leigh
Posts: 434 Joined: Fri Oct 15, 2004 10:01 pm
Post
by leigh » Fri Apr 11, 2008 6:48 pm
dtiger wrote: I've got my mac pro 3.0 in an iso box too, L, and when the temp gets up around 85 degrees if I've been pushing the thing hard all day and night I might get a crash. The good thing is everything recovers fine and the thing cranks so I've got no complaints.
But I've been wondering, since it's in the iso box already, couldn't I leave off the side panel and treat the whole iso box like an extended computer enclosure, letting the heat dissipate a bit more? Or do you think I'm courting disaster with static and dust?
D
dtiger,
What kind of crash? Is it a DP crash or a kernel panic?
I'm not sure about leaving the cover off. The airflow system over critical components may require the cover to be in place.
**Leigh
Renaissance Man
Posts: 272 Joined: Mon Nov 01, 2004 10:01 pm
Post
by Renaissance Man » Fri Apr 11, 2008 7:16 pm
When I upgraded to the 2.8 8-core it wouldn't fit in the isobox which I had built for my G4 Macs. Thankfully the 8-core is extremely quiet and is not a problem from an ambient noise standpoint.
The fact that it wouldn't fit is perhaps a good thing, as the 8- 2GB ram modules I installed put off a serious amount of heat (and even though the processors are more efficient, I imagine the 8-core processors generate considerable heat also).
As processing power and ram capacity continue to increase, it may require re-engineering the cooling capacities of the various iso-boxes.
You might try operating the 8-core outside of your isobox to determine if the noise level is acceptable without it.
After running the 8-core hard, shutting it down and opening the cover to see where the hot spots are, I personally would not operate it (or any Mac for that matter) without the covers in place.
Christopher
Mac Pro Mid 2012 12-core 3.46GHz, 128GB RAM, Mojave, DP11, Waves Mercury & SSL 4000, VocAlign Project 3, Melodyne 5, EastWest Quantum Leap Pianos & Voices of Soul, Nomad Factory Integral Studio Pack, Slate Digital VCC, RC Tube & Trigger, & lots more plug-ins, MOTU PCIe 424, 3-2408Mk3's, 24io, MTP AV USB, Apogee AD-16X's & Big Ben, CraneSong HEDD 192, ATC monitors, tons of outboard gear & microphones, MIDI/keyboard rig, house drums & tuned percussion
www.nrpstudio.com
dtiger
Posts: 17 Joined: Fri Sep 09, 2005 6:34 pm
Post
by dtiger » Sun Apr 13, 2008 2:38 am
Leigh, they are DP crashes. I think I am running too many VI's at once and then after the machine has been pushed hard for hours it seems like it needs a break. A restart is like magic. I'm not a computer tech but it SEEMS like either all direct from hard disk sample reading and buffering across all the different drives for extended periods starts to gunk things up and it needs some naptime, or things are just getting to hot after prolonged use and it needs to chill a bit. But it always comes back strong.
Ren man, that is a good point, they are really quiet machines. I got the iso box based on my experiences with the G5.
Thanks for your replies.
D
Posts: 10459 Joined: Tue Jan 10, 2006 9:01 am
Post
by HCMarkus » Sun Apr 13, 2008 3:18 pm
Not sure about the Intels, but the G5 has a baffle that fits inside the panel cover. Instructions warned me to never operate without it.
Timeline
Posts: 4910 Joined: Tue Nov 09, 2004 10:01 pm
Post
by Timeline » Wed Apr 16, 2008 9:01 am
Update:
I dropped my MP off at the apple repair center store and they ran the stress test. After one hour it locked up.
I'm laughin big time but cryin inside from all the pain this POS cost me.
G
Posts: 19820 Joined: Sat Oct 16, 2004 10:01 pm
Post
by Shooshie » Wed Apr 16, 2008 9:14 am
Timeline wrote: Update:
G
So sorry to hear that, Gary, but GLAD to hear that they've found something. It sucks big time to go through that. Man, I hope they replace it with one that gives you no trouble. Did they say that option is on the table? Or is it a mobo replacement? Well, anyway, I hope you get some satisfaction out of this. You've been talking about that for a long time, and I've been hoping there might be a new computer in it for you.
Tritonemusic
Posts: 2749 Joined: Fri Oct 15, 2004 10:01 pm
Post
by Tritonemusic » Wed Apr 16, 2008 12:02 pm
Putting all of your problems aside, you couldn't be luckier that something went down while Apple was testing your box. I hope you get a brand new machine.
Edit: Oops. Looks like Shooshie beat me to it.
leigh
Post
by leigh » Wed Apr 16, 2008 12:15 pm
There's nothing worse than going through all you've been through only to have it pass all of Apple's tests so I am glad it failed for Apple. I believe you definitely deserve a new machine.
My Mac Pro is the first desktop machine I've ever bought AppleCare for since I started with my MacPlus. I'm not yet sure that these more complex machines are more reliable, but they are more expensive to fix.
**Leigh
Timeline
Post
by Timeline » Wed Apr 16, 2008 1:27 pm
Well I put a healthy scratch on the case so I think it's mine but who knows.
The report also said they think it was script related and changed the video board which was a gforce 8800 I special ordered. Is there any chance the video card could have done all this? I really have no clue. They say done by the 20th. Which ever way it turns out I will be thrilled to get it back working.
Timeline
Post
by Timeline » Sat Apr 19, 2008 2:12 pm
Interesting update on my 08 mac....
After replacing the motherboard, GeForce 8800gt graphics card and running the stress test again, the machine fails. They are thinking now it's the raid card.
I really expected that but still unsure. A mac pro genius on the discussion boards said overheating had been an issue with ATTO boards but surprise, Mac's too?
They are going to bit copy the drives and hand me back a brand new latest update machine I guess. I asked them to please run the stress test before I accept it.
I can't say enough good things about the way they handle mission critical clients like we are in DAW environments.
Hurray! x3 for Apple. Now I know why I paid so much.
Timeline
Post
by Timeline » Mon Apr 28, 2008 8:25 pm
Machine returned. Spiking gone but then this when I tried to record: HELP!!!
