DP 2.7 won't install on G5 Dual 2GHz
FrankDSM
Post by FrankDSM »
DP 2.7 won't install on G5 Dual 2GHz. I want to upgrade to 4.5/4.6. I use 2.7 on an older Mac which I want to take out of service. When I try to run the 2.7 installer from the original DP disk, an error is generated which says it can't find the CD.
Any suggestions?
I'm concrned that, if I buy the upgrade ony, it won't work because 2.7 isn't installed.
Frank
Henry Robinett
Re: DP 2.7 won't install on G5 Dual 2GHz
Post by Henry Robinett »
I think 2.7 is OS9 only. I don't think it's gonna work. I think the upgrade path will handle that upgrade. As long as you have a registered copy, buy the new update and install.
All the best,
Henry Robinett
2019 Mac Pro 16 core, 192 GB; 2 MacPro 5,1 Metric Halo ULN-8 3d (x6), ULN-2-3d, MIDI Express XT,
DP10.13, UAD2 Quad TB,Duo,solo, Fractal Ax Fx III, FM3, LF+12+, Altiverb 7, Pianoteq7, Falcon, Keyscape, Omnisphere, Kontakt 5, Superior Drummer 3, Slate Drums, Live 10, Battery4, Diva, Spitfire Chamber and Symphony Strings, Ivory 2, Spectrafoo, Millennia HV3-D, many mics, many guitars . . ..
azusa749a
Post by azusa749a »
It will install fine, no need to worry.
Harry
Post by Harry »
Hey man, DP 2.7 is OS 9 only!!!
You need a full installation disk DP 4.5.
Trying to install DP 2.7 on a G5 is the same, like trying to install a Lawn mower engine on a Porsche!
You should read the operating instruction ;-)
OS 10.14.6, iMac i7.3,5 with 32 GB Ram, 828x, Miditimepiece AV, DP 10.00 (ger.)
MachFive 3, MSi, Ethno 1, Omnisphere 2, Sampletank 4, Forest Kingdom II, Desert Winds, EWQLSO-Silver, Real Guitar 2, VLP120, PLP120, VCP120, Liquid Saxophones, Elastic, The Resource, Wave Arts PowerSuite 4+5 and Master Restoration, Kontaktplayer, Absynth 5, Ni Action Strings etc.
azusa749a
Post by azusa749a »
Perhaps I wasn't clear.
I meant if you buy a DP upgrade, MOTU will send you the whole new DP4.5.2 or 4.6.
I just moved to OS X recently and DP 4.5.2 was an upgrade from 3.1.
Aramis
Post by Aramis »
Azuza , If you have the upgrade from 2.7 or 3.1 to 4.5 , you will be abble to load and instal 4.6 ....
Aramis
iMac 2012 27 ' 3.2 ghz 32 gigs ram OSX 10.9.4 DigitalPerformer 8.7 , MOTU Track 16, MOTU MachFive3.2, Ethno and BPM , Komplete 9, OmniSphere , Trilian and Stylus RMX , Axon mkII and Godin LG .
azusa749a
Post by azusa749a »
Thanks Aramis. I did that 2 days ago.
Now I'm having fun with the pitch automation and v-rack.
