The free VI's/plugs list.
blazingrythm
Side Chain?
Post by blazingrythm »
Can't anyone here tell me what side chain means
as in side chain compressor?
No one has replied to my previous post.
Macbook Pro 10.6.8, 16 GB DDR SDRAM, 828mkII, DP 8.05
Played drums for Capt. Beefheart and the Magic Band, The Stranglers, Hugh Cornwell, George Sarah, John Lydon, Robbie Krieger, Johnny Guitar Watson, Peewee Crayton, Dr. John, Tex & the Horseheads, Parthenon Huxley, The Magic Band, Tomoyatsu Hotei, George Clinton, Bone Symphony, Bo Donaldson & the Heywoods, with two solo albums on A&M Records in 1980 and 1982, & one in 1998 on Tonecasualties Records.
chadd
Post by chadd »
Sidechain refers to using one signal to trigger processing on another one. A common example would be busing the kick drum signal to the key input of a compressor on a bass guitar track. That way, the bass guitar volume is lowered by the compressor whenever there is a hit on the kick drum. Another common one is setting up a de-esser by busing a copy of the vocal signal through an EQ to cut all frequencies except the sibilance, then sending that EQ'ed signal to the key input of a dynamic processor on the vocal track.
2022 Mac Studio, 32GB RAM, OS 12.6, DP 11.2, Metric Halo LIO-8/4p, micro lite, EWQLSO Gold, Waves Gold, Komplete 6, Stylus RMX, Slate VCC & VTM
blazingrythm
Chain on the side
Thank you for that very informative reply.
It goes to show I have a lot more to learn about engineering.
I rarely use sends because I found it complicated years ago
and never bothered with it as a result. I'm sure it's much easier than I think it is but I developed a psychological block to approaching it.
Silly nilly willy old bear.
I uusually only use inserts for each individual track.
It piles up the CPU with plugins like Altiverb and Guitar Rig.
I'm a lazy bastard with engineering but I'm going to have to get off my butt and start figuring some of these things out.
In the meantime, I just get the best sound I can on a track and bounce it to clear out the plugins but keep the original in case it doesn't sit right in the track.
After mixing I throw on the Waves L13 multi maximiser (or whatever it's called) and pump it up with "enhance 2" and it kicks the whole mix up to
'hype level.'
I have editting down pretty well but I realy need to learn that time adjustment thingy again where you can adjust the tempo of an audio track(s) like 8 drum tracks to fit in with the song or vise versa.
I usually use strip silence for kicks and snares and quantize them with some adjustments to the length of the separated soundbites and then use fades to get rid of the digital clicks.
BTW
How do I get rid of those annoying pop up windows when the cursor goes over the pan, volume etc. knobs?
I know it's a pan knob when I'm usiing it but the pop ups block my vision of the actual knob when I'm trying to adjust it.
Thanks again!
I LOVE THIS FORUM!!!!
PS OT: I almost installed Leopard on my main hard drive but after reading about it here decided to wait because I love my plugins and DP5 is running pretty damned smoothly at the moment. I'll buy another external drive to put it on soon and try it out.
HeadMaster
Re: Side Chain?
Post by HeadMaster »
blazingrythm wrote:Can't anyone here tell me what side chain means
There are two things here that can easily be mistaken
- Side chain filter
- External side chain
Side chain filter, is when there is more or a less an EQ, often a selection of pre-defined curves, that is used "in behind" on the current material fed to the plug-in and used to provide frequency-selective compression.
External side chain, is when you have the possibility to feed another audio stream to the compressor, and with that stream, affect the compression pretty much as with the side chain filter.
HM
Macbook 2.16
OS-X 10.4.11
DP 5.13
Volentary promotion for free stuff (UB) that you just have to have
Linplug: Alpha Free
Big Tick: Cheeze Machine, Ticky Clav (Apulsoft Mac Ports)
U-HE: Triple Cheese
Lernvall Audio: LAConvolver (IR player)
Yohng: W1 Limiter (L1 "clone")
Sonalksis: FreeG (Advanced Fader/Gain/Meter)
blazingrythm
Side chain/filter
I appreciate your reply but I am confused.
What does the term "in behind" mean?
(no prison jokes from lurkers please)
Providing frequency-selective compression sounds like a cool way to approach the sound one might want.
Can you expound on the subeject.
It all sounds extremely interesting to me.
Please forgive my layman's requirments in simple language to get my head around some of these very usefull ideas.
PEACE and LOVE thru MUSIC
NitrouStang96
Re: Two Questions:
Post by NitrouStang96 »
NitrouStang96 wrote:1) I see a ton of free plugs, but no VI's...
2) I've been reading about deconvolution. What types of things do you guys use deconvolution for?
papageno
This just came out: UpStereo from QuikQuak
Post by papageno »
A free stereo enhancer.
http://www.quikquak.com/Prod_UpStereo.html
Downloaded Mac AU version, tried it with DP 5.13. Works.
+372 56222285
timriley
Post by timriley »
Someone just put this one in the Free VI's/plugs list today.... Apparently it's a free stereo enhancer!
Mac Pro Quad XEON/2.8Ghz/12GB RAM
Macbook Pro Core Duo/2.16Ghz/2GB RAM
OSX 10.6.8/DP7.22
papageno
Post by papageno »
timriley wrote:Someone just put this one in the Free VI's/plugs list today.... Apparently it's a free stereo enhancer!
Maybe you read about it in the last posting before yours :P ?
+372 56222285
HeadMaster
Have you guys seen this?
=D
HM
Macbook 2.16
OS-X 10.4.11
DP 5.13
Linplug: Alpha Free
U-HE: Triple Cheese
timriley
Post by timriley »
Ooops!!! How did that happen? I meant to put it in a thread i saw the other day where someone was looking for a free stereo expander..... :oops:
OSX 10.6.8/DP7.22
mikebeckmotu
Post by mikebeckmotu »
Hey - have you all heard about that stereo enhancer yet?
But seriously -
Voxengo is in the process of porting their sizable collection of plugins to OSX. They posted a beta of their Overtone EQ, which is a free plugin. So far it's working in all my apps. Interesting things can be done with it.
http://www.voxengo.com/product/overtonegeq/
Dave Bourke
Post by Dave Bourke »
The final version of the Voxengo Overtone GEQ has now been released.
These plug-ins have a stellar reputation among PC users.
Kind regards.
Dave Bourke
– ideation –
Mac Pro Quad Xeon 2.66 GHz, 5 Gb, OS X 10.5.8, iMac 24" 2.4 GHz Intel Core Duo, OS X 10.6.2, Mac G4 dual 800 MHz Quicksilver, DP 7.11, PCIe-424/24i, UAD-2 Quad/UAD-1e, PowerCore Firewire.
matticus
Post by matticus »
Does anybody know if this overtone eq works on intel macs? I didn't see them address that on the site.
...real bits of panther, so you know it's good...
Macbook Pro 2.3Ghz
2Gb Ram
MOTU Ultralite
DP5.13
timriley
Post by timriley »
The Overtone Eq is working on my intel mac! I installed it last week and tested it and all was fine as far as i could tell....
OSX 10.6.8/DP7.22
