6.02 defaulting to aiff files?
ks
Post by ks »
6.02 is defaulting to aiff files instead of sdII when starting a new project on my machine, even when audio file new project prefs are set to sdII. its fine once i manually change the format from aiff to sdII in the project once created (it stays in sdII after that) but having to manually set this each time i start a new project is less than ideal.
trying to figure out if anyone else is having this problem... start a new project and see what happens.
im on a ppc dual 2.0 running 10.5.6
thx
Dan Walsh
Re: 6.02 defaulting to aiff files?
Post by Dan Walsh »
I think you can set the default Audio formats in the DP Preferences...........
iMac 3.06 i3|OSX 10.6.8|8 gig ram||DP 7.24|Motu 896HD|2 Avalon VT 737's|Presonus ADL600|Slate VCC|Superior Drummer 2|EZ Drummer|1.1.6|Kontakt Player 4.1|Steven Slate Drums EX|SampleTank 2 XTAntares ATR-1|Presonus Central Station|Neumann TLM 103|Rode NT1|Audio Technica AT 4033 X2| Rode NT-5's|and lot's of other junk
ks
Post by ks »
exactly - thats what isnt working...
wurliuchi
Post by wurliuchi »
ks wrote:6.02 is defaulting to aiff files instead of sdII when starting a new project on my machine, even when audio file new project prefs are set to sdII. its fine once i manually change the format from aiff to sdII in the project once created (it stays in sdII after that) but having to manually set this each time i start a new project is less than ideal.
thx
I'm on intel, not PPC.
I'm not having that problem here. Mine are bwav, just as the new and current projects are set.
That's a weird problem. It must be a stuck preference file, though I don't know which one you should trash.
DP 6.03 • MacPro 2x3 Ghz Dual-Core Intel Xeon • 9 GB RAM • 10.5.7 • Prayers
Obvious qestion, KS:
Have you tried re-saving your "new file template/s" after altering the prefs and then quitting DP?
ks
Post by ks »
yeah, tried that. when opening a new project, the default files for "new project" are still sdII but the format for "this project" is aiff. doesnt seem to matter what i try, having to set file pref for every new project manually. strange.
nobody else having this problem, PPC especially? just want to make sure before i start in on the computer...
thx
slicerecords
Post by slicerecords »
I'm having the exact same problem. Once I change the Project format it sticks after a save---but all new projects just open up with AIFF, no matter what the overall default is set to. Definately a bug.... I can re-create it with 10 new templates I made.
PowerMac G5 Dual 2.5Ghz, 6GB RAM, 10.5.8, DP 7.11, 828mk3, Waves Platinum V7, Komplete 5, VSL Special Edition Plus Byndle, URS Everything Bundle...
slicerecords wrote:I'm having the exact same problem. Once I change the Project format it sticks after a save---but all new projects just open up with AIFF, no matter what the overall default is set to. Definately a bug.... I can re-create it with 10 new templates I made.
If you had it set to AIFF when you created the templates, and maybe you didn't, isn't that what you'd expect if you are creating new projects from templates? I.e., couldn't new projects from templates take on the forma tpref for existing projects?
I hear you, KS. Just wanted to make sure. Strange.
ks
Post by ks »
ok, so thats one other machine that this is happening on. this has felt like a bug from the second i noticed it (and had to change a bunch of aiffs to sdIIs) but i dont want to make a big deal out of it if its only happening to a couple of us.
some more of you might want to test it out; recording as aiffs isnt the end of the world but we all know dp likes the sdIIs and ill bet youd rather record in the format you prefer...
martian
Post by martian »
i wouldnt record in sd2 anymore these days.... wav is the way!
http://www.fork-media.com
My thinking exactly, KS.
Best we await further data; it's early days. The thread title should make it easy for folks to find and report in on this. It might be worth adding the words, "Please Report" to it though IMHO.
nadeama
Post by nadeama »
Just to let you know I'm having the same exact problem on an Intel machine.
Martin Nadeau
Mac Pro 8-core, Mac OS 10.5.6, DP 6.02, MIDI Express XT USB, MOTU 2408, MOTU 308
dinobass
Post by dinobass »
Same problem here with my Mac Pro 3.2 (10.5.6) and the AIFF default (I set the preferences in my template to WAV). Also, the MIDI outputs for my VIs in my templates are not showing up. Multiple MIDI outs for RMX and Omnisphere, for example, show up italicized and only as MIDI channel 1.
Mac Studio M2 Ultra 128G RAM OSX 14.3, 16" MacBook Pro M1 Max, UA Apollo x6, UA Apollo Twin, UAD-2 Satellite (x2)
slicerecords
surely a bug, and it makes sense because this is an area they changed slightly with the 6.02 update, must have missed something. I just have to remember to change my project default to BWAV when I start a new project.
