HotKeys for switching takes on mult. tracks?
I can't find a way to switch multiple tracks to different takes at the same time, unless they are record-enabled, in which case I have found the shortcut. If they are just play-enabled, the same shortcuts do not work. Any ideas?
Re: HotKeys for switching takes on mult. tracks?
I'm pretty sure they do need to be play enabled to be switched via key command.
you need to setup a group in order to do that. customize the group when you are setting it up and the include the new take, switch take in the group