Date/Time: 2008-04-28 20:16:20 -0700
OS Version: 10.5.2 (Build 9C7010)
Architecture: i386
Report Version: 4
Command: Digital Performer
Path: /Applications/MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/Digital Performer
Version: 5.13 (5.13)
Parent: launchd [87]
PID: 565
Event: hang
Time: 6.85s
Steps: 45
Process: Digital Performer [565]
ADDRESS BINARY
00001000 /Applications/MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/Digital Performer
00e26000 /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
00e5b000 /Applications/MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/AllUtilities.dylib
00e85000 /Applications/MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/DPBasicUI.dylib
00ef4000 /Applications/MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/DPPart2.dylib
01332000 /Applications/MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/FileSystem.dylib
01348000 /Applications/MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/GenericPanes.dylib
013ca000 /Applications/MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/HiLevelWrappers.dylib
014d9000 /Applications/MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/../Frameworks/MidiSystem.framework/Versions/A/MidiSystem
015fa000 /Applications/MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/../Frameworks/MotuPublicObjects.framework/Versions/A/MotuPublicObjects
015ff000 /Applications/MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/../Frameworks/MotuAudioSystem.framework/Versions/A/MotuAudioSystem
016c7000 /Applications/MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/../Frameworks/MotuDAE.framework/Versions/A/MotuDAE
017f2000 /Applications/MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/OMF_AAF.dylib
018c6000 /Applications/MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/PerfEngine.dylib
01f6f000 /Applications/MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/PerfError.dylib
01f7a000 /Applications/MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/PerfFoundation.dylib
020ff000 /Applications/MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/PerfMSL.dylib
0210e000 /Applications/MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/PureDSP.dylib
02211000 /Applications/MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/ResourceAccess.dylib
02219000 /Applications/MOTU DP5 Folder/Digital Performer 5.13.app/Contents/MacOS/XML.dylib
02238000 /usr/lib/libexpat.1.dylib
027f7000 /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
17788000 /Library/Audio/Plug-Ins/MOTU Audio Export/Core Audio Export.bundle/Contents/MacOS/Core Audio Export
177c7000 /Library/Audio/Plug-Ins/MOTU Audio Export/LAME Audio Export.bundle/Contents/MacOS/LAME Audio Export
1786e000 /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
17a29000 /Library/Audio/Plug-Ins/MOTU Audio Export/QuickTime Export.bundle/Contents/MacOS/QuickTime Export
184c0000 /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
18506000 /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
1850f000 /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
18519000 /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
187e1000 /Library/Audio/Plug-Ins/MAS/Arc Panner.bundle/Contents/MacOS/Arc Panner
18a0b000 /Library/Audio/Plug-Ins/MAS/Auralizer.bundle/Contents/MacOS/Auralizer
18c71000 /Library/Audio/Plug-Ins/MAS/AutoPan.bundle/Contents/MacOS/AutoPan
18e88000 /Library/Audio/Plug-Ins/MAS/Bass Manager.bundle/Contents/MacOS/Bass Manager
18fe6000 /Library/Audio/Plug-Ins/MAS/BassLine.bundle/Contents/MacOS/BassLine
19310000 /Library/Audio/Plug-Ins/MAS/Buffy.bundle/Contents/MacOS/Buffy
1941a000 /Library/Audio/Plug-Ins/MAS/Calibration.bundle/Contents/MacOS/Calibration
195b5000 /Library/Audio/Plug-Ins/MAS/Chorus.bundle/Contents/MacOS/Chorus
19716000 /Library/Audio/Plug-Ins/MAS/DCNotch.bundle/Contents/MacOS/DCNotch
19805000 /Library/Audio/Plug-Ins/MAS/Delay.bundle/Contents/MacOS/Delay
19a5a000 /Library/Audio/Plug-Ins/MAS/Dynamics.bundle/Contents/MacOS/Dynamics
19bbe000 /Library/Audio/Plug-Ins/MAS/Echo.bundle/Contents/MacOS/Echo
19db6000 /Library/Audio/Plug-Ins/MAS/eVerb.bundle/Contents/MacOS/eVerb
19ff1000 /Library/Audio/Plug-Ins/MAS/Flanger.bundle/Contents/MacOS/Flanger
1a16f000 /Library/Audio/Plug-Ins/MAS/InvertPhase.bundle/Contents/MacOS/InvertPhase
1a1bc000 /Library/Audio/Plug-Ins/MAS/MAS AudioUnit Support.bundle/Contents/MacOS/MAS AudioUnit Support
1a287000 /Library/Audio/Plug-Ins/MAS/MasterWorks Compressor.bundle/Contents/MacOS/MasterWorks Compressor
1a455000 /Library/Audio/Plug-Ins/MAS/MasterWorks EQ.bundle/Contents/MacOS/MasterWorks EQ
1a800000 /Library/Audio/Plug-Ins/MAS/MasterWorks Gate.bundle/Contents/MacOS/MasterWorks Gate
1a995000 /Library/Audio/Plug-Ins/MAS/MasterWorks Limiter.bundle/Contents/MacOS/MasterWorks Limiter
1aba9000 /Library/Audio/Plug-Ins/MAS/Model12.bundle/Contents/MacOS/Model12
1b135000 /Library/Audio/Plug-Ins/MAS/Modulo.bundle/Contents/MacOS/Modulo
1b6e9000 /Library/Audio/Plug-Ins/MAS/MS Decoder.bundle/Contents/MacOS/MS Decoder
1b8b2000 /Library/Audio/Plug-Ins/MAS/Multimode Filter.bundle/Contents/MacOS/Multimode Filter
1ba71000 /Library/Audio/Plug-Ins/MAS/n-Panner.bundle/Contents/MacOS/n-Panner
1bc89000 /Library/Audio/Plug-Ins/MAS/nanosampler.bundle/Contents/MacOS/nanosampler
1c234000 /Library/Audio/Plug-Ins/MAS/ParaEQ.bundle/Contents/MacOS/ParaEQ
1c468000 /Library/Audio/Plug-Ins/MAS/PatternGate.bundle/Contents/MacOS/PatternGate
1c5f5000 /Library/Audio/Plug-Ins/MAS/Phaser.bundle/Contents/MacOS/Phaser
1c7f6000 /Library/Audio/Plug-Ins/MAS/Plate.bundle/Contents/MacOS/Plate
