hi there
i'm using an original 896 with an intel macbook pro on 10.5.2. it works ok, but the cuemix console doesn't come up. cuemix loads and appears on the menu bar just fine, but no window as i'm accustomed to seeing. i've downloaded the current software from motu a few times to check myself, repaired permissions and so forth. no luck after any of that. i've tried opening up cuemix with and without the 896 attached and it performs the same - no window either way.
any clues appreciated.
cuemix console not appearing
alright, i checked and found this
http://mixonline.com/products/review/audio_motu/
with a quick google. i'd used cuemix with some other 896's, but i thought they were the hd models so that point is moot. and i'm away from home, so manuals and so forth are a few hundred miles away. if the cuemix console opened up i'd know what to do. i just can't determine if this is a known bug or something. and since i'm away from home, i can't troubleshoot quite as easily. for instance, at home i also have an 828 which i'd love to see configured via cuemix, although i suspect that this is some odd software issue which can be worked out.
