HI
Is everyone can tell me how can i swich input levels from -10 to +4 db on motu 2408 mk 2.On motu site for 2408 mk3 write that inputs are software swichable between +4/-10 ,but on software for pci 324 I can't locate it
motu 2408 +4/-10
Re: motu 2408 +4/-10
if you open up the mkii you will see eight jumpers aligned with the analog outs. put the jumper over both pins to change the output to +4dB. repeat for each channel.
The jumpers change the reference level of the inputs, not the outputs. The outputs are fixed at +4dBu.supersetsounds wrote:if you open up the mkii you will see eight jumpers aligned with the analog outs. put the jumper over both pins to change the output to +4dB. repeat for each channel.
