Stewpid question, how do you delete measures?
- BKK-OZ
I added some measures that I now want to delete (at the begining of a sequence).
errrrr.... me stuck.... me stewpid...
how can I get rid of them?
Can't see anything in the manual about it.
All help gratefully rec'd.
Cheers,
BK
- M Kaku
BK
- M Kaku
- Shooshie
Re: Stewpid question, how do you delete measures?
SNIP, under the Edit Menu. I think it's Command J.
- Shooshie
Actually, I guess it depends on the context. But for what you're asking--snip the measures and move everything forward into their place--the SNIP command works perfectly.
- BKK-OZ
Thanx Shoshie, that works, sorta...
I get the measures out with that command but the references all stay the same (measure numbering is the same).
You see, I inserted some measures @ the beginning of this sequence, and they got numbered as -4, -3 etc,
Now I realise I don't need them, but when I cut them, the measure numbers are still starting @ -4, etc., but I want to start @ '0'.
Your help much appreciated. I'll give you that hug someday...
Cheers,
BK
- M Kaku
BK
- M Kaku
Hi,
I'm not sure if this applies in DP4 (I'm still on DP3). If I'm understanding your question, the answer might be found in the "Chunks" Window where you can "set chunk start". Perhaps doing this after the "snip" will accomplish what I think you are after.
Good luck.
http://phobos.apple.com/WebObjects/MZStore.woa/wa/viewAlbum?playListId=53612232
Good luck.
Macbook 2GHz Core 2 duo 2G memory Ultralite DP 7.24 OS 10.6.8
I had the exact same problem here a while back and the answer is in the chunks mini menu. Here is the thread about my problem
Thread
Thread
Mac Pro Quad "Nehalem" Xeon 2.93 Ghz-12GB RAM - OS 10.6.4-DP 7.21- & Logic 9.1.3 - MOTU 896HD- Apogee Big Ben-Tascam US2400-UAD2 Duo-Altiverb 6-Melodyne Editor-Autotune Evo-Plugins from UAD, URS, PSP, Abbey Road, Flux-VI's- LASS-EWQLSO-VSL-Kirk Hunter VS Pro-Kontakt 4 -Manley Voxbox, Brauner VM1, Soundelux E47C & much more.
- philbrown
The trick is selecting a time range including the conductor track rather than measures in the editor. Then do the Command-J snip.
My spoken-word editing work involves doing this about 300 times a day.
- BKK-OZ
thanx for that peoples, I appreciate the help and advice.
Cheers,
BK
- M Kaku
BK
- M Kaku
