i have happily used this setup for about 3 years (give or take a year). about 10 months ago, i started to have an intermittent issue with the TDIF meters (A & B) on the 2408mk coming on (erratically) when there was no signal going in or out. in Sonar, those channels that are "freaking out" are totally pinned, making recording impossible on them.
i would reboot and start everything up again and it would usually be fine. (i'd say the freakage happened about 30% of the time, but always went away after a reboot/power cycle or two.)
as time goes on, the problem has gotten worse and worse. at this point, i have the issue 100% of the time. if i wait long enough after powering on, it will sometimes go away for a little while, but always comes back after a few minutes. i am now unable to record on any of the TDIF channels (thereby making live band recording impossible).
this phenomenon goes away immediately when i power off the DM24 (and comes back when i power it on). of course, i can't record when the DM24 is off (since i use it for the 16 XLR inputs and monitoring). so it's definitely related to the DM24 somehow...
i have tried swapping TDIF cables (and even ADAT even though that bank seems OK); swapping BNC cables (word clock); reseating the PC424; changing the sync settings so that the DM24 is the master; also tried making the 2408mk3 master; updated firmware on the DM24. nothing seems to help.
the thing that really puzzles me is how this issue just got steadily worse and worse rather than happening all of a sudden.
does anybody have any ideas? this is killing me.