1c999000 /Library/Audio/Plug-Ins/MAS/PolySynth.bundle/Contents/MacOS/PolySynth
1cce0000 /Library/Audio/Plug-Ins/MAS/Preamp-1.bundle/Contents/MacOS/Preamp-1
1ce81000 /Library/Audio/Plug-Ins/MAS/Proton.bundle/Contents/MacOS/Proton
1d2d5000 /Library/Audio/Plug-Ins/MAS/Quan Jr.bundle/Contents/MacOS/Quan Jr
1d3f2000 /Library/Audio/Plug-Ins/MAS/Reverb.bundle/Contents/MacOS/Reverb
1d502000 /Library/Audio/Plug-Ins/MAS/Reverse.bundle/Contents/MacOS/Reverse
1d520000 /Library/Audio/Plug-Ins/MAS/RingMod.bundle/Contents/MacOS/RingMod
1d683000 /Library/Audio/Plug-Ins/MAS/Sonic Modulator.bundle/Contents/MacOS/Sonic Modulator
1d879000 /Library/Audio/Plug-Ins/MAS/Tremolo.bundle/Contents/MacOS/Tremolo
1d9e2000 /Library/Audio/Plug-Ins/MAS/Trigger.bundle/Contents/MacOS/Trigger
1db5d000 /Library/Audio/Plug-Ins/MAS/Trim.bundle/Contents/MacOS/Trim
1dd04000 /Library/Audio/Plug-Ins/MAS/TriPan.bundle/Contents/MacOS/TriPan
1df87000 /Library/Application Support/Propellerhead Software/ReWire/ReWire.bundle/Contents/MacOS/ReWire
1e005000 /System/Library/PrivateFrameworks/OpenTransport.framework/OpenTransport
1e276000 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
1e285000 /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
1e29b000 /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
1e6b9000 /Library/Audio/Plug-Ins/MOTU Control Surface/MackieControl.bundle/Contents/MacOS/MackieControl
1e70f000 /Library/Audio/Plug-Ins/MOTU Control Surface/SAC DP Driver.bundle/Contents/MacOS/SAC DP Driver
1ea2f000 /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
1ed59000 /usr/lib/libmx.A.dylib
2109f000 /Library/Audio/Plug-Ins/Components/WaveShell-AU 5.9.7.component/Contents/MacOS/WaveShell-AU
21492000 /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
2154b000 <unknown>
21610000 /Applications/Waves/Waves Plug-Ins/RDeEsser.bundle/Contents/MacOS/RDeEsser
216b1000 /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
216cf000 /Users/garybrandt/Library/Caches/Waves/Applications/Waves/Waves Plug-Ins/RDeEsser.bundle/Contents/Resources/RDeEsser.rsrc/asIL/1000
21800000 <unknown>
2195e000 /Library/Audio/Plug-Ins/Components/AutoTuneAU_MM.component/Contents/MacOS/AutoTuneAU_MM
21d89000 <unknown>
2229f000 /Applications/Waves/Waves Plug-Ins/WavesLib 5.9.7.framework/Versions/A/WavesLib
22853000 /Library/Audio/Plug-Ins/Components/AutoTuneAU_MM.component/Contents/Resources/AutoTuneAU_MM.bundle/Contents/MacOS/AutoTuneAU_MM
22af8000 /Library/Audio/Plug-Ins/Components/UAD Precision Limiter.component/Contents/MacOS/UAD Precision Limiter
22b59000 /Library/Audio/Plug-Ins/Components/UAD Precision Limiter.component/Contents/Resources/UAD Precision Limiter.vst/Contents/MacOS/UAD Precision Limiter
23183000 /Library/Frameworks/UAD GUI Library.framework/Versions/A/UAD GUI Library
23327000 /Library/Audio/Plug-Ins/Components/UAD Precision Equalizer.component/Contents/Resources/UAD Precision Equalizer.vst/Contents/MacOS/UAD Precision Equalizer
23dc4000 /Library/Audio/Plug-Ins/Components/ViennaInstruments.component/Contents/MacOS/ViennaInstruments
242af000 /Library/Audio/Plug-Ins/Components/BFD2.component/Contents/MacOS/BFD2
2ae96000 /Library/Audio/Plug-Ins/Components/Hypersonic.component/Contents/MacOS/Hypersonic
2bb87000 /Library/Application Support/Syncrosoft/pos/Synsoacc.bundle/Contents/MacOS/Synsoacc
4078e000 /Library/Audio/Plug-Ins/Components/Ambience.component/Contents/MacOS/Ambience
ba900000 /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
bab00000 /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
Thread id: 15986048
User stack:
45 ??? [0x338d]
45 ??? [0x3466]
45 ??? [0x5c48f9]
45 ??? [0x5c3fbc]
45 ??? [0x5c3efd]
45 ??? [0x5c3c71]
45 __Z17SafeWaitNextEventtP18EventRecordAdaptermP15OpaqueRgnHandle + 52 (in PerfFoundation.dylib) [0x1f83cbc]
45 _WaitNextEvent + 54 (in HIToolbox) [0x9164eef5]
45 _WNEInternal + 151 (in HIToolbox) [0x9164ef96]
45 _GetNextEventMatchingMask + 447 (in HIToolbox) [0x9164f28f]
45 _RunCurrentEventLoopInMode + 283 (in HIToolbox) [0x9159b6a0]
45 _CFRunLoopRunInMode + 88 (in CoreFoundation) [0x918e6d18]
45 _CFRunLoopRunSpecific + 4494 (in CoreFoundation) [0x918e6b5e]
45 ??? [0x1e1702]
45 ??? [0x1e198b]
45 __Z11MaybeRTPollb + 215 (in PerfEngine.dylib) [0x1a0173b]
45 __Z11AudioRTPollb + 110 (in PerfEngine.dylib) [0x1ae357e]
45 ??? [0x122840]
45 __ZN22WrappedMotuAudioSystem4PollEv + 43 (in DPPart2.dylib) [0xfd3703]
45 _MAS82879 + 130 (in MotuAudioSystem) [0x165982c]
45 _semaphore_wait_trap + 10 (in libSystem.B.dylib) [0x9352ba22]
Kernel stack:
2 _i386_astintr + 47 [0x1a7e22]
2 _ast_taken + 247 [0x1291b0]
2 _bsd_ast + 721 [0x37e4cb]
2 _postsig + 351 [0x37ca5b]
2 _exit1 + 392 [0x3712dd]
1 _task_terminate_internal + 240 [0x13b5f2]
1 _ipc_space_destroy + 169 [0x1246fb]
1 _ipc_right_clean + 419 [0x1234d5]
1 _ipc_notify_no_senders + 30 [0x121170]
1 _mach_notify_no_senders + 75 [0x14bed3]
1 _mach_msg_send_from_kernel + 90 [0x12d38d]
1 _ipc_kmsg_send + 111 [0x1200dd]
1 _ipc_kobject_server + 270 [0x12d192]
1 _iokit_notify + 169 [0x187332]
1 _iokit_client_died + 85 [0x43d4ed]
1 com.uaudio.driver.HypKern (4.9.0) + 10177 [0xada7c1]
1 com.uaudio.driver.HypKern (4.9.0) + 10101 [0xada775]
1 com.uaudio.driver.HypKern (4.9.0) + 9967 [0xada6ef]
1 com.uaudio.driver.HypKern (4.9.0) + 9876 [0xada694]
1 com.uaudio.kext.HypAudio (4.9.0) + 5072 [0x9733d0]
1 com.uaudio.kext.HypAudio (4.9.0) + 274449 [0x9b5011]
1 com.uaudio.kext.HypAudio (4.9.0) + 274402 [0x9b4fe2]
1 com.uaudio.kext.HypAudio (4.9.0) + 22256 [0x9776f0]
1 com.uaudio.kext.HypAudio (4.9.0) + 22174 [0x97769e]
