NEW (3.6.8.1360) usb/firewire drivers posted today !
majdid
Re: NEW (3.6.8.1360) usb/firewire drivers posted today !
Post by majdid »
windows xp Sp2, Firewire drivers "downgraded" as per RME suggestions to be able to avoid the 100 MBit microsoft limitation on the IEEE1934 bus.
wo1
Post by wo1 »
Wohoo !
There's no high pitched sounds and squeezing anymore. My Ultralite MK3 has been working perfectly with new drivers for a week. :D
comradec
Post by comradec »
wo1 wrote:There's no high pitched sounds and squeezing anymore. My Ultralite MK3 has been working perfectly with new drivers for a week. :D
I'm very pleased for you but it's difficult to glean anything significant from that fact without knowing which operating system you're using and what you did to solve the problem.
Ableton Live 7, Sampler, Session Drums; NI Kontakt 3; MusicLab RealGuitar 2, RealStrat; Sony Sound Forge 9.
Red Submarine desktop: Intel E6600 @ 2.4GHz, 4GB RAM; ATI Radeon X1050; MS Windows XP and Vista dual-boot; Phonic Helix Board 12 FireWire MkII; Alesis Fusion 6HD, ControlPad; Roland Fantom G6; Edirol PCR-500; Lexicon MX200; Samson C-com16, C-control, Resolv 50a.
Samsung R70 laptop: Intel T7100 @ 1.8GHz, 2GB RAM; NVIDIA NB8M-GS; MS Windows Vista; Edirol UA-1EX; Korg nanoKEY, nanoKONTROL.
reeper
Post by reeper »
same here :) 1360 drivers work.
runing xp64 btw.
nerd info:Cubase 4.5.2. Xp x64. Asus p5q-e. 8gb ram
dustplanks
Post by dustplanks »
i did the clean install, but i am still experiencing loud pops and squeals/interrupted audio.
in device manager - my "motu audio" driver version is 3.6.9.1323
i'm running xp 32 bit.
wo1
Post by wo1 »
I'm using only WinXP SP3. Vista is unsuitable for stable work with audio. And never will be.
What I've done ? Just followed these steps, as I've mentioned many times here before:
1. Turn off your system and disconnect the MOTU
2. Use Add/Remove programs to remove the MOTU driver
3. Restart your system and load the MOTU driver (make sure the MOTU is NOT connected for this process).
4. Restart the system once the MOTU driver has been loaded.
5. Shut down the system and connect the MOTU
6. Turn on the system (making sure the MOTU is currently off)
7. Once the system is back up/running, hit the power switch on the MOTU... and complete the driver install process (click Next)
And there's no problem. AT ALL.
comradec
Post by comradec »
wo1 wrote:I'm using only WinXP SP3. Vista is unsuitable for stable work with audio. And never will be. What I've done ? Just followed these steps, as I've mentioned many times here before: ... And there's no problem. AT ALL.
Excellent. I achieved exactly the same results using XP SP3.
As for Vista. You say it's "unsuitable for stable work with audio. And never will be." Well, after making various tweaks to optimise the operating system for audio, I've found that Vista works fine for audio ... except when using MOTU products. Most of the same tweaks are required to get the best out of XP too, by the way.
I would have tolerated the Ultalite-mk3 being suitable for sophisticated multi-tracking work in XP alone if it had at least been able to play back basic audio files in Windows Media Player when I booted to my Vista installation (I have a dual-boot system). But it couldn't even do that. It couldn't even play back a 320kbps MP3 file without audio drop-outs and high-pitched squeals several times a minute. So I couldn't do non-audio work in Vista while playing music in the background. I'd have needed to connect two separate audio interfaces to allow me do that, which is very disappointing for a supposedly professional audio interface.
Like it or not, we have to face the reality that Microsoft have taken XP off the market, except for a few limited cases such as netbooks and businesses. Therefore, most people buying a PC from now until the next OS comes along will have Vista pre-installed and they won't have had much choice about that.
MOTU advertise the Ultralite-mk3 as suitable for Vista. They therefore have to accept responsibility to making it work with that operating system. If that's too much for them, MOTU should specifically warn potential purchasers beforehand that their product is unsuitable for Vista users.
wo1
Post by wo1 »
comradec wrote:As for Vista. You say it's "unsuitable for stable work with audio. And never will be." Well, after making various tweaks to optimise the operating system for audio, I've found that Vista works fine for audio ... except when using MOTU products.
I don't want to make debates about XP / Vista. If you want to use Vista - use it :D
comradec wrote:Like it or not, we have to face the reality that Microsoft have taken XP off the market, except for a few limited cases such as netbooks and businesses. Therefore, most people buying a PC from now until the next OS comes along will have Vista pre-installed and they won't have had much choice about that.
And what's next ? Is it a problem for you that Microsoft discontinued XP ????!!! Is it a real problem for you in that case to make music using Windows XP ?
majdid
Post by majdid »
wo1 wrote:Wohoo !
can you please post your config? TI Chipset, OS, Service Pack, Driver Version, ...
comradec
Post by comradec »
wo1 wrote:And what's next ? Is it a problem for you that Microsoft discontinued XP ????!!! Is it a real problem for you in that case to make music using Windows XP ?
I'm not arguing about the pro's and cons of Vista, but about MOTU releasing a product they claim works with a specific operating system when it clearly does not.
As for the questions in your last paragraph, no, it isn't a major problem for me personally to make music using XP. But, as I explained, the Ultralite-mk3 won't even let me play back music in Vista. It isn't unreasonable to expect that I would be able to do that. Especially as MOTU promised that their product was capable of a great deal more than that.
But this isn't just about me. It's about MOTU advertising a product as capable of working with Vista when it isn't. And about them continuing to advertise that even though it is now quite apparent that the Ultralite-mk3, or at least its drivers, don't actually have that capability.
reeper
Post by reeper »
comradec
Post by comradec »
reeper wrote:this guy "comradec" is a crybaby- hes now on my ignore list
Music-making is supposed to be a pleasure, not a chore. So I took control of the problem and returned the Ultralite-mk3 to the shop.
So I'm outta here anyway now. Goodbye and good luck to all.
jguss
Post by jguss »
I am about to purchase a motu unit to work with my HP DV6000 running Vista Home 42bit version. I have just returned my Presonus firestudio to GC after the same degree of problems some of you are running into here. So can anyone tell me definitive whether it is possible for Motu interfaces to work with my setup or should I not even try? I suppose the other option is to go buy a Mac. Is that the best solution?
JGuss
VigilantSound
Post by VigilantSound »
Can some put up a link to this driver?
