Dp 6.02: Movie Window crash
nadeama
Post by nadeama »
Hi,
I just tried doing a search on this and found nothing, but my apologies if this has been covered in one of the DP 6.02 threads and I missed it.
Just wondering if anyone could try this before I report it to MOTU as a bug:
*** It seems you have to use a dual display setup in order to reproduce this.
1- Create a new project
2- Open a Movie Window
3- Drag the Movie WIndow to your second display
Does anyone else get a DP crash when doing this? I can reproduce this 100% of the time, even after deleting all preferences. This wasn't happening in previous DP versions.
Thanks for your help!
Martin Nadeau
Mac Pro 8-core, Mac OS 10.5.6, DP 6.02, MIDI Express XT USB, MOTU 2408, MOTU 308
bdr
Re: Dp 6.02: Movie Window crash
Post by bdr »
Hi Martin
has been mentioned here before
http://www.motunation.com/forum/viewtop ... sh#p269468
scooter
Post by scooter »
That's weird because my QT movie always comes up on my 2nd display. I've never once had to drag it from my main monitor to the 2nd monitor. Lucky I guess.
scooter
Macbook Pro OS 10.12.6, 2.6 GHz Intel Core i7, 16 gig memory, Apollo Twin audio interface.
zaratero
Post by zaratero »
The thread linked by bdr solved that issue for me. It´s all got to do with video formats, and it´s explained very well.
http://www.cueaudio.org
Macpro 3.1 Octocore-16Gb RAM-OSX10.8 - DP 7.24
Macbook pro Core2Duo-4Gb RAM-OSX10.6 - DP 7.24
nadeama
Post by nadeama »
Thanks for the link to the other thread. I just tried converting a movie to DV format and I don't get the crash anymore. I guess I had always been using DV format in the past because I don't remember seeing this before.
Anyway, I'm happy now. Thanks again. :)
Martin Nadeau
Mr_Clifford
Post by Mr_Clifford »
nadeama wrote:Thanks for the link to the other thread. I just tried converting a movie to DV format and I don't get the crash anymore. I guess I had always been using DV format in the past because I don't remember seeing this before.
What codec were you using before? I generally use Motion J-Peg A and I don't have any problems viewing it on my second monitor.
jpiscitello
Post by jpiscitello »
I don't have that, but I do have this crash:
- Have a multi-sequence file.
- Choose a movie file for one sequence and set to "Same movie for all sequences".
- Switch to a different sequence.
- Now change the movie file (sometimes I do this like say I need to compress the movie a little for performance, or replace its audio track and I do it in a different saved-as move file).
- Switch back to the first sequence.
I've gotten a long beach ball followed by a crash in this scenario multiple times, both in 5.13 and 6.02.
This has happened even if I have saved the file and reopened it after switching the movie file.
The fix is to remove the "Same movie for all sequences" option, and close the movie, and *then* switch to the original sequence. Then re-add the movie, put it back on "Same movie for all..." and you are ok from there.
