Hi everyone. I'm doing a project with a quick turnaround that has me doing the sound design, mix and mastering on an animated commercial. My mastering experience is pretty limited, and I want to make sure that the commercial is done to broadcast spec, the problem is that I can't seem to find out what that is. I'm thinking mainly of the frequency range/dynamic range aspects of it.
Any suggestions?
Thanks.
Jeff
(the spot is an animated bit with orchestral score, light sound fx, and a prominent VO)
Mastering audio for broadcast
2019 MacPro, 10.15.5, 16 core 3.2 GHz, 384 GB RAM
DP 10.11
Kontakt 6.2.2, Spectrasonics, u-he, Arturia, NI Komplete 11, VE Pro
UAD, Waves, Soundtoys, Slate, FabFilter
DP 10.11
Re: Mastering audio for broadcast
Nearly all broadcasters have different specs… so this isn't easy to answer.
Here in Germany I usually format the audio due to ARD/ZDF specs: -9dBFS maximum peak and a lineup tone of 1KHz@-18dBFS… this would usually not be rejected.
But you'll have to find out the specs according to the broadcaster.
Homeediting is killin proToolstitution…
- Radiogal
The Swedish national radio test tone translated to digital DAW metering is
TEST tone 1kHz -18 dB
Highest peaks -12 dB
- burn em
MTV in Sydney Australia accepts footage -10 peak for music videos/ live clips on Digi Beta. I still haven't been able to get a straight answer from anyone though as to the actual Illusive "specs" they "require". Jobs are accepted and well received, I don't ask any questions.
The guys who do my DV file to Digi Beta conversion put in tone and bars for me, so I have no idea of specs that.
Make sure your mix sounds good in mono and on small and crappy speakers and be careful with anything below 200/150Hz. Avoid multi band compression in mastering if you can help it.
Macbook Pro i7 17"-10.6.8 16Gb DP 7.24 ][ G5 dual 2 ghz pci, 4Gb-10.4.11 DP 7.12
Nomad Factory ][ Airwindows Gatelope (The best drums gate. buy it!) ][ Altiverb 6
MOTU 828 mkIII, 828 mkI x3, 8Pre ][ Apogee AD16, DA16 & Duet ][ MC Mix ][ API 3124+ ][ Toft ATB 24
