what does error ID = -199 mean?
"An error occurred while reading from the disk. The file was not loaded."
DP crashed on exit while last saving the project, now it won't open. Other projects still open normally, though. It looks like the app is ok.
- kassonica
this is a site i have saved. A great resource
http://www.cs.cmu.edu/~lenzo/mac_errors.html
error -199 mapReadErr: map inconsistent with operation
does this mean that the error IDs are MacOS-specific, not DP-specific?kassonica wrote:this is a site i have saved. A great resource
tried removing both the audio and analysis files, but it still wouldn't open. Copied the folder to a different drive, also no luck. Looks like the DP document is corrupted.dweiss wrote:You may have a corrupted audio file. Remove all the audio files from their folder and try starting the project without them. If it opens the task then will be to figure out which file is bad.
i was saving often, but i hadn't backed this one up for a week or so. lost a great deal of editing, arranging and drum performances.
thanx for your replies!
cheers
- Shooshie
Don't throw it away. Wait for DP6 and see if it will open it. That's happened before. A corrupted file would not open, but a later version opened it. I wouldn't put a lot of stock in that possibility, but... just for kicks, it's worth a try.
Success!! File recovered!!
tried opening it with DP in "MIDI only" mode, but that didn't work either (clever idea, though).96khz wrote:And try to create a new project and use the "Load" command to import the sequence from the "probably corrupt" file. Sometimes the sequence information can be recovered. It happened to me a few times. Give it a shot!
i made a New project, then successfully "Loaded" the sequence i wanted with all the new edits, and everything was right there, pretty much intact. (only the track i/o's and colors were different).
thanks a million, guys--
