Spectrasonics and Leopard on PPC Mac: is it possible?
daveyboy
Post by daveyboy »
Just updated my system and can't load Atmosphere or Trilogy (Stylus RMX works) in DP 5.13. I've scanned them and authorized them no problem but when I actually try to load one in a sequence I get the beach ball and have to force quit. Do these actually work on Leopard on a G5? I know that on intel you need their wrapper. Thanks.
Update: Left a message at Spectrasonics in which they called back and left a message saying that "they've heard that it doesn't work on Leopard and you should revert back to Tiger...". Bummer.
Dave
www.dbwproductions.com
melenko
Re: Spectrasonics and Leopard on PPC Mac: is it possible?
Post by melenko »
daveyboy wrote:Just updated my system and can't load Atmosphere or
Do they mean , by that, Stymus RMX is not Leopard compatible...??!!! :evil:
daveyboy
Post by daveyboy »
Incorrect, RMX does work, just not Trilogy or Atmosphere. I'm still hoping I'm wrong though and someone here can tell me how to get it working. :shock:
Dave
David Polich
Post by David Polich »
Trilogy and Atmosphere require a "public beta" wrapper to work on an Intel Mac, however, it is unclear whether it works with Leopard on an Intel Mac. I would say it doesn't at this point. For more info, visit their website:
http://www.spectrasonics.net
There still are some plugs that don't work with Leopard, Spectrasonics aren't the only ones that don't.
rikp
Post by rikp »
David Polich wrote:Trilogy and Atmosphere require a "public beta" wrapper to work on an Intel Mac, however, it is unclear whether it works with Leopard on an Intel Mac. I would say it doesn't at this point. For more info, visit their website:
That is why I have not upgraded to Leopard. I love Trilogy and Atmosphere and want to keep using them! From what I understand, Atmosphere will now be part of Omnisphere and there is a new version of Trilogy in the works that uses the new STEAM engine.
Peace
rp
http://www.coffeecupmusic.com
Mac Pro 8 Core 22 Gig RAM, 2 Hackintoshes, DP 8, ProTools 11, Logic X, Waves, Kontakt, Vienna Strings, EWQL Platinum, GPO, BFD, Omnishphere, Stylus RMX, Trilogy, Altiverb, DrumCore, EZ Drummer, LASS, HollyWoodwinds, and too much money spent on VI libraries.
daveyboy
Post by daveyboy »
Peace
rp
So it is confirmed then that the wrapper doesn't work on Intel in Leopard, only Tiger?? Thanks for clarifying this.
Dave
rikp
Post by rikp »
Peace
rp
I don't know about "confirmed" but I have not heard too many good things about the wrapper. If you can avoid it, you will be better off! Trilogy is my go-to bass plug, so I want to make sure that the problem is solved before I move to Leopard or an Intel Mac. I have always felt that it is better to be creating music than working on the bleeding edge of technology. I am staying put with Tiger and my PPC Quad G5!
Peace
rp
daveyboy
Post by daveyboy »
Update: I was hoping to talk to someone who was successfully using these things on Intel using the wrapper system. Then, it dawned on me try it myself on my macbook pro (duh)! I don't use this mac for any music but I do have DP 5.13 installed and I am using OSX.5.2 . So, I installed Atmosphere along with the wrapper as per their directions and just in dabbling around I've found that it does in deed work! There are limitations as discussed on Spectrasonic's site. Can't load old projects, can't save settings etc. You'll just have to freeze stuff on the old machine and "start over" on the new one. And, I would continue to freeze stuff on the new setup as well. I was debating for a second on getting a used G5 quad as an upgrade but I think moving up to intel would be the way to go seeing how it is the current standard.
Dave
misty
Post by misty »
Working with the wrapper is a test of patience, but it does work with Leopard. Yes, you cannot open old projects with the wrapper but new ones started will be ok.
It took me a couple of tries to get it going, but so far so good... just be careful and follow the directions from Spectrasonics and all will be good.
mi
8 core, g5dual2, alum, dp6.01, 2408mkII, rmeFF800, traveler, 828x2, d8b.. more stuff at home
melenko
Post by melenko »
rikp wrote: and there is a new version of Trilogy in the works that uses the new STEAM engine.
Peace
rp
Where did you got that info, please?
bralston
Post by bralston »
Peace
rp
Spectrasonics was basically saying that at the NAMM show. The STEAM engine is the foundation for which all their future libraries will be based. Omnisphere (The atmosphere replacement) just happened to be the first out the gate with a release this coming fall...but they said that the eventual Trilogy replacement (What ever that will be called) and all future libraries will be STEAM engine based.
Regards,
Brian Ralston
___________________________________
- MacPro 7,1 3.2 GHz 16-core Intel Xeon W, 384GB 2933MHz DDR4 RAM, OS 10.15.7, 2TB SSD OS drive, 6TB Samsung Pro EVOPlus SSDs via Sonnet 4x4 M.2 PCIe card, Graphics card: AMD Radeon Pro Vega II 32GB, UAD-2 Quad, DP 10.13, DP 11.0,
- 15" MacBook Pro 2.3GHz 8‑core 9th‑generation Intel Core i9 processor, Turbo Boost to 4.8GHz, 32GB 2400MHz DDR4 mem, Radeon Pro Vega 20 w/4GB HBM2 mem, 2TB SSD storage, OS 10.15.7, 2TB SSD, DP 10.13
daveyboy
Post by daveyboy »
Cause I'm slightly insane I've decided to stay in Leopard and use VST wrapper to run Atmosphere and Trilogy. DP just seems to run better in Leopard. I'll just have to make sure I freeze those vi tracks that's all.
Dave
melenko
Post by melenko »
bralston wrote:
melenko wrote:
rikp wrote: but they said that the eventual Trilogy replacement (What ever that will be called) and all future libraries will be STEAM engine based.
"Eventual..." makes me suspicious.
melenko
Post by melenko »
hammerman
Post by hammerman »
OK, I'm confused here. I thought the wrappers were for Intel Macs and have nothing to do with Leopard running on Power PC's? I'm on a G5 so I'm wary but I guess I'll email them and see what they say.
