OS X 10.4.x? which update release is the best?
Hi,
I'm using a PPC G5 Dual 2.7 w. 4 GB of RAM
Based on your experience, which OS X/DP combination is more stable?
OS X 10.4.x?
DP 5.x?
Considering also various 3rd part. plugins (NI Komplete, Nomad Factory, Powercore, IK, Waves, etc...)
OS X 10.4.x?
DP 5.x?
FWIW, Dual 2.7 as you (only 2.5GB), 10.4.11 + DP 5.01 (think the next version was primarily the Intel update, so didn't bother; waiting for 6 now) + NI Komplete (et al), no particular problems, just the usual occasional "What the heck?/why'd that happen !?".
G5 Dual 2.7 2.5gb, (10.4.11).
Yamaha mLan:01x/i88x;
DP 5.01, Cubase SX3, NI Komplete, Melodyne, Ethno, MSI, et al.
- airtime
+1 for 10.4.11 and DP 5.13
iMac11,1, 2.66 GHz, 8 GBRAM, OS 10.6.8, DP 7.24, MOTU 828mkII (BLA clock & analog mods), VoiceMaster Platinum, RNP preamps, 4 handmade mic pres, AKG C451E (vintage), AKG 460B, AT 4050, Red/Oktava, sE Z5600A, Shure 545 Unidyne III, Sennheiser MD21s, a few cobbled electret mics, Genelec 1030As, SVS subwoofer and a room that's honest if you're in the sweet spot.
I'm not sure I would vote for 5.13!
quicktime playback offset definitely broken - PIA if you use the DV firewire out thing
haven't tried exporting a 4.5 file but you definitely can't export a 5.11 file in the save as
it might be a bit less prone to file corruption if you start a project in there - but maybe you going to have problems opening some older files in there...
I'm with the monkey man!
http://www.fork-media.com
Yup, from 10.4.9 onwards Apple seems to have started adding/tweaking code in preparation for Leopard (that's the only explanation I've been able to come up with).
I realise many folks have touted the efficacy of 5.13 on 10.4.11 for some time, but I remember a number of issues arising after the 10.4.8 platteau at which many (including myself and Shooshie) at the time agreed that 10.4.8 and 5.11 was the killer combo, possibly of all time 'till that point.
- Mr_Clifford
I'm on 5.13. But I'd probably say 5.11 is the best version of DP5. It's too late for me to go back now, but if you haven't upgraded yet, I'd say go to 5.11 and wait there for DP6 (or maybe DP6.11 once they iron out the kinks).
As for OS. 10.4.11 seems pretty good. And it worked fine with 5.11 the time i did go back and use it do a project (you can have 5.11 & 5.13 installed on the same system and go back and forth no problems - except for remembering which projects go with which version).
- Dwetmaster
Yep 10.4.11 is the way to go
Like 10.3.9 was
I'm wondering how the last leopard will be?
Like 10.3.9 was
