hi ,
i know the motu ultralite is has many outputs and so i was woundering if it was possible to connect a pair of krk v8s and a v12 sub to the ultralite?
and can i also connect 2 pair of monitors so i can switch between them to check the mixdowns and also connect a sub to it bareing in mind it has many outputs?
thanks.
few newbie questionsa about motu ultralite?
- Pappy725
You get 8 analog outs plus the Main Outs (which have a front panel control), you would have to set up the 2.1 in your audio software to have the 2 sets of monitors and the sub. Of course, you could use the Main Outs for one of the sets of monitors.
Take a look:
http://www.motu.com/products/motuaudio/ ... rview.html
Stephen
Take a look:
Stephen
- Pappy725
That sounds right to me. Bound to be some way to set up the routing in your software so you only have to mute one bus or aux
Stephen.
Stephen.
