Hello!
I need an audio interface to connect an electrical drumkid, bass, 2 x guitar and a mic and send it all out to multiple headphones. This way my band and I can practice in my own living room instead of investing in a dedicated rehearsal room. So my question is this: Can the jack outputs on the back of the 828mk3 mirror the stereo headphone output on the front? If not, do you know what I can do/buy to make this setup work?
Thank you for reading my post.
828mk3 as amplifier for multiple headphone signals possible?
- Pappy725
Yes, they can be set up to mirror the phones output. However, you will need a headphone amp to get the output up to proper levels. You can get those with several separate channels (mixes) whereby you could use all 8 of the outputs to give you 4 separate stereo monitor mixes.
Pap
Pap
MacBook Pro (Retina, 15-inch, Early 2013)
2.4 GHz Intel Core i7, 8GB RAM, OS High Sierra 10.13.2, DP8.07, 256GB SSD
828mkII, 8Pre, Alesis M1 Active Mk2, Ext. FW drives, Yamaha fretless bass, Kay upright bass, Wechter acoustic/electric, trombone, baritone and a proclivity for polka music. (With sufficient quantities of beer) and I play country music.
- Pappy725
You are correct sir.
