Power for Micro Express
mtodd
Post by mtodd »
Hello All,
This may be a silly question, but here goes...
I was pointed to the Micro Express to solve two issues.
1) I need a MIDI interface to PC for three keyboards
2) In live applications, I was looking for a 'MIDI-director'. I would like to control one keyboard live from another. At other times I would like to shut off the control easily. Since the Micro Express can merge and channelize MIDI data even when not connected to a computer, I proposed setting up a preset with no MIDI transmitted, and another that transmits the control data. The fact that I did not need to have this connected to a computer for this live application was a big plus. My silly question is this... "How does the Micro Express get power when it is not connected to a computer via USB?"
I thank all for any advice.
jarok
Post by jarok »
Hi
http://www.motu.com/products/MIDI/micro_usb/tour.html
Quote:
Micro express USB connector provides power. No separate power cable is required.
You have to connect Micro express with computer USB to get it working.
jarok
carrythebanner
Post by carrythebanner »
You might be able to use a generic USB power supply.
mtodd
USB Power
Post by mtodd »
A blurb that appears on the Micro Express Tour for the Front Panel Interface states "User and factory presets provide stand alone operation, allowing you to merge and channelize MIDI data, even when the Micro Express is not connected to a computer.
May I ask... What is a generic USB power supply? :roll:
jarok
Re: USB Power
Post by jarok »
mtodd wrote:A blurb that appears on the Micro Express Tour for the Front Panel Interface states "User and factory presets provide stand alone operation, allowing you to merge and channelize MIDI data, even when the Micro Express is not connected to a computer.
Something like this for example:
http://www.proporta.com/F02/PPF02P05.ph ... t_mode=des
jarok
mtodd
USB Power
Post by mtodd »
Thank you very much. You've both been very helpful.
