Your fave non-MOTU interface
Mr_Clifford
Post by Mr_Clifford »
Mr. Quimper wrote:Maybe if there are some happy DP/RME users on here, I'll decide to look into it again...
One VERY happy DP/RME user here. My Fireface 800 works great on my Dual G4 (in a FW800 port via PCI card), but I've also used it with DP on my MacBook Pro in the FW400 port without any problems.
I suspect, however, that you would run into trouble trying to run the Fireface 800 in full bandwidth mode on the same firewire 400 bus as an external Hard-drive. Maybe that's what people have been complaining about, i don't know. The FF400 would take up less bandwidth, but I suspect that it might still run better with its own FW bus.
kassonica
Post by kassonica »
I second that about RME
I have a FF800 running on a PB 1.25 and am most impressed with it's performance and stability. It replaced the 828mk 11 and the difference was noticeable immediately.
Less grainy sound, better image and better pres.
Highly recommended.
chrispick
Post by chrispick »
Frodo wrote:
frankymax wrote:Hey is anyone using the Apogee Ensemble with DP? It seems to be all set up for Logic but I hear that it'll run fine with DP- I'm using an 828MkII but would love to hear from Apogee Ensemble users what they think of the sound.
Thanks,
Frank
Peter McCStrat is among the few who have Ensemble here-- but I haven't seen him online in a while. He also uses one of the RME interfaces as well.
I use Ensemble. Love it. Good enough converters. Better-than-expected pres. I clock it to my Rosetta. Sounds great.
frankymax
Post by frankymax »
chrispick wrote: I use Ensemble. Love it. Good enough converters. Better-than-expected pres. I clock it to my Rpsetta. Sounds great.
and it plays well with DP? by that I mean it interfaces as easily as with the 828? Or do you have to jump thru a lot of hoops to get it to interface?
I also just started looking t the TC StudioKonnect 48 which seems to give you a lot of bang for the buck but TC's user forums have a lot of disgruntled users who seem to have problems with TC on intel Macs, etc. Anyone have any experience with the Studio Konnect and DP?
DP9/Windows7-64bit-32GBRAM Intel i7-3e930K CPU@3.2GHz/Lynx Aurora 8/VSL Ext.Lib//Komplete8/Spectrasonics/KorgLegDig/Valhalla/WavesMus2/iZotope/PSP/CytomicGlue/NomadPP/Plug&Mix/DynSpecM/KurzPC88/LexiNatBundle/RelabLX480/Kush/FabFilter/Finale/Sibelius/PacificaMicPre/Lawson/Neumann/Peluso/AKG/SeNeve/Lucas Mics/Genelec1032A
http://frankmacchia.net/
chrispick
Post by chrispick »
frankymax wrote:and it plays well with DP? by that I mean it interfaces as easily as with the 828? Or do you have to jump thru a lot of hoops to get it to interface?
Ensemble plays great with DP. And its Maestro user interface app is set up nicely and simply. It's all pretty plug-and-play really. No hoops to speak of.
I've never had an 828, so I can't attest first-hand to how it compares regarding ease-of-use. I'd imagine they're comparable in that regard.
The positive criticisms of Ensemble: A/D/D/A plenty good enough for what I do (work-for-hire music creation). Surprisingly good preamps. Easy to integrate with DP and Peak, my main audio apps. And a nicely constructed UI in Maestro. A good package in my estimation.
The only negative criticism: It seems to have a slightly noisy built-in headphone amp (that I only really notice when I'm not playing audio through it). But that's so minor in the scheme of things. I could easily pick up a dedicated headphone amp to work with one of it many outputs if I cared.
Yiannis
Post by Yiannis »
ULN-2 from Metric Halo here.
works perfect with DP..no problems at all and it has great preamps and AD-DA.
:wink:
I am a very happy DAD.
MacPro 3.33Ghz 6core-32g Ram-10T HDs-10.12.6-Dp-10.0.1.
Korg Kronos 2-Korg Pa4X-Ensonic TS 10-Korg T3-Yamaha Dx 7iiFD-Akai S3000xl-Roland JV 2080
Genelec 1031A with KRK 10S sub-Yamaha NS10m
ULN-2..Tubetech Lca2B-Avalon 737sp-HEDD 192-Lexicon PCM 90.
Soundcraft Sapphyre 28ch
3rdpath
Post by 3rdpath »
i have both the 828 and the ensemble and they both work swimmingly well.
i prefer the a/d on the apogee and as was mentioned, the maestro software makes setup a breeze.
i don't use the pre's or headphone outs on either unit so i really can't comment on those factors...
mac pro 2.66 quad, 7gb RAM, 10.4.10, dp5.13, M5v2.01, kontact3, reason4, ivory, addictive drums, BFD2, ocean way drums, stylus, altiverb, speakerphone, gearbox, EWQLSO platinumXP, apogee ensemble, izotope ozone, liquid mix, imposcar, vintage neves, UA 1176's...yada yada yada.
