we could use a "Chunks EDL"?
o.k....I had pretty good success with my "vertical nudge" suggestion...got some good chat and other ideas going. so I'll try again.
I guess I'd call this a "Chunks EDL". Something I noticed while working on a multi-Chunk film score last week was that there doesn't appear to be any place to see all of your Chunks with their;
a. start times,
b. end times,
c. durations.
Yes, you can see that info for any single chunk while you're working on that chunk and, yes, you can see the duration of the chunk in Soundbites once it's been rendered to audio.
But wouldn't be nice (and very helpful) to have a single window that showed all Chunks with Start Times, End Times and & Durations? And maybe even the ability to total up the duration values? Sort of an audio EDL? I know more than a few producers/editors that would like me to be able to furnish that kind of info.
a. start times,
b. end times,
c. durations.
Kurz Midiboard, MOTU MTP AV
https://vimeo.com/71580152
~me
~me
I certainly like that idea. I can't tell you how many times I'm using one chunk and want to know the start and end times of another. At the moment, I have to play enable the other chunk, write down the numbers and then switch back. If there's a lot of data (Vis, audio bundles etc.) involved, it can be very time consuming. I'd also like it if I could change the SMPTE start times of various chunks from inside the "EDL" page.
- Mr_Clifford
Thanks Mr. Clifford. I've been a Performer user since 1985 and it runs on my computer at least 40 hours a week. I didn't know about that (even though it's been staring me in the face for God knows how long). I guess it just shows that I follow the same paths in this program over and over and never look at another way of doing things. I wonder how many other features I've been missing.Mr_Clifford wrote:You can already do that from the 'chunks' window. From the pull-down menu select 'change start time'.modular wrote:I'd also like it if I could change the SMPTE start times of various chunks from inside the "EDL" page.
- Timeline
BUT an edl would give some surprising options like trim/duration and crossfades if done completely. Could be a real excellent add on and bring in pro users. I would love global CF.
- Shooshie
What is global CF? I need a definition of CF for the abbreviations dictionary in the Tips Sheet.
I know what EDL is. Just not CF.
Please, when an abbreviation is not common or possibly not known to a lot of readers, give us the whole words, then you can shorten it in subsequent references. The only context I know for CF is in computer hardware: compact flash memory.
I try to keep a list of all these things for our readers, here, but I can't keep up with them all. A little help now and then would be much appreciated.
- Timeline
It just means crossfade Shoosh. No biggie. Imagine though being able to select master fader outputs and controlling crossfades into any song of sound effects build. Or... cutting exactly on cue to any piece of music and enable master outputs different on each cut.. This type of edit would GREATLY enhance any DAW for post and or album production. How about notes on cuts too like a real edl. Automatic ripple of the list when a new chunk is added, tons more. I have a CMX manual somewhere.Shooshie wrote:What is global CF? I need a definition of CF for the abbreviations dictionary in the Tips Sheet.
Even having multiple edits in parallel. One might be sound effects and another music, another dialogue for global assembly.
The only limitation might be you would have to render all vis before DP could really play everything in sync because of the massive track collection from the originals.
- Shooshie
Doh! I thought you were referring to something involving Edit Lists. You did a 90-degree turn on me, and I kept going straight! :D:D