1 com.uaudio.kext.HypAudio (4.9.0) + 16050 [0x975eb2]
1 com.uaudio.kext.HypAudio (4.9.0) + 39793 [0x97bb71]
1 com.uaudio.kext.HypAudio (4.9.0) + 90170 [0x98803a]
1 com.uaudio.kext.HypAudio (4.9.0) + 72900 [0x983cc4]
1 com.uaudio.kext.HypAudio (4.9.0) + 273895 [0x9b4de7]
1 _IOSleep + 25 [0x403745]
1 _delay_for_interval + 49 [0x12988c]
1 _thread_block + 33 [0x1369fb]
1 _thread_continue + 1181 [0x13678e]
1 _task_terminate_internal + 313 [0x13b63b]
1 _vm_map_remove + 145 [0x16a361]
1 _vm_map_simplify + 4131 [0x169d99]
1 _pmap_remove_range + 1104 [0x1934af]
Thread id: 1424c7d8
User stack:
43 _thread_start + 34 (in libSystem.B.dylib) [0x9355cb12]
43 __pthread_start + 321 (in libSystem.B.dylib) [0x9355cc55]
43 __ZN10PerfAssert18SetEnableDebugMsgsEb + 4019 (in PerfMSL.dylib) [0x2103bcf]
43 __ZN10PerfAssert18SetEnableDebugMsgsEb + 4746 (in PerfMSL.dylib) [0x2103ea6]
43 _mach_wait_until + 10 (in libSystem.B.dylib) [0x9352bb06]
Kernel stack:
1 _dtrace_get_cpu_int_stack_top + 543 [0x1972ea]
1 _mach_wait_until_trap + 61 [0x12975a]
1 _thread_block_reason + 135 [0x136957]
1 _thread_setrun + 2924 [0x135e69]
1 _machine_idle + 278 [0x1a2aab]
Thread id: 14143a78
User stack:
43 _catch_exception_raise_state + 527 (in PerfMSL.dylib) [0x2101e43]
43 _mach_msg_trap + 10 (in libSystem.B.dylib) [0x9352b9e6]
Thread id: 155c7048
User stack:
43 __ZN16PerfWorkerThread9GetThreadEv + 1085 (in PerfFoundation.dylib) [0x1fc655d]
Thread id: 27eb28b8
User stack:
43 __ZN14PerfAudioCache7RunJobsERSt6vectorIP11workq_ele_tSaIS2_EE + 705 (in PerfEngine.dylib) [0x1af2355]
43 _semaphore_timedwait_trap + 10 (in libSystem.B.dylib) [0x9352ba3a]
Kernel stack:
9 _dtrace_get_cpu_int_stack_top + 543 [0x1972ea]
9 _semaphore_timedwait_trap + 41 [0x1399f1]
9 _semaphore_timedwait_trap_internal + 89 [0x1399b3]
9 _semaphore_wait_internal + 565 [0x139750]
9 _thread_block + 33 [0x1369fb]
9 _thread_block_reason + 135 [0x136957]
9 _thread_setrun + 2924 [0x135e69]
9 _machine_idle + 278 [0x1a2aab]
Thread id: 15210128
User stack:
43 __ZN9CAPThread5EntryEPS_ + 96 (in CoreMIDI) [0xe389ee]
43 __ZN7XThread9RunHelperEPv + 17 (in CoreMIDI) [0xe2e07d]
43 __ZN16MIDIInPortThread3RunEv + 111 (in CoreMIDI) [0xe2a477]
Kernel stack:
5 _dtrace_get_cpu_int_stack_top + 543 [0x1972ea]
5 _mach_msg_overwrite_trap + 4783 [0x12721c]
5 _ipc_mqueue_receive + 738 [0x120ea4]
5 _thread_block + 33 [0x1369fb]
5 _thread_block_reason + 135 [0x136957]
5 _thread_setrun + 2924 [0x135e69]
5 _machine_idle + 278 [0x1a2aab]
Thread id: 156a6e40
User stack:
43 __ZN9CAPThread5EntryEPS_ + 96 (in CoreAudio) [0x95099300]
43 __ZN10HALRunLoop9OwnThreadEPv + 160 (in CoreAudio) [0x95099464]
43 _CFRunLoopRunInMode + 88 (in CoreFoundation) [0x918e6d18]
Thread id: 155c3f20
User stack:
43 ??? [0x1647848]
43 ??? [0x164778c]
43 _MasEffectHelper_AllocateBuffer + 62396 (in MotuAudioSystem) [0x1670816]
43 _semaphore_wait_trap + 10 (in libSystem.B.dylib) [0x9352ba22]
Thread id: 27eaff20
User stack:
43 ??? [0x1646fa5]
43 ??? [0x160a0b9]
43 ??? [0x1602e5f]
Thread id: 27eb1d60
User stack:
43 _RWPUnregisterDeviceImp + 132794 (in ReWire) [0x1dfada5c]
43 _RWPUnregisterDeviceImp + 21574 (in ReWire) [0x1df927e8]
Kernel stack:
2 _dtrace_get_cpu_int_stack_top + 543 [0x1972ea]
2 _mach_wait_until_trap + 61 [0x12975a]
2 _thread_block + 33 [0x1369fb]
2 _thread_block_reason + 135 [0x136957]
2 _thread_setrun + 2924 [0x135e69]
2 _machine_idle + 278 [0x1a2aab]
Thread id: 1479d128
User stack:
Kernel stack:
34 _dtrace_get_cpu_int_stack_top + 543 [0x1972ea]
34 _mach_wait_until_trap + 61 [0x12975a]
34 _thread_block + 33 [0x1369fb]
34 _thread_block_reason + 135 [0x136957]
34 _thread_setrun + 2924 [0x135e69]
34 _machine_idle + 278 [0x1a2aab]
Thread id: 14e71a78
User stack:
43 _MasEffectHelper_AllocateBuffer + 17435 (in MotuAudioSystem) [0x1665875]
Thread id: 27f1c410
User stack:
Thread id: 14e712e8
User stack:
Thread id: 15986ba0
User stack:
Thread id: 27f1b8b8
User stack:
Thread id: 27f1a208
User stack:
43 _MasEffectHelper_AllocateBuffer + 17251 (in MotuAudioSystem) [0x16657bd]
43 _MasEffectHelper_AllocateBuffer + 11260 (in MotuAudioSystem) [0x1664056]
43 ??? [0x16364fd]
43 __ZN16MasAUSupportProc7ProcessEP13MotuExceptionPPfP13MasBufferInfoP17IMasEffectContext + 2549 (in MAS AudioUnit Support) [0x1a1e6793]
43 __ZN10AudioUnits4Base6renderERmRK14AudioTimeStampmmP15AudioBufferList + 66 (in MAS AudioUnit Support) [0x1a1d32f0]
43 _AudioUnitRender + 67 (in AudioUnit) [0x91ef7af3]
43 _CallComponentDispatch + 29 (in CarbonCore) [0x922ec5cd]
43 _SynthEditEntry + 33 (in Hypersonic) [0x2af53063]
43 __ZN6AUBase22ComponentEntryDispatchEP19ComponentParametersPS_ + 410 (in Hypersonic) [0x2ae9d254]
43 __ZN6AUBase8DoRenderERmRK14AudioTimeStampmmR15AudioBufferList + 733 (in Hypersonic) [0x2ae989ab]
43 __ZN7CPlugIn6RenderERmRK14AudioTimeStampm + 613 (in Hypersonic) [0x2afc1c9d]
43 __ZN5Synth16processReplacingEPPfS1_i + 377 (in Hypersonic) [0x2afa8807]
43 __ZN5Synth4SyncEv + 424 (in Hypersonic) [0x2afa3504]
43 __ZN6Engine6resyncEdddddl + 260 (in Hypersonic) [0x2af85316]
21 __ZN14FX_ReverseVerb8setParamElf + 334 (in Hypersonic) [0x2aee52e8]
11 __ZN14FX_ReverseVerb8setParamElf + 341 (in Hypersonic) [0x2aee52ef]
11 __ZN14FX_ReverseVerb8setParamElf + 338 (in Hypersonic) [0x2aee52ec]
Kernel stack:
43 _PE_incoming_interrupt + 131 [0x446f38]
43 _lapic_interrupt + 300 [0x1af78e]
43 _sync_iss_to_iks + 114 [0x1a7f5e]
Thread id: 159858b8
User stack:
Thread id: 156a53c8
User stack:
Thread id: 14e725d0
User stack:
43 __ZN11HP_IOThread11ThreadEntryEPS_ + 17 (in CoreAudio) [0x950a8aab]
