DP 6.01 released!
bleach30
Re: DP 6.01 released!
Post by bleach30 »
Mach Five (version 1) still crashes DP6.01
carrythebanner
Post by carrythebanner »
bleach30 wrote:Mach Five (version 1) still crashes DP6.01
What version of M5 v1 are you using — 1.2.3? Check the version on the plug-in file itself, in /Library/Audio/Plug-ins/MAS.
willheim
Post by willheim »
I have a theme going that is in 6.0 so i opened it up in 6.01 and right away tried melodyne and a UA plugin, both of which worked.
Very encouraging.
mac pro 2.66 2010 8 core w 48 gig 1600 ddr, Mac OS 10.6.8, DP 7.21, the usual plugs and stuff.
wurliuchi
Post by wurliuchi »
Frodo wrote:
That is really wild! I got no PDF with my download. I just did a search for DP 6.01 and came up with zilch.
Also, I just checked my downloads again and still get this blurb:
There are currently no updates available for the version of Digital Performer registered to your MOTU.com login ID, or you do not have any Digital Performer registrations linked with your MOTU.com login ID...
I got the same thing when checking my downloads. You have to get it from this page: http://www.motu.com/download/download_m ... oad_id=150
DP 6.03 • MacPro 2x3 Ghz Dual-Core Intel Xeon • 9 GB RAM • 10.5.7 • Prayers
Dave Bourke
Post by Dave Bourke »
RecordingArts wrote:I'm having crashes with 6.01 that seems to be repeatable with Antares new Auto-Tune Evo. One project that had it inserted in a vocal channel crashes on launch and another file that opened fine crashed as soon as I inserted it...
Process: Digital Performer [194]
Path: /Applications/Digital Performer 6.01.app/Contents/MacOS/Digital Performer
Identifier: com.motu.DigitalPerformer
Version: 6.01 (6.01)
Code Type: PPC (Native)
Parent Process: launchd [159]
Date/Time: 2008-08-29 14:48:46.519 -0700
OS Version: Mac OS X 10.5.4 (9E17)
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread: 8
Thread 0:
0 libSystem.B.dylib 0x946734a8 semaphore_timedwait_trap + 8
1 com.motu.MAS.framework 0x017c2e94 MAS82879 + 120
2 DPPart2.dylib 0x0113fe3c WrappedMotuAudioSystem::Poll() + 44
3 com.motu.DigitalPerformer 0x00134c00 0x1000 + 1260544
4 PerfEngine.dylib 0x01ca8534 AudioRTPoll(bool) + 104
5 PerfEngine.dylib 0x01b9d358 MaybeRTPoll(bool) + 196
6 PerfFoundation.dylib 0x021caee4 CompoundPane::_Iterate(bool, long (*)(GlogPane*, void*, short), void*) + 236
7 PerfFoundation.dylib 0x021cb61c CompoundPane::Deactivate() + 44
8 PerfFoundation.dylib 0x021dd368 GlogPane::GlogMessage(short, long) +
It was Thread 8 that crashed, RA. You've pasted Thread 0 here.
Kind regards.
Dave Bourke
– ideation –
Mac Pro Quad Xeon 2.66 GHz, 5 Gb, OS X 10.5.8, iMac 24" 2.4 GHz Intel Core Duo, OS X 10.6.2, Mac G4 dual 800 MHz Quicksilver, DP 7.11, PCIe-424/24i, UAD-2 Quad/UAD-1e, PowerCore Firewire.
wurliuchi
Post by wurliuchi »
I don't think this release is meant to fix all -- or even very many -- of the problems people are experiencing. I think they had a list of things they didn't complete before releasing 6.0 and that's what we're seeing with 6.01, with maybe just a few bug or configuration fixes. I think the next release will have more bug fixes.
Well the UAD stuff seems to be working great.
Frodo
Post by Frodo »
wurliuchi wrote:I don't think this release is meant to fix all -- or even very many -- of the problems people are experiencing. I think they had a list of things they didn't complete before releasing 6.0 and that's what we're seeing with 6.01, with maybe just a few bug or configuration fixes. I think the next release will have more bug fixes.
No doubt, it wouldn't fix all issues. It certainly wouldn't fix an issue related to a new version of a third-party plugin. I'm glad to hear that the UAD issue is among the positives. But I also hope that certain GUI issues that caused 6.0 to crash (with no plugins loaded) when selecting tracks, deleting markers, etc., has been taken care of.
