CAN LOOPLAB SLICES FOLLOW HOST TEMPO?
rahquee
Post by rahquee »
good question.
if you have a 4 bar loop and you slice it up and turn the speed down from say 100 bpm to 60 bpm will the slices follow th tempo without changing the key?
i need to find out b4 i take the plunge :wink:
meeloo
Post by meeloo »
Of course it can! That's the whole point of using the looplab...
rahquee
Post by rahquee »
can i adjust the slce points after i map the slices over the keys?
meeloo
Post by meeloo »
You can go back and forth in between the normal sliced loop mode and the keymapped mode to adjust the slices to your liking. You can also ask machfive 2 to create a program with the mapped version where each key will contains a sliced sample so that you can treat each slice as a normal sample (but you can't go back to the looplab once you have created such a program)
Cheers
halcyo
Post by halcyo »
Can these loops then be exported as Rex files for me to load up in Stylus RMX!? That would be way too cool!
I really might have to look into Machfive II!
halcyo
carrythebanner
Post by carrythebanner »
halcyo wrote:Can these loops then be exported as Rex files for me to load up in Stylus RMX!?
No, MachFive doesn't export as REX files. I'm pretty sure that ReCycle is the only program that actually exports REX files.
RCory
Post by RCory »
Yes - Recycle is the only app that can save a REX file
rahquee
Post by rahquee »
you can't go back to the looplab once you have created such a program!!!!
that suks because i have a mpk49 and i like auditioning my chops "live" with the pads........then i might change my mind.......then what? do i scrap the whole program and have to re-chop (manualy adjusting)! whats the work araound.
rahquee
Post by rahquee »
ANYBOBODY?
Sarcazm
Post by Sarcazm »
rahquee wrote:you can't go back to the looplab once you have created such a program!!!!
It doesn't write over the looplab preset, it saves a different one. You can still open the looplab preset then resave as separate samples if you wish. Of course, if you have extensive mods to the individual samples (filtering, lfoing, effects and the like) you'll want to:
A) have a looplab version
B) have a individual sample version with mods set
Then if you change the slices in A, save a new indi sample version (C). Open up B and overwrite the old samples with the samples from C. Bit convoluted but it does retain the mod settings.
C) have a dummy individual version, then import the samples into
rahquee
Post by rahquee »
you sir or madame.........are a great inspiration!
ill try it out inna few days imm tryin to reach 500 to get my apogee duet!
one.
rahquee
Post by rahquee »
whoops forgot to post an update cause i been in bliss with my new duet card!!
yeah i think its a sound "workaround" and i will also explore my redmtica keymap with the exs24 and see who has the best flow!
thanx
one
bobbybland
Re: CAN LOOPLAB SLICES FOLLOW HOST TEMPO?
Post by bobbybland »
Hi,
Once you create a program of a sliced loop and map to keys,is there anyway that you can adjust the start and end points of each sample on any given key,or would you have to enter back into looplab to do that?
Thanks.
carrythebanner
bobbybland wrote:Once you create a program of a sliced loop and map to keys,is there anyway that you can adjust the start and end points of each sample on any given key,or would you have to enter back into looplab to do that?
Once you've created that program, the samples are independent, "normal" sample files, so you could move their sample start/end points inward, but not outward beyond the bounds of the file.
bobbybland
Nice.. I see thanks so much for the quick response.
