MOTU 24 I/O users
MOTU 24 I/O users
Hit me up if you own this piece of gear. I'd like to know which driver you're using and how is it working for you.
http://www.myspace.com/timelesssoldierproductions" onclick="window.open(this.href);return false;
INTEL CORE2QUAD Q9650 @3.01 GHz, 4GB RAM, XP Service Pack 3, Sonar 8 (finally, from Sonar 3), 300GB VelociRaptor HD, WD 1TB HD, MOTU 24i/o SCard
I'm using it (along with a 2408 MK3) on a PCIe-424 card in Vista 64 with the 1.6.7.0 drivers. I find the MOTU Vista drivers a little funky in that they don't always detect the hardware if the PC boots with the rack unit switched on. I also find that I can't get as low a latency as I could with my old Delta 1010 units.
Other than that, the 24I/O seems to work pretty well, although I'd like to see them update their Vista drivers. Motu were quick out of the blocks with their Vista support for the PCIX-424/PCIe-424 based products, but since then have dropped the ball a little IMHO.
Well, I am still using Windows XP. I tried a year ago to get their latest driver to work on my system, and it didn't. And for the life of me, the latency is not as perfect as I'd like for it to be. I love the gear and the sound of it, but I need that latency to be on the dot!!
Are you using the ASIO or WDM??
sample rate
what sample rate are you using that is giving you the latency issue
Re: sample rate
48Khz 24bit is what I use..JBAUDIOPRODUCTIONS wrote:what sample rate are you using that is giving you the latency issue
The newest version of the drivers didn't work for me. But, in a week or so, I will retry them since I finally went ahead and updated to Service Pack2 of XP... I've never tried recording at 96Khz..
I JUST RECIEVED MINE ON FRIDAY AND HAVE HAD NO LATENCY ISSUES AT 2496 BUT YOUR RIGHT THE A/D CONVERTERS SOUND GREAT.
MAYBE ITS YOUR COMPUTER. DO HAVE RAIDED HARD DRIVES THAT MAKES A HUGE DIFFERENCE,[especially gigastudio}
well heres my system
asus p5b mb
pentium d 3.2 ghz processors
2 striped raided sata 300 80 gig hard drives [FOR AUDIO FILES ONLY}
2 GIGS OF OCZ OVERCLOCKING RAM
asus p5b mb
