CD Burn not working
CD Burn not working
Hello,
On session tring to make references for the artist. Bounced all my tracks to stereo Core Audio AIF files (16bit 44.1), and then placed them back in the sequence to retain the markers for tracks. Bounce this to a CD file, try to burn and it finishes before even starting. ANyone? Thanks.
MacBook Pro FULL, 896HD, 828mkii, DP7... Just go to the web site and look at the pretty pictures ; )
- cloudsplitter
Re: CD Burn not working
Did you go to "edit>select all"(that will bounce all the tracks that have their "play enable" box checked) before bouncing to disc..?? this is especially important if you use a master fader track..(which I do on every sequence) if you are using a master fader track make sure it is turned up to unity gain before bouncing to disc as the bounce will record the level of the master fader setting, not the track setting.
Mac Pro 3,1 8 core 12 gigs ram Mavericks. DP-8.05 Fractal Audio Axe-FX Ultra, motu traveler, motu MIDI express, 2-24" LCD monitors, Yamaha HS80M,Yamaha NS10M's JBL28P monitors. Mackie control universal, BFD-2, Omnisphere,Trilian Ozone 4, Melodyne Studio/Editor, . Alesis Masterlink. Avalon 737sp. PCM 90. MikTek C4V. Korg Triton Extreme. Paul Reed Smith guitars, MPC-2500 there's more..but that's the heart of it.
Not the problem. I can import to itunes or quicktime and the original AIF bounced stereo file plays fine. There is something going wrong with the creation of the CDfile.
- Mr_Clifford
The first audio file has to be hard up against the absolute start of the sequence timeline, and you need to make a selection of all the audio soundbites/tracks you wish to include in the CD burn - in fact you need to select to just past the end of the last one or you'll get a burn error.draudio2u wrote:Not the problem. I can import to itunes or quicktime and the original AIF bounced stereo file plays fine. There is something going wrong with the creation of the CDfile.
- kassonica
This is correct (as always Mr clifford) users have reported adding between two and 6sec after the final wave file, seems to do the trick.Mr_Clifford wrote:The first audio file has to be hard up against the absolute start of the sequence timeline, and you need to make a selection of all the audio soundbites/tracks you wish to include in the CD burn - in fact you need to select to just past the end of the last one or you'll get a burn error.draudio2u wrote:Not the problem. I can import to itunes or quicktime and the original AIF bounced stereo file plays fine. There is something going wrong with the creation of the CDfile.
I don't use this function myself as I own toast but it would be handy as you can add the marker tracks.
If only it worked properly, I would.
I went thru this last night, I had more that 99 ids/tracks, I put a DVD instead of a CDR in the burner, I was at 96K.
Double check your sample rate, when importing back to DP, was it converted (back) to another sample rate?
Got that all fix up, the CD didn't capture the names of the tracks, got to figure that out.
http://www.spoonwood.net
http://www.davidgennaro.com
2.16 Intel Core 2 Duo, 10.4.11, 3gigs ram, Ultralite 2 (good Box),Bunch of FireWire Drives, guitars guitars guitars, plugins plugins , mostly use Kontakt3
- daniel.sneed
Inserting a marker at the end of the very last soundbite has solved the case here.kassonica wrote:This is correct (as always Mr clifford) users have reported adding between two and 6sec after the final wave file, seems to do the trick.
dAn Shakin' all over!
