After spending hours, and 2 frustrating phone calls with MOTU Tech Support, I finally have the FireWire and Firmware Updates Installed. What follows is the approach I took. Hopefully it helps those with similar struggles.
(FIRST) Disable all Virus Protection, and ANY other Audio interface you may have active. For me it was the Realtek driver that came standard.
(SECOND) Prepare for a direct connection to the 828MK3, in my case by FireWire. Do not yet attach any other peripherals such as a spare Hard Drive.
(STEP 1) Download the latest 32-bit Firewire and USB 2 Audio file from MOTU, dated on the website 6/30/2008 and identified as version 3.6.8.1; file: 32fw.zip. Unzip the file to a folder on your desktop
(STEP 2) Download the the MOTU 828mk3 v.1.06 Update. Unzip the file to a folder on your desktop
(STEP 3) Disconnect the MOTU 828MK3 from your PC and power it off
(STEP 4) From within Control Panel ---> Add/Remove Programs, remove the MOTU Audio Driver, identified as 'MOTU Firewire/USB2 Audio'. Go into the C:\WINDOWS --> System32 directory and delete the leftover MOTU file titled, 'mfwaasio'. Turn off the machine and restart.
(STEP 5) Be sure any Virus Protection; and any audio card on the PC is Disabled. Check by going into Device Manager from the System icon within Control Panel. Check your system tray to be sure all memory resident programs that you can disable, are disabled.
(STEP 6) From within the 32fw folder, run the 'Setup Audio' file. 6 installs will take place. Shut your PC down, then power back up
(STEP 7) AGAIN - Be sure any Virus Protection; and any audio card on the PC is Disabled. Check by going into Device Manager from the System icon within Control Panel. Check your system tray to be sure all memory resident programs that you can disable, are disabled
(STEP
(STEP 9) Start your PC. AGAIN - Be sure any Virus Protection; and any audio card on the PC is Disabled. Check by going into Device Manager from the System icon within Control Panel. Check your system tray to be sure all memory resident programs that you can disable, are disabled
(STEP 10) HOLD DOWN the PAGE button on the MOTU 828MK3 and Power it up. The Boot Loader message will appear and the 828MK3 will stay in this state. You can remove your finger from the PAGE button. Don't worry if Windows XP Hardware detector starts again, it will attempt to re-load the MOTU Audio driver. Say Yes at this step and allow the driver to load.
(STEP 11) From within the 828mk3_106ud folder go into the 828mk3v106 subfolder, then double-click on MOTU Fx Updater 32 to run the update program. You can click from within the program to run the v106 firmware update. [PLEASE NOTE: I found my system was terribly unstable after updating with the new firewire drivers, and before running the 1.06 firmware update. Therefore do not delay in following up quickly by running this firmware update right after the 3.6.8.1 Firewire/USB drivers are loaded. Turn off the PC, then power back up.
(STEP 12) At this point you can work through daising-chaining any other devices off your MOTU 828mk3. All-in-all the system should be stable. And you can reap the benefits of this update.
Best regards,
......Gary
