in this config, Its D/A like DA 16X necessary?
tobysan
Post by tobysan »
Hey friends, When you recording/tracking and mixing everything on a computer, intel, DP 6.02 etc..
do you really need a DA ?
im kind of confuse, i am clear about using a A/D but... D/A ? what's for ?
so what about this configuration ?
Apogee A/D 16X
Mini DAC
Symphony 64 PCIe Card
X-Symphony Option Card
Thank you guys, any help its going to have impact on my decision to buy some stuff.
Mac pro 8 Core 2.8GHz, 10G RAM, OSX 10.5.6, DP 6.02
PCI 424 e, 2408mk3, MTPAV,rosetta 800, BigBen WC
Latin Music production and songwriting..
www.myspace.com/tobysandoval
BradLyons
Re: in this config, Its D/A like DA 16X necessary?
Post by BradLyons »
You need the same quality D/A as the A/D to fully hear what you hear.
Thank you,
Brad Lyons
db AUDIO & VIDEO
-Systems Advisor, CTS
tobysan
Post by tobysan »
Thank you Brad,
BradLyons
Post by BradLyons »
ACtually, the gear you're asking about is EXACTLY the configuration I recommend for those that want a very high-end setup when using Apogee, but don't need a lot of outputs. For most project/pro studios that I'm putting in Apogee gear, I'll recommend the AD16X and the Rosetta800---why? This gives them 24-inputs with 8-outputs. Now while the Rosetta800 isn't exactly the AD16X/DA16X level, at that point it's not that much of an issue. If you go this direction, simply connect an Optical Cable out of the AD16X into the MiniDAC input---and use ADVANCED ROUTING MODE. The other advantage to the MiniDAC is that you have analog attenuation monitor control, which is very important in a DAW environment.
Thank you,
Brad Lyons
db AUDIO & VIDEO
tobysan
Post by tobysan »
Thank you Brad,
i just realize you are an audio consultant !
Yesterday I just bought the X-Symphony/ Symphony 64/ rosetta 800/BigBen... in a couple of months i going to upgrade adding a AD16X to my system as you recommend so i let you know.
i just connect everything and everything appears to be ok,i can see the PCI correctly installed on my computer, all the lights are ok on both the rosetta and Big Ben, i terminate the WC cable,
but i have only an annoying noise coming out my speakers so i realize i need some kind of attenuation control right ?
i have the " T.C level pilot" but still only noise its coming out...
i post a treat about this here
http://www.motunation.com/forum/viewtop ... =3&t=35004
if you have any idea, i really appreciated your help.
Thank you Brad.
BradLyons
Post by BradLyons »
Question---why did you buy the BigBen? Do you have multiple devices connected digitally?
As to annoying noise coming out, well I can't say that an attenuator would change this. What kind of noise is it? Is it just noise floor from everything being so loud?
Thank you,
Brad Lyons
db AUDIO & VIDEO
tobysan
Post by tobysan »
Thank you Brad.
The noise its coming gradually, when i start my system after all night let it rest,
i turn on the computer then both apogee, i start a song on i tunes and sound perfect but after 3 songs the sound start to degrading
it start with a little clips just like digital noises (like different Hz format on each device), then like an LP old record, then you can hear nothing but scratch noise.
I have WC because Also I have a digimax FS
but i was tried disconnect and work as INTERNAL WC... same happened.
