is blinking normal?
tangucho
is blinking normal?
Post by tangucho »
When I turn on the Ultralite MK3 just after all the system is loaded, a number 44 appears on the LED and starts to blink for a few seconds and then stops. is that normal?? do i have a voltage problem?
HLStudios
Re: is blinking normal?
Post by HLStudios »
i dont have that interface but im guessing the number 44 is referring to your sample rate...its problably locking itself to the current sample rate and when its done...it stops blinking?? something very simlar happens with 2408 mk3
PowerMac PPC G5 Dual Processor 2.0Ghz 4GB RAM 720GB HD OSX 10.5.7 (Leopard)
MOTU 424 PCI-X Card / MOTU 2408 MKIII / Focusrite Octopre / M-Audio Axiom 61 / TC Electronic Finalizer / M-Box
Digital Performer 6.02 / Pro Tools 8 / Peak Pro 5 / Reason 4 / BFD 1.5 / Addictive Drums / Antares Auto-tune /
Nomad Factory Analog Sign. Pack / PSP Audioware / Voxengo / Sonalksis / Celemony Melodyne / T-Racks 3
a pair of acoustic guitars and basses..lots of creativity!!
tomcrabb
Post by tomcrabb »
Yeah I get a blinking on the 896mk3 but each sample rate has its own light. I'm guessing because the Ultralight is more compact they need to use the screen to display more of the info.
iMac G5 :: MOTU 896mk3 :: Logic Pro 8 :: Pro Tools LE 7.4
tangucho
Post by tangucho »
HLStudios wrote:i dont have that interface but im guessing the number 44 is referring to your sample rate...its problably locking itself to the current sample rate and when its done...it stops blinking?? something very simlar happens with 2408 mk3
Yes, indeed it stops blinking when "its done". So I can relax about it?
tomcrabb
Post by tomcrabb »
Yep. If you want to test the theory change your sample rate and see if the number changes :)
