David Polich wrote:Keep in mind it's worth it to purchase DP6 now (either full version or upgrade), even if you don't install it. You will need the installer disc, after the updates come out. The updates won't work without the original version of DP6 installed from the disk.
I purchased the upgrade and haven't installed, but I look forward to when the maintenance updates come out and I can then install.
Are you suggesting that I will pay more later if I don't get it now?
I could understand what you are are saying if this is the case.
I just thought about buying it now to work with it now.
But, not at the expense of being a crash test dummy.
So, I'll wait. I hope not too long as other things might catch up with updates.
I don't want to be stuck in the "twilight zone".
I wouldn't want to go to another DAW at this point.
So, I'll stay with DP 5.13 for now.
Everything works at this point.
TT