I haven't quite threaded the needle on the pre-rendering thing: "always run in real time" and "default to real time". There's a global element along with a local per-instance element at least implied. But kwiz's observation that remaining record-enable delays (which I've avoided by disabling pre-rendering) sort of concerns me. I can still run in real time if pre-rendering causes an action delay and subsequent crash, but it would be nice if this weren't a problem at all.
And I'm still keeping an eye out for that volume surge thingy.
wurliuchi
Post by wurliuchi »
James Steele wrote:Well the UAD stuff seems to be working great.
Yeah, that's good. They had to fix something! I'm going to check splicing and edge editing and fades, those were the killers for me.
I also notice they added back the automation snapshot button.
I think this fixes the "MIDI logjam" issue too.... I had a sequence that a friend sent me that would cause this to happen when you located back and forth and now it doesn't do this. I'd be curious if other users who were getting the MIDI "machine gun" effect to try this out and verify.
homebilly
Post by homebilly »
malditoyanki wrote:
James Steele wrote:
homebilly wrote:record enable delay still not fixed!
What is this issue? I'm not sure I'm aware of it.
I believe it's when switching between MIDI tracks for example with the arrow keys to quickly record enable them. You could do this in DP easily, but in DP 6 there is a noticeable lag and beachball that happens especially when switch between tracks that are assigned to different plugins.
yes the beachball + lag syndrome while switching tracks to record on (MIDI, aux or audio)
jeez :cry:
el Ocho 2.8 running DP6 & RMX with M5II - 828mkII / el Quatro 2.66 running Vienna VI & Vienna Ensemble, RAX 2, M5II & L8 for VSL - 2408mkII / steiner MIDI EVI, Oberheim Xpander, M5II reading UVI .dats, Radium 61 controller
http://www.ronmeza.com
Paris mini studio : iMac 20" intel 2.66 core duo (spring 2009) DP 6.02 - Firebox running M5II & Independence Pro 2.1 connected to Mac Mini (spring 2009) - Firebox running L8, RAX 2, Independence 2.1, M M5II
Keystation 49e controller
Bill O'C
Post by Bill O'C »
Bill O'C wrote:
monkey man wrote:Thank you for your kind thoughts, James. I've already started the download (registration must be automatic I guess), and as long as it allows me to resume tomorrow, I'll be fine.
My prime motivations for seeking the swap with the wholesaler are the fact that I was laughed at and my request ignored (even though it was agreed to by the boss), leading to much unanticipated loss of sleep, and that the manuals have arrived in a very sorry state; the heavily crumpled corners of both books are at the very least an eyesore and a distraction.
Further, I'd estimated to the fella that 6.01 would be shipping within 2 weeks or so, in response to which he laughed out aloud. That was 8 days ago. :lol:
That is unacceptable, and it really ticks me off. :evil: At the very least, Nicky, I would write a hard copy letter to MOTU headquarters stating the facts of the situation.
I'm sure MOTU doesn't want their distributors treating their customers that way, and there needs to be some accountability.
But don't write it when you're too angry. IMHO, the facts will speak for themselves.
piranesi
Post by piranesi »
I'm having problems with 6.0.1 which do not occur in 6.0
3 of my Sonnox plug-ins were crashing 6.0.1 on start. I switched all Sonnox plug-ins to 'render in real time' and made this the default. Now just the TransMod causes a crash at start up.
If the plug-ins are not used they don't cause a problem. If I use TransMod I get a crash so I've taken it out of the Components folder.
Strange. The same file with TransMod activated opens in 6.0 but not 6.0.1. and it was only the Sonnox plug-ins that caused a problem. Anyone else having similar problems?
Piranesi, Cortona
mchenetz
Post by mchenetz »
Any Eucon controller support yet?
Mike
Mike
Gear:
Monitoring: Apogee Ensemble and Duet - Digi 003 - JBL LSR Monitors
DAWs: Logic 8, Protools 7.4, DP 6, Ableton Live
DSP: UAD-1 x 2 - TC PowerCore MKII - Liquidmix
Controllers: Novation Remote SL, Kore
Synths: Moog LP II - Virus TI - Nord Lead 2 - Roland V-Synth XT - Kawai k5000s - Korg MS2000R - Waldorf Micro Q - Yamaha CS6R - Yamaha TEnori-on
Soft Synths: NI Komplete 5 - Digidesign Transfuser
kassonica
Post by kassonica »
Yea I got my copy and installed it yesterday so this update is timely :D
Sorry to hear your woes Nicky I'd be more than happy to DL anything for you and post it out to you free of charge :D Seriously though, now we are running the same system I get all the updates and I have quick broadband so just give us a hoy OK, It would be a pleasure :D