43 __ZN11HP_IOThread8WorkLoopEv + 759 (in CoreAudio) [0x950a8da7]
43 __ZN7CAGuard9WaitUntilEy + 70 (in CoreAudio) [0x950aa602]
43 __ZN7CAGuard7WaitForEy + 213 (in CoreAudio) [0x950a8a47]
43 _semaphore_timedwait_signal_trap + 10 (in libSystem.B.dylib) [0x9352ba46]
Kernel stack:
16 _dtrace_get_cpu_int_stack_top + 543 [0x1972ea]
16 _semaphore_timedwait_signal_trap + 48 [0x13984c]
16 _semaphore_timedwait_signal_trap_internal + 112 [0x1397fc]
16 _semaphore_wait_internal + 565 [0x139750]
16 _thread_block + 33 [0x1369fb]
16 _thread_block_reason + 135 [0x136957]
16 _thread_setrun + 2924 [0x135e69]
16 _machine_idle + 278 [0x1a2aab]
Thread id: 15983a78
User stack:
43 __ZN4BFD227MessageServicingThreadProxyEPv + 17 (in BFD2) [0x242c6561]
43 __ZN4BFD222MessageServicingThreadEv + 140 (in BFD2) [0x242c651c]
Kernel stack:
Thread id: 1479e410
User stack:
43 __ZN11VFoundation10VJobServer17ServerThreadProxyEPv + 21 (in BFD2) [0x24943c79]
43 __ZN11VFoundation10VJobServer12ServerThreadEv + 330 (in BFD2) [0x249432a8]
43 __ZN11VFoundation10VSemaphore16WaitForSemaphoreEl + 86 (in BFD2) [0x2495d132]
Kernel stack:
11 _dtrace_get_cpu_int_stack_top + 543 [0x1972ea]
11 _mach_wait_until_trap + 61 [0x12975a]
11 _thread_block + 33 [0x1369fb]
11 _thread_block_reason + 135 [0x136957]
11 _thread_setrun + 2924 [0x135e69]
11 _machine_idle + 278 [0x1a2aab]
Thread id: 14248000
User stack:
Thread id: 27eaf000
User stack:
43 __Z15AsyncFileThreadPv + 73 (in CarbonCore) [0x922e340b]
43 _TSWaitOnSemaphoreCommon + 422 (in CarbonCore) [0x922e370a]
43 _TSWaitOnConditionTimedRelative + 246 (in CarbonCore) [0x922e392a]
Thread id: 155c3790
User stack:
Kernel stack:
7 _dtrace_get_cpu_int_stack_top + 543 [0x1972ea]
7 _mach_wait_until_trap + 61 [0x12975a]
7 _thread_block + 33 [0x1369fb]
7 _thread_block_reason + 135 [0x136957]
7 _thread_setrun + 2924 [0x135e69]
7 _machine_idle + 278 [0x1a2aab]
Process: ATSServer [117]
Path: /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support/ATSServer
ADDRESS BINARY
00001000 /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support/ATSServer
Thread id: 1535b410
User stack:
45 ??? [0x4e26]
45 ??? [0xdd24f]
45 _CFRunLoopRun + 84 (in CoreFoundation) [0x918e6d74]
45 _mach_msg_trap + 10 (in libSystem.B.dylib) [0x9352b9e6]
Kernel stack:
1 _mach_msg_overwrite_trap + 4783 [0x12721c]
1 _ipc_mqueue_receive + 738 [0x120ea4]
Thread id: 1535b048
User stack:
45 _thread_start + 34 (in libSystem.B.dylib) [0x9355cb12]
45 __pthread_start + 321 (in libSystem.B.dylib) [0x9355cc55]
Process: AirPort Base Station Agent [104]
Path: /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
ADDRESS BINARY
00001000 /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
Thread id: 152117d8
User stack:
45 ??? [0x1e32]
45 _NSApplicationMain + 574 (in AppKit) [0x9452e30a]
45 -[NSApplication run] + 795 (in AppKit) [0x945610c5]
45 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128 (in AppKit) [0x9456808e]
45 __DPSNextEvent + 657 (in AppKit) [0x945687d9]
45 _BlockUntilNextEventMatchingListInMode + 106 (in HIToolbox) [0x9159b32d]
45 _ReceiveNextEventCommon + 374 (in HIToolbox) [0x9159b4b9]
Process: CoreRAIDServer [44]
Path: /System/Library/PrivateFrameworks/CoreRAID.framework/Resources/CoreRAIDServer
ADDRESS BINARY
00001000 /System/Library/PrivateFrameworks/CoreRAID.framework/Resources/CoreRAIDServer
0000f000 /System/Library/Extensions/AppleRAIDCard.kext/Contents/PlugIns/AppleRAIDCardLib.plugin/Contents/MacOS/AppleRAIDCardLib
00043000 /System/Library/PrivateFrameworks/CoreRAID.framework/Versions/A/CoreRAID
00200000 /System/Library/PrivateFrameworks/CoreRAID.framework/PlugIns/AppleRAIDCard.crplugin/Contents/MacOS/AppleRAIDCard
Thread id: 14d1c410
User stack:
45 ??? [0x1fca]
45 _CRServerMain + 2637 (in CoreRAID) [0x66ae3]
Thread id: 14e747d8
User stack:
45 _CRThreadMain + 224 (in CoreRAID) [0x67732]
2 _CFRunLoopRunSpecific + 3166 (in CoreFoundation) [0x918e662e]
2 _CRSignalPortPerform + 335 (in CoreRAID) [0x48c29]
2 _AppleRAIDCardPlugInCopyAttachedDisks + 518 (in AppleRAIDCard) [0x209762]
1 _AppleRAIDCardPlugInCopyAttachedDisks + 64 (in AppleRAIDCard) [0x20959c]
1 _RegistryUpdateCreate + 289 (in AppleRAIDCard) [0x229221]
1 _CRALGetDriveInfo + 89 (in AppleRAIDCard) [0x218a05]
1 __ZN6tsalif25soap_call_tsal__getDrivesEP4soapPKcS3_RNS_16tsal__DrivesRespE + 272 (in AppleRAIDCard) [0x2ddfba]
1 _soap_envelope_end_out + 42 (in AppleRAIDCard) [0x236212]
1 _soap_element_end_out + 120 (in AppleRAIDCard) [0x236196]
1 _soap_flush_raw + 300 (in AppleRAIDCard) [0x2356a6]
1 _SoapTest_fsend + 193 (in AppleRAIDCard) [0x214c9f]
1 __ZN19AppleRAIDCardDevice8SOAPCallEPK8__CFDataPS2_Pt + 231 (in AppleRAIDCardLib) [0x106ef]
1 _IOConnectCallScalarMethod + 84 (in IOKit) [0x91de9218]
1 _IOConnectCallMethod + 300 (in IOKit) [0x91de8f66]
1 _mach_msg_trap + 10 (in libSystem.B.dylib) [0x9352b9e6]
1 _AppleRAIDCardPlugInCopyAttachedDisks + 201 (in AppleRAIDCard) [0x209625]
1 _RegistryUpdateHosts + 90 (in AppleRAIDCard) [0x228c86]
1 _CopyLunMap + 99 (in AppleRAIDCard) [0x2f96ab]
1 _IOServiceGetMatchingServices + 161 (in IOKit) [0x91dea1f7]
Kernel stack:
2 _mach_msg_overwrite_trap + 752 [0x12625d]
2 _ipc_kobject_server + 247 [0x12d17b]
1 _iokit_server_routine + 20111 [0x18d825]
1 _is_io_connect_method + 468 [0x43a38a]
1 com.apple.driver.AppleRAIDCard (49) + 24453 [0xc9bf85]
1 com.apple.driver.AppleRAIDCard (49) + 24245 [0xc9beb5]
1 com.apple.driver.AppleRAIDCard (49) + 51498 [0xca292a]
1 com.apple.driver.AppleRAIDCard (49) + 28916 [0xc9d0f4]
1 _IORecursiveLockSleep + 67 [0x403e7b]
1 _lck_mtx_sleep + 87 [0x130a1e]
