828mkIII instr in clipping w/guitar
Is anyone getting clipping when plugging a guitar into the instrument input? The pickups are pretty hot (dimarzio super d) but I'm still a bit surprised. Trim is all the way down and the pad (probably only for mic pre) doesn't seem to help. Turning on the v limit w/ look ahead solves the problem unless I dig in really hard. Is this normal with high output humbuckers?
Re: 828mkIII instr in clipping w/guitar
I have the same problem. All of my electric guitars and bass guitars clip the input with the trim to zero. The input is way too hot.
I hope they can change that with a firmware update.
Exactly the same. So far i'm pretty pissed with the mk III. I blew a speaker with it! its too hot and loud!
Computer/s: OSX 10.8.3
2 x 2.66 GHz Mac Pro Quad-Core Intel Xeon w/ 16GB RAM,
DAW:DP8.05
Hardware: Apogee Duet
VI's/Plug-ins:
Kontakt 5.1, EW PLAY Libraries and a
million others.
DAW:DP8.05
VI's/Plug-ins:
million others.
- jeff sanders
audio 101:hrw wrote:Exactly the same. So far i'm pretty pissed with the mk III. I blew a speaker with it! its too hot and loud!
dont plug anything in with the volume up.
dont turn anything up before you know how loud it will be.
voila!
there are toggles with input settings on the two front inputs on the 828mk3, set them correctly for best results.
the signal hits red when my friends use bass and guitar through them but the signal sounds clean when i record them. its not distorted or harsh like i would think from the red lights. could it be the meter is over sensitive?
good luck
have you all loaded the latest firmware and drivers?
I don't have this issue anymore, but I used to .
PowerMac G5 Dual 2.5Ghz, 6GB RAM, 10.5.8, DP 7.11, 828mk3, Waves Platinum V7, Komplete 5, VSL Special Edition Plus Byndle, URS Everything Bundle...
Yes, I have the latest firmware and drivers.
It's not just going into the red on my 828 but also the input in Logic 8.
Motu told me to reinstall the firmware but that just seems to be a standard routine answer. I haven't tried that yet.
Any suggestions?
Any suggestions?
