AHHHH!!!
Trying to use my Frontiers Tranzport remote with DP6 on a Mac Pro 8 core and even after I drag the Tranzport bundle into the the control surface folder it still doesn't show up in the window when I need to select a driver. Anyone get a Tranzport to work with DP 6? ANy tips?
I'm guessing Frontiers is going to have to provide a DP6 driver update....
Help!!!
DP6 and Frontiers Tranzport
Mac Pro 3.2, 8 Core. Mac Book Pro 2.4 GHz Intel Core 2 Duo. Power Mac G5 Dual 2.0. (2) MOTU 2408 MK3's (BLA Mods) & 8 Pre. Motu Micro lite for MIDI (interface for Mac Pro) MOTU Ultralite MK3, Dp 7.2, Reason 4, Ethno 2, MX4, Symphonic Instrument, Mach 5 V2, Electric Keys, Ivory II Grand, Arturia CS-80V, Arturia Prophet V.2, PSP Vintage Warmer, Softube Trident A-Range EQ, IK Classik Reverb, Focusrite Liquid Mix, Peak LE
Affordable "E" Drum session work: gongbass@msn.com
Re: DP6 and Frontiers Tranzport
Works great for me. Make sure you put it in the correct folder. I don't remember if it's supposed to be ~ or /, but it does make a difference.
Also, you did install the drivers correct? And made sure the MIDI i/o is working?
thanks. i spoke to a really helpful guy (brian) at frontiers and he solved the problem. i had both drivers (the old and the new intel) in the control surface folder. once i took the older one out, all was great. thank god, i use this thing daily to do drum sessions. i couldn't deal with pre-rolls again!!!!