1 _iokit_server_routine + 535 [0x188bad]
1 _is_io_service_get_matching_services + 82 [0x438ed4]
1 __ZN9IOService19getMatchingServicesEP12OSDictionary + 47 [0x40d7fb]
1 __ZN9IOService19getExistingServicesEP12OSDictionarymm + 360 [0x40d648]
1 __ZN12OSOrderedSet9setObjectEPK15OSMetaClassBase + 27 [0x3ef507]
Process: DirectoryService [11]
Path: /usr/sbin/DirectoryService
ADDRESS BINARY
00001000 /usr/sbin/DirectoryService
0015a000 /System/Library/PrivateFrameworks/DirectoryServiceCore.framework/Versions/A/DirectoryServiceCore
Thread id: 1424c410
User stack:
45 start + 54 (in DirectoryService) [0x165ca]
45 _main + 2569 (in DirectoryService) [0x16ff1]
Thread id: 14249a78
User stack:
45 __ZN9DSLThread11_RunWrapperEPv + 84 (in DirectoryServiceCore) [0x162196]
45 __ZN9DSCThread3RunEv + 39 (in DirectoryServiceCore) [0x161f8b]
45 __ZN20CPluginRunLoopThread10ThreadMainEv + 222 (in DirectoryService) [0x23126]
Thread id: 14248f20
User stack:
45 __ZN17CMigHandlerThread10ThreadMainEv + 303 (in DirectoryService) [0x2335f]
Kernel stack:
45 _dtrace_get_cpu_int_stack_top + 543 [0x1972ea]
45 _mach_msg_overwrite_trap + 3771 [0x126e28]
45 _ipc_mqueue_receive + 750 [0x120eb0]
45 _thread_block + 33 [0x1369fb]
45 _thread_continue + 1181 [0x13678e]
Thread id: 148548b8
User stack:
45 ___kevent + 10 (in libSystem.B.dylib) [0x9355c4c6]
Thread id: 148513c8
User stack:
1 _thread_start + 34 (in libSystem.B.dylib) [0x9355cb12]
1 __pthread_start + 321 (in libSystem.B.dylib) [0x9355cc55]
1 __ZN9DSLThread11_RunWrapperEPv + 84 (in DirectoryServiceCore) [0x162196]
1 _syscall + 5 (in libSystem.B.dylib) [0x9356e725]
Thread id: 15986410
User stack:
44 _thread_start + 34 (in libSystem.B.dylib) [0x9355cb12]
44 __pthread_start + 321 (in libSystem.B.dylib) [0x9355cc55]
44 __ZN9DSLThread11_RunWrapperEPv + 84 (in DirectoryServiceCore) [0x162196]
44 _syscall + 5 (in libSystem.B.dylib) [0x9356e725]
Process: Dock [122]
Path: /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
ADDRESS BINARY
00001000 /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
00400000 /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
Thread id: 1520f208
User stack:
45 ??? [0x5472]
45 ??? [0x95c85]
45 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 213 (in Foundation) [0x93713b15]
31 _mach_msg_trap + 10 (in libSystem.B.dylib) [0x9352b9e6]
14 _CFRunLoopRunSpecific + 4494 (in CoreFoundation) [0x918e6b5e]
14 ??? [0x282e8]
14 ??? [0x11ad1]
14 ??? [0x2386a]
14 __HandlePopUpMenuSelection2 + 111 (in HIToolbox) [0x91706c55]
14 __HandlePopUpMenuSelection5 + 120 (in HIToolbox) [0x916cd11a]
14 __HandlePopUpMenuSelection7 + 627 (in HIToolbox) [0x91639805]
14 __Z19PopUpMenuSelectCoreP8MenuData5PointdS1_tjPK4RecttmS4_S4_PK10__CFStringPP13OpaqueMenuRefPt + 1845 (in HIToolbox) [0x91639f8d]
12 __Z15TrackMenuCommonR14MenuSelectDataPh + 3846 (in HIToolbox) [0x915cb726]
12 __Z19IsUserStillTrackingP14MenuSelectDataPh + 493 (in HIToolbox) [0x915e2527]
11 _ReceiveNextEventCommon + 374 (in HIToolbox) [0x9159b4b9]
11 _RunCurrentEventLoopInMode + 283 (in HIToolbox) [0x9159b6a0]
11 _CFRunLoopRunInMode + 88 (in CoreFoundation) [0x918e6d18]
11 _mach_msg_trap + 10 (in libSystem.B.dylib) [0x9352b9e6]
1 _ReceiveNextEventCommon + 175 (in HIToolbox) [0x9159b3f2]
1 _CFRunLoopRunSpecific + 656 (in CoreFoundation) [0x918e5c60]
1 ___CFRunLoopDoObservers + 466 (in CoreFoundation) [0x918e49c2]
1 _CATransactionCommit + 219 (in QuartzCore) [0x9516ed77]
1 _CAContextCommitTransaction + 955 (in QuartzCore) [0x9516f37f]
1 __Z15TrackMenuCommonR14MenuSelectDataPh + 4582 (in HIToolbox) [0x915cba06]
1 __Z13FlashFeedbackP14MenuSelectData + 154 (in HIToolbox) [0x915e8372]
1 __ZN6HIView13SimulateClickEsmPs + 225 (in HIToolbox) [0x915e852f]
1 _SendEventToEventTargetWithOptions + 58 (in HIToolbox) [0x91572262]
1 __Z30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCallRec + 405 (in HIToolbox) [0x915723fd]
1 __Z23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1181 (in HIToolbox) [0x91572fc3]
1 __ZN6HIView12EventHandlerEP25OpaqueEventHandlerCallRefP14OpaqueEventRefPv + 1954 (in HIToolbox) [0x91581514]
1 __ZN6HIView17SimulateClickSelfEsmPs + 41 (in HIToolbox) [0x915e8623]
1 __Z22SendControlSimulateHitP6HIViewsmPs + 199 (in HIToolbox) [0x915e8787]
1 __ZN6HIView12EventHandlerEP25OpaqueEventHandlerCallRefP14OpaqueEventRefPv + 2185 (in HIToolbox) [0x915815fb]
1 __ZN18HIStandardMenuView15SimulateHitSelfEsmPs + 181 (in HIToolbox) [0x915e889b]
1 __ZN10HIMenuView15SimulateHitSelfEsmPs + 194 (in HIToolbox) [0x915e89a0]
1 __Z15TrackMenuCommonR14MenuSelectDataPh + 5008 (in HIToolbox) [0x915cbbb0]
Kernel stack:
1 _mach_msg_overwrite_trap + 4455 [0x1270d4]
1 _ipc_kmsg_send + 278 [0x120184]
1 _ipc_mqueue_send + 418 [0x120bb8]
1 _ml_set_interrupts_enabled + 47 [0x1a2389]
Thread id: 152108b8
User stack:
43 ??? [0x12d8a]
43 ___semwait_signal + 10 (in libSystem.B.dylib) [0x93532bce]
2 _clock_sleep_trap + 10 (in libSystem.B.dylib) [0x9352baee]
Kernel stack:
2 _clock_sleep_trap + 426 [0x12a70d]
2 _thread_continue + 1181 [0x13678e]
Process: Finder [124]
Path: /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
ADDRESS BINARY
00001000 /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
004e4000 /System/Library/Frameworks/Collaboration.framework/Versions/A/Collaboration
0060a000 /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
12233000 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
15cde000 /System/Library/PrivateFrameworks/URLMount.framework/URLMount
15ef1000 /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
Thread id: 1520e6b0
User stack:
