI issue?
All is well
waterstrum wrote:Did they fix the Toontracks 'drag and drop' MIDI issue?
Yes. Drag and drop in both EZ Drummer and Addictive Drums is okay here for me.
kgdrum
Post by kgdrum »
+1
waterstrum
Great news!
Thanks James.
All is well
poldo
Post by poldo »
MIDI Life Crisis wrote:OK, I'll ask again, and maybe more nicely. I'll even make a cake!!
Are there any changes to the notation page?
Are the chords and lyrics included?
Is the page able to handle more than a single line at a time and (oh please) wrap a track to view more?
(Note: not the Quickscribe page.)
no, no.... no changes there...
same old need update notation editor.
poldo
grouse
Post by grouse »
Can I ask a specific question to those who have 7? It may seem quite insignificant in the grand scheme of things but I use looping all the time.
So, in 7, does the audio drop when you change the global loop points or turn it on/ off.
They may have sorted that out in 6 as I'm still on 5.
Thanks.
DP 7.24, Focusrite 18i20, 3.06GHz Intel Core i3, OSX 10.9.5, 4 GB RAM, Reason 10, Kontakt, Motif +++
Post by Shooshie »
This tidbit might be encouraging if you had this problem in 6.02:
Apparently DP 6.02 had some inconsistencies in Auto Delay Compensation for certain VI's, namely VSL. IN other words, it didn't fix the delay for VSL (on my system, anyway).
DP7 -- it's all working correctly. All VI's are synchronized, including all my VSL instances.
twistedtom
Post by twistedtom »
Q; Are you using SL? Is it more stable? How is the CPU hit? From the site it looks as if the GUI is the same? Did you computer have any oddness after installing it? AND; are you happy you got it? What is the CPU hit on the guitar simulation stuff? With DP6.02 and SL I have been using a 64 buffer setting for line6 tracking and play through just fine. ( with a number of effects and VI's running) Will DP7 be even better?
I did not feel the need to jump on the bleeding edge and be crying but so far it looks good so if it is all good I am going to order DP7 in a few days. My birthday is soon I think my wife wants to get that for me. :wink:
