monkey man wrote:No worries cob. Glad you got it sorted man.
MWLeveler, eh? I'm counting on it mate. DP due to arrive here any year now...
yep,
I have it slamming a sub of rock drums,..not using it subtle, it has lots or character. nice!
hate to be a wet blanket but the Waves Ren Comp still causes phasing when used in this capacity,.
oh well,.. fk it,
best-
P
Mac Pro 2.66 | 4GB ram | OS 10.5.4 | MacBook Pro 2.4 | 2GB ram | 10.5.4 | Apogee Ensemble | Apogee Duet | DP 6.01
Root is a "super-user" without any permissions restrictions. To be able to log as root, you have to open Directory Utility, unlock the padlock on the main window and from the menu edit, select "Enable Root User" Once that is done, you can log out from your regular account and login as root to authorize DP.
MacBookPro, 10.64, MOTU Ultralite, DP7.2, Live Suite 8, Logic Studio 9, MaxMSP 5
mlehmann wrote:Root is a "super-user" without any permissions restrictions. To be able to log as root, you have to open Directory Utility, unlock the padlock on the main window and from the menu edit, select "Enable Root User" Once that is done, you can log out from your regular account and login as root to authorize DP.
Thanks mlehmann! I just got my DP6 yesterday and was all set to get to work when...not so fast.
However, this solution worked for me. I would give it a try. Once you turn on "Root User" just type "root" for the username and the password it asked you to create, if you didn't already have a root password. I logged in as "root" activated and when back to my original account and everything is up and running.
Glad it worked! I already had that problem with DP 4.6 and repairing permissions fixed the problem. However this time, I was not so lucky until I thought about using root to authorize.
Thank You!!!!!!! Logging on as a root user got me DP6 up and running on OSX10.8!
I did have to change the all permissions to read and write on the Auth file (using get info)
and have the unlocked padlock on as i did it too....
serendo wrote:Thank You!!!!!!! Logging on as a root user got me DP6 up and running on OSX10.8!
For what it is worth...even though you got DP6 to authorize on your 10.8 machine...you will probably find DP6 to be frustrating to work with and it will most likely lead you to hate DP. It had a lot of issues. DP7 at a minimum is a MUCH better experience and everything DP6 should have been. Perhaps time to upgrade?
Regards,
Brian Ralston
___________________________________
- MacPro 7,1 3.2 GHz 16-core Intel Xeon W, 384GB 2933MHz DDR4 RAM, OS 10.15.7, 2TB SSD OS drive, 6TB Samsung Pro EVOPlus SSDs via Sonnet 4x4 M.2 PCIe card, Graphics card: AMD Radeon Pro Vega II 32GB, UAD-2 Quad, DP 10.13, DP 11.0,
- 15" MacBook Pro 2.3GHz 8‑core 9th‑generation Intel Core i9 processor, Turbo Boost to 4.8GHz, 32GB 2400MHz DDR4 mem, Radeon Pro Vega 20 w/4GB HBM2 mem, 2TB SSD storage, OS 10.15.7, 2TB SSD, DP 10.13
1. Find the invisible AUTH files for DP and delete all of them, no matter which version. There are many ways to do this but making them visible through Terminal works on all builds of OS X. I have posted the Terminal commands a number of times.
2. Run Repair Permissions in Apple's Disk Utility. This is the important step most leave out.
3. Re-authorize DP 5.13 or 6.03 while logged in as Admin or Root.
You can make 5.13 or 6.03 work in Lion or ML if authorized in 10.6.8 first, then the OS is upgraded. Only DP 7.24 and 8 can be authorized in OS 10.7 or higher.
DP 11.34; 828mkII FW, micro lite, M4, MTP/AV USB Firmware 2.0.1 2023 Mac Studio M2 8TB, 192GB RAM, OS Sequoia 15.4, USB4 8TB externals, Neumann MT48, M-Audio AIR 192|14, Mackie ProFxv3, Zoom F3 & UAC 232 32bit float recorder & interface; 2012 MBPs (x2) Catalina, Mojave IK-NI-Izotope-PSP-Garritan-Antares, LogicPro X, Finale 27.4, Dorico 5, Notion 6, Overture 5, TwistedWave, DSP-Q 5, SmartScore64 NE Pro, Toast 20 Pro
YEah i know... never liked DP6 much, and heard lots more hates on it. but one thing at a time, got the new computer last week,(macbook pro 2.6 quad) got the new UAD satetille to replace the solo card, the old 828 Mk1 is looking prehistoric, PT10 is looking tempting(interface with my friends studios alot easier)....argh the list goes on, I just wanna make music!
