Vanishing Audio MIDI Driver
EarlRShay
Post by EarlRShay »
I've been using a vintage Yamaha YS200 with DP 5.13 for several years now. The YS200 had been showing up in Audio MIDI Setup. In the least month, the YS200 has disappeared from the AMS. I checked that the Mac is receiving data from the YS200 with MIDI Monitor. I also ran a reset to see if AMS would recognize the AMS. No luck. I even attached the YS to an Ibook, and still could not bring the YS up on the AMS. Still no luck. I looked for YS200 drivers online and no luck. I also opened up archived docs that had been created using the YS. The YS selection is in italics. Could the list help? Many Thanks, Earl Using Mac Core Duo OS 10.4.11
IMac 2 GHZ Intel Core 2 Duo 4 GB Ram, EWQLSC, EWQLSO Silver, Play, Kontakt2, Finale 2007, DP 5.13
adriano
Re: Vanishing Audio MIDI Driver
Post by adriano »
Hi EarlRShay,
From my findings online and I might be wrong, there was never a Mac driver for the YS200.
It does have the same patch/synthesis as the TX81Z though and it should work fine with the YS200.
I'm guessing you are running through an Audio/MIDI interface and if so, open AMS/MIDI Devices, Add Device, Double-click the New Device, Manufacturer/Yamaha, Model/TX81Z and then make your connections.
Hope it helps
Just noticed, you're right up the street
iMac9,1, 3.06GHz Intel Core 2 Duo, 8GB-RAM, 10.9.5
DP 8.07, 828MKIII, Keys-Fantom X8, XV-88. Key
SampleTank v2.5.4, Miroslav Philharmonik v1.1.2, SampleMoog v1.02, SampleTron v1.02, Sonik Synth 2 v2.1.1, Independence Pro v3.2.0126, EZDrummer 1.4, MDrummer Large 5.02, Komplete U9, Orchestral Essential 1, Orchestral Essential 2, Complete Orchestral Collection
Music is the wine that fills the cup of silence.