45 ??? [0x94e6]
45 ??? [0xf37d9]
45 ??? [0x23605]
45 _RunApplicationEventLoop + 207 (in HIToolbox) [0x915f895b]
45 __AcquireNextEvent + 58 (in HIToolbox) [0x915fa1fe]
44 _ReceiveNextEventCommon + 374 (in HIToolbox) [0x9159b4b9]
44 _RunCurrentEventLoopInMode + 283 (in HIToolbox) [0x9159b6a0]
44 _CFRunLoopRunInMode + 88 (in CoreFoundation) [0x918e6d18]
44 _mach_msg_trap + 10 (in libSystem.B.dylib) [0x9352b9e6]
1 _CFRunLoopRunSpecific + 546 (in CoreFoundation) [0x918e5bf2]
1 __Z15FlushAllBuffersP19__CFRunLoopObservermPv + 168 (in HIToolbox) [0x9159cd7e]
1 __Z17FlushWindowObjectP10WindowDataPPvh + 749 (in HIToolbox) [0x9159d367]
1 __ZN6HIView6RenderEmP9CGContext + 45 (in HIToolbox) [0x9159486b]
1 __ZN6HIView4DrawEsP13OpaqueGrafPtrm + 83 (in HIToolbox) [0x9159491b]
1 __ZN6HIView14DrawCompositedEsP13OpaqueGrafPtrPK9__HIShapemPS_P9CGContext + 668 (in HIToolbox) [0x91594c08]
1 __ZN6HIView23RecursiveDrawCompositedEPK9__HIShapemPS_P9CGContexthf + 1090 (in HIToolbox) [0x9159596e]
1 __ZN6HIView23RecursiveDrawCompositedEPK9__HIShapemPS_P9CGContexthf + 734 (in HIToolbox) [0x9159580a]
1 __ZN6HIView8SendDrawEsP13OpaqueGrafPtrPK9__HIShapeP9CGContext + 475 (in HIToolbox) [0x91595d1d]
1 ??? [0x261ba]
1 ??? [0x261f6]
1 ??? [0x26376]
1 ??? [0x31537]
1 ??? [0x2b05c]
1 ??? [0x45ff8]
1 ??? [0x469d9]
1 ??? [0x49836]
1 ??? [0x49905]
1 ??? [0x49ad9]
1 ??? [0x4a0d1]
1 ??? [0x18a4c4]
1 ??? [0x4b2ea]
1 _CGContextRestoreGState + 71 (in CoreGraphics) [0x90450074]
1 _CGGStackRestore + 124 (in CoreGraphics) [0x904500fb]
1 _CGGStateRelease + 47 (in CoreGraphics) [0x9045013c]
1 _renderingStateRelease + 52 (in CoreGraphics) [0x90450208]
1 _szone_free + 732 (in libSystem.B.dylib) [0x93531e56]
Kernel stack:
1 _PE_incoming_interrupt + 131 [0x446f38]
1 _lapic_interrupt + 300 [0x1af78e]
1 _sync_iss_to_iks + 114 [0x1a7f5e]
Thread id: 14d18f20
User stack:
45 _PrivateMPEntryPoint + 56 (in CarbonCore) [0x92302beb]
45 __ZN23TSystemNotificationTask26SystemNotificationTaskProcEPv + 123 (in DesktopServicesPriv) [0x9550146f]
Thread id: 15359d60
User stack:
45 __ZN25TFSEventsNotificationTask28FSEventsNotificationTaskProcEPv + 216 (in DesktopServicesPriv) [0x955015e8]
Thread id: 153595d0
User stack:
45 __ZN13TNodeSyncTask12SyncTaskProcEPv + 84 (in DesktopServicesPriv) [0x9550ca7a]
45 _MPWaitOnQueue + 208 (in CarbonCore) [0x92304654]
45 _TSWaitOnConditionTimedRelative + 202 (in CarbonCore) [0x922e38fe]
45 _TSWaitOnCondition + 126 (in CarbonCore) [0x923049d7]
45 ___semwait_signal + 10 (in libSystem.B.dylib) [0x93532bce]
Thread id: 15358a78
User stack:
Thread id: 153582e8
User stack:
45 _select$DARWIN_EXTSN + 10 (in libSystem.B.dylib) [0x9357bb3a]
Thread id: 1479a3c8
User stack:
45 __ZN15TFolderSizeTask18FolderSizeTaskProcEPv + 104 (in DesktopServicesPriv) [0x9550e9c4]
45 _TSWaitOnConditionTimedRelative + 246 (in CarbonCore) [0x922e392a]
45 _semaphore_timedwait_signal_trap + 10 (in libSystem.B.dylib) [0x9352ba46]
Thread id: 27eb1998
User stack:
45 ??? [0x9d22]
45 ??? [0xdd40c]
45 ??? [0xe079d]
45 ??? [0x49f41]
Process: KernelEventAgent [35]
Path: /usr/sbin/KernelEventAgent
ADDRESS BINARY
00001000 /usr/sbin/KernelEventAgent
Thread id: 148522e8
User stack:
45 start + 54 (in KernelEventAgent) [0x1bfe]
45 _main + 1126 (in KernelEventAgent) [0x3b7f]
Thread id: 14d19e40
User stack:
Process: MIDIServer [566]
Path: /System/Library/Frameworks/CoreMIDIServer.framework/MIDIServer
ADDRESS BINARY
00001000 /System/Library/Frameworks/CoreMIDIServer.framework/MIDIServer
00012000 /System/Library/Extensions/AppleMIDIFWDriver.plugin/Contents/MacOS/AppleMIDIFWDriver
00025000 /System/Library/Frameworks/FWAUserLib.framework/Versions/A/FWAUserLib
0005c000 /System/Library/Frameworks/CoreMIDIServer.framework/Versions/A/CoreMIDIServer
000b8000 /System/Library/Extensions/AppleMIDIIACDriver.plugin/Contents/MacOS/AppleMIDIIACDriver
000bf000 /System/Library/Extensions/AppleMIDIRTPDriver.plugin/Contents/MacOS/AppleMIDIRTPDriver
000dc000 /System/Library/Extensions/AppleMIDIUSBDriver.plugin/Contents/MacOS/AppleMIDIUSBDriver
000eb000 /Library/Audio/MIDI Drivers/EmagicUSBMIDIDriver.plugin/Contents/MacOS/EmagicUSBMIDIDriver
00300000 /Library/Audio/MIDI Drivers/Fireface MIDI.plugin/Contents/MacOS/Fireface MIDI
0030b000 /Library/Audio/MIDI Drivers/Motu MIDI Driver.plugin/Contents/MacOS/Motu MIDI Driver
00365000 /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
Thread id: 15982000
User stack:
43 ??? [0x1f5e]
43 ??? [0x1fb1]
43 _MIDIServerRun + 975 (in CoreMIDIServer) [0x76dc9]
43 _CFRunLoopRun + 84 (in CoreFoundation) [0x918e6d74]
Thread id: 155c68b8
User stack:
43 __ZN9CAPThread5EntryEPS_ + 96 (in CoreMIDIServer) [0x7d61c]
43 __ZN7XThread9RunHelperEPv + 17 (in CoreMIDIServer) [0x6e57d]
43 __ZN12TimerTaskMgr3RunEv + 378 (in CoreMIDIServer) [0x7dc7c]
43 __ZN7CAGuard4WaitEv + 93 (in CoreMIDIServer) [0x7cfd7]
Thread id: 27eb3048
User stack:
43 __ZN14DriverIOThread3RunEv + 82 (in CoreMIDIServer) [0x6d276]
Thread id: 156a5000
User stack:
43 _ListenForData + 17 (in Fireface MIDI) [0x304281]
43 __ZN18FirefaceMIDIDevice6ThreadEv + 117 (in Fireface MIDI) [0x3041fd]
Thread id: 14d1bc80
User stack:
43 __ZN12MIDIIOThread3RunEv + 109 (in CoreMIDIServer) [0x7756b]
Kernel stack:
Process: Spotlight [108]
Path: /System/Library/CoreServices/Spotlight.app/Contents/MacOS/Spotlight
ADDRESS BINARY
00001000 /System/Library/CoreServices/Spotlight.app/Contents/MacOS/Spotlight
00057000 /System/Library/PrivateFrameworks/Calculate.framework/Versions/A/Calculate
00068000 /System/Library/PrivateFrameworks/URLMount.framework/Versions/A/URLMount
