Random "spitting" on all outputs
SusanG
Post by SusanG »
Hi-
Ultralite/SONAR PE 7.0.2 (also encountered in FLS8)
There might be some posts about this, but I'm not sure what to search for! :wink:
I occasionally get a random "spitting" noise on all outputs, including SPDIF. The meters fly all over the place and when it eventually stops I have no audio output. I need to close SONAR, and restart the Ultralite.
I don't need to be playing or recording when this happens. I haven't done much to troubleshoot it, since I can't reproduce it at will. I suspect it has something to do with the fact that I usually have an internet connection active, but I wonder if anyone has experienced this and can confirm that's [probably] what it is?
I can go offline, but it's sometimes literally days between instances of the problem, so I wanted to check here first.
TIA-
-Susan
briandeeley
Post by briandeeley »
Exact same problem here, running Sonar PE 7.0.2 + Ultralite (latest drivers using ASIO) on a Vista laptop. Laptop has a onboard firewire and a TI chipset ExpressCard firewire. Same behavior on both.
Tried disabling all network components, alternating firewire ports, updating video drivers and all of it has made no difference. The behavior cannot be made to occur, so I'm at a bit of a loss where to go now. Also happens in WMP11 & SoundForge + Vegas.
Might try building an XP partition and give that a whirl, but that may be clutching at straws a little.
Anyone else have any ideas?
TIA
SB
SusanG
Post by SusanG »
Hi SB-
Ugh, that's not good! I was hoping it was a "known" issue with an easy fix.
Do you use the external power adapter? I haven't been, might try that.
BTW, I usually use WDM, so it's not an ASIO/WDM thing. Oh, and I'm on XP, so it's not an OS thing, either.
Halp!
-Susan
SusanG
Post by SusanG »
Nope, I still get it with the external power adapter, not that I thought that would make a difference...
Do the two of us just have faulty units? I'm not seeing much response to this thread.
It makes me nervous to try any "serious" live recording, since I don't know when this problem might raise its ugly head again.
Thanks-
-Susan
blaze
Post by blaze »
http://au.youtube.com/watch?v=OG7QwcveAH8
also its worth checking the comment on:
http://au.youtube.com/watch?v=PLQCy6sdd1g
I havent fixed it yet but when I use it with my mac... no problems.
I think the problems on windows are:
- WDM Drivers? - Try uninstalling the MOTU windows WDM drivers and just using the ASIO drivers in your DAW?
- Bad firewire card. I'm using my included card i got with my ASUS p5b Deluxe Wifi AP --- it doesnt appear to run too bad most of the time but sometimes i get the crackle etc on all channels.
SusanG
Post by SusanG »
Hi blaze-
Thanks for those links. Interesting that it might be just having the WDM drivers installed even if not "in use". There must be some other variable, though, since I've only seen this reported here and a couple of other places -- not a lot of response anywhere.
I just installed SP3 for XP last night. If the problem occurs again, I'll re-install my MOTU drivers without WDM, see how it goes, and post back.
Thanks again-
-Susan
briandeeley
Hi Blaze
How do you install the drivers without WDM? I have the latest ones from MOTU website and don't remember seeing any options one which driver components to install.
TIA
SB
SusanG
Post by SusanG »
It's been a while, but IIRC there are check boxes presented during the install. I just always left ASIO & WDM checked.
-Susan
SusanG
"Tentative" good news?
Post by SusanG »
I don't want to jinx it, but so far I haven't had this problem after installing XP SP3.
Hush...! :wink:
-Susan
briandeeley
Posted: Sun May 11, 2008 8:27 pm Post subject: "Tentative" good news?
Hush...!
Really????
Got a free morning today so gonna install an XP. Fingers crossed....
SusanG
Post by SusanG »
How'd it go, Brian? Still problem-free here, all digits crossed! My DAW builder thinks it might have been a Firewire update that resolved the issue.
-Susan
briandeeley
Hi SusanG
Not quite there with XP yet. I'm using an HP laptop which came preinstalled with Vista. Getting drivers for basic stuff is proving difficult and I believe will ultimately scupper the idea.
I've got XP loaded on a seperate partition with the Ultralite installed and you're right, it seems fine so far. However without drivers for things like video card, keyboard (work that one out!) it's there, but not usable for anything other than basic testing.
Glad to hear all is well under XP for you, I'll keep searching for drivers.
SB
briandeeley
Well, after a few days I've managed to get enough "generic" drivers for my HP laptop to function. It's a mixed blessing really because I can't get drivers for anything that is not required for audio so my XP partition is absolutely clean. Managed to get SP3 down + a few Microsoft drivers (video card + keyboard).
Good news is that my Ultralite perfoms as designed with no crackles!!!! I'm so happy, 1.5ms latency means I can use Amplitube in real time and with no posibility of getting any other XP drivers, the partition wil always be ready for audio only work.
What a result after weeks of troubles.
Many thanks to SusanG for the post about XP SP3 which inspired the last few days of surfing for drivers.
Now for a well earned beer, and some glitch free music.
All the best.
SB
SusanG
Post by SusanG »
Hi Brian-
You're more than welcome! I'm still running XP SP3 glitch-free here.
I have to say I'm surprised you're having problems finding XP drivers, but I guess that makes sense with a new Vista machine. I usually hear the opposite -- that it's hard to find Vista drivers for installed hardware (esp. soundcards).
Thanks for the update, and I hope it goes smoothly for you from here on!
-Susan