000d6000 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0030d000 /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
Thread id: 1520f998
User stack:
45 ??? [0x2a82]
Thread id: 15357000
User stack:
45 _fe_fragment_thread + 54 (in QuartzCore) [0x9521e121]
Thread id: 155c5998
User stack:
Thread id: 155c55d0
User stack:
Thread id: 155c5208
User stack:
Thread id: 155c4e40
User stack:
Thread id: 155c4a78
User stack:
Thread id: 155c46b0
User stack:
Process: SyncServer [592]
Path: /System/Library/Frameworks/SyncServices.framework/Versions/Current/Resources/SyncServer.app/Contents/MacOS/SyncServer
ADDRESS BINARY
00001000 /System/Library/Frameworks/SyncServices.framework/Versions/Current/Resources/SyncServer.app/Contents/MacOS/SyncServer
Thread id: 156a7208
User stack:
45 ??? [0x2366]
45 ??? [0x3d1d]
45 -[NSRunLoop(NSRunLoop) run] + 84 (in Foundation) [0x9371fc34]
Thread id: 27f1c7d8
User stack:
Process: SystemStarter [29]
Path: /sbin/SystemStarter
ADDRESS BINARY
00001000 /sbin/SystemStarter
Thread id: 1424b128
User stack:
Process: SystemUIServer [123]
Path: /System/Library/CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer
ADDRESS BINARY
00001000 /System/Library/CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer
00069000 /System/Library/PrivateFrameworks/SystemUIPlugin.framework/Versions/A/SystemUIPlugin
00077000 /System/Library/PrivateFrameworks/NetworkConfig.framework/Versions/A/NetworkConfig
000cb000 /System/Library/PrivateFrameworks/ICANotifications.framework/Versions/A/ICANotifications
000f5000 /System/Library/PrivateFrameworks/iPod.framework/Versions/A/iPod
00100000 /System/Library/PrivateFrameworks/BezelServices.framework/Versions/A/BezelServices
0010a000 /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0023e000 /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0039c000 /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
003d4000 /System/Library/Frameworks/AppleTalk.framework/Versions/A/AppleTalk
003e5000 /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0042c000 /usr/lib/libcurl.4.dylib
00482000 /Applications/iCal.app/Contents/Resources/iCalDockExtra.bundle/Contents/MacOS/iCalDockExtra
00493000 /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
004a4000 /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0073e000 /System/Library/CoreServices/Menu Extras/Displays.menu/Contents/MacOS/Displays
00757000 /System/Library/CoreServices/Menu Extras/AirPort.menu/Contents/MacOS/AirPort
00773000 /System/Library/CoreServices/Menu Extras/Bluetooth.menu/Contents/MacOS/Bluetooth
00787000 /System/Library/Frameworks/IOBluetoothUI.framework/Versions/A/IOBluetoothUI
007c8000 /System/Library/CoreServices/Menu Extras/Eject.menu/Contents/MacOS/Eject
11ef0000 /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
12010000 /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
120ca000 /System/Library/CoreServices/Menu Extras/TimeMachine.menu/Contents/MacOS/TimeMachine
120e2000 /System/Library/CoreServices/Menu Extras/UniversalAccess.menu/Contents/MacOS/UniversalAccess
120f3000 /System/Library/CoreServices/Menu Extras/RemoteDesktop.menu/Contents/MacOS/RemoteDesktop
12105000 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreG
Post
by Shooshie » Mon Apr 28, 2008 9:37 pm
After carefully reading every line of your code, I finally came to the conclusion that your problem is right here:
Code: Select all
Architecture: i386
Report Version: 4
PID: 565
Event: hang
Time: 6.85s
Steps: 45
Which is to say that this describes the problem, but I have no idea how to fix it. The rest of the log that you posted is stuff I recognize as the boot log for DP. Sorry I can't be of help. I really don't know what could be causing the problem. Can you give us any clues as to behaviors before, during or after?
Timeline
Post
by Timeline » Mon Apr 28, 2008 10:17 pm
Thanks Shooshie. Well to be honest, it's 80% there compared to the machine I had with a bad CPU. They even replaced the raid card with the next best version they had. So... Looks like I'll just live with it and be careful continuing to save allot. Nothin new there.
I looked at the 8 cores in monitor during PB and wow, they look great. Data seems dispersed across all eight evenly.
I also notice that because I have the airport card option it was left on and looked like data was coming in and going out. I turned off all of that and disabled everything I could that might take attention away from audio.
So far it's ok and the late hour overheating is gone. it seems to run cool and stable now.
I think because of the VI's running here with several instances of each one I'm putting a bit of pressure on the SAS drives though.
On the G5 with the REAL scsi's, they could take everything I could throw at em which is a lesson learned here for future expansion.
I'll keep goin here. Thanks...
Post
by Shooshie » Tue Apr 29, 2008 1:55 am
Timeline wrote: Thanks Shooshie. Well to be honest, it's 80% there compared to the machine I had with a bad CPU. They even replaced the raid card with the next best version they had. So... Looks like I'll just live with it and be careful continuing to save allot. Nothin new there.
What are SAS drives? (darned those acronyms!
) Is that something I've missed, or are you referring to Serial ATA drives? Took me a couple of minutes to remember ATA, myself, so if that's what you meant by SAS, no biggie. But if it's something I don't know, then I need to know it!
leigh
Post
by leigh » Tue Apr 29, 2008 6:39 am
I think SAS is Serial Access SCSI.
So does SAS constitute a meta-acronym?
**Leigh