Frodo
Post by Frodo »
chrispick wrote:I use Ensemble. Love it. Good enough converters. Better-than-expected pres. I clock it to my Rosetta. Sounds great.
Hey Colonel-- didn't mean to forget about you on this one. Sorry 'bout that.
denovo
Post by denovo »
Frodo wrote:
denovo wrote:
homebilly wrote:firebox $225 or so
Yes, I've heard good things about this. However, I need 4 pres at least.
C
I know the original question was about "non-MOTU" interfaces, but as long as it's clear what MOTU represents in the way of interfaces, you can make the most informed decision.
MOTU interfaces are historically a lot of bang for the buck. The only reason not to use a MOTU interface with DP is if the quality of the convertors is/are at issue.
I would sooner just make a list of what I wanted to accomplish ideally without putting a price restriction on it. This will give you a better picture of how close to or far from the mark you are with your most coveted features from your $500 benchmark.
I even hesitate to recommend a worthy alternative because:
-- $500 for 4 pres with topshelf conversion is a tall order
-- $500 (or so) for something like the MOTU 8Pre doesn't address your original question
-- My favorite non-MOTU interface probably has an optional cable of some sort that would cost about $500
However:
If price is your first priority, scour the web for mac-compatible interfaces with at least 4 pres in the $500 price range, then limit your evaluation to those. Consider that two fireboxes for $450 with 4 pres would be awkward to setup as an aggregate device whereas an 8Pre for $550 may suit your purse at the expense of other criteria you are looking for in a non-MOTU interface.
If sound quality is your main criterion for judgment, then you are going to be out a whole lot more than $500, imho, OR you will find yourself right back at square 1 with an 8Pre or similar with CueMix.
Good points, Frodo. I guess from my viewpoint or ears. The converters from MOTU and/or the Firepod's are plenty usable. I have a 2408 MkII and I think the converters in it run rings around the Firepod's. But YMMV.
However, I'm pretty sure I'm never going back to a PCI based system again unless I become wealthy enough to own a workhorse laptop and a monster desktop system at the same time to run a full time home studio.
I just love the versatility that a portable firewire based system offers. And you can also use it with a desktop hog.
So really I just need 4-6 pres total. I already have a VMP-2 that I can run to the 828 MkII for two extra pres. And the 828 comes with 2 of it's own. Though I don't know how good they sound compared to the Firepod's. Plus I also have a BlueTube that I can use in a pinch (not my first choice - but its there if I need it...). SO that's another 2 for 6 total pres.
I might also at some point find a used Presonus MP20 and mod that. So the only other question than is to see if there's a way I can use a FMR RNC as an effects insert for the 828 MkII based system instead of using multiple compressors in series.
C
waxman
Post by waxman »
The Ensemble was a big step up in sound quality from my Motu 896 HD...
I use it with DP and Logic and it works great. Maestro is pretty elegant and works great.
If you only need 2 channels go for a Duet...
waxman
leigh
Post by leigh »
I use a Metric Halo ULN-2 and 2 Metric Halo 2882s.
The 2882 pres are quite good and the ULN pres are exceptional. The I/O routing is *very* flexible and provides very low latency monitoring.
I started with the original MOTU 2048, moved to the 896 and finally switched to the Metric Halo stuff.
For live recording, I use the Metric Halo recording software and then do the editing and mixing in DP. In the studio I use DP with the MH hardware. I record mostly jazz (small ensembles and big bands) and small classical ensembles and I get lots of compliments on how good my recordings sound.
And, of course, I get the usual: "You use ProTools, right?".
**Leigh
jaygro
Duet
Post by jaygro »
I just ordered a Duet. I'll let you know what I think when it gets to my door.
Everything else I have is MOTU.
jay
jgest
Post by jgest »
Mr. Quimper wrote:I know this isn't useful to the topic starter as it's above the stated price range, and I know Mackie's gained a bit of a negative reputation with this sort of gear in the past, but I just wanted to bring this thing up...because it truly looks lovely:
Mackie Onyx 1200F FireWire Audio/MIDI Interface Features:
* 30-in, 34-out audio/MIDI interface with 12 Onyx preamps
* Two instrument inputs
* Eight balanced line outputs
* Dual stereo control room outputs
* Four independent headphone outputs
* S/PDIF and AES/EBU I/O
* Dual ADAT I/O
* Two FireWire ports
* Includes Tracktion 2 and Final Mix software
:shock: Wow, looks divine.
Macbook pro, 3 gigs of ram, osx 10.62, Dp 5.13, Live 8.1.2, Reason 4, Tc powercore Virus, Albino 3.02, proper ergonomic sitting posture, plenty of coffee (french press only with a pinch of cardamon added)
My dp inspired music.....
http://www.myspace.com/aislingbeing" onclick="window.open(this.href);return false;
http://www.myspace.com/wigginsmaroo" onclick="window.open(this.href);return false;
http://www.mp3.com.au/artist.asp?id=10004" onclick="window.open(this.href);return false;
kelldammit
Re: Duet
Post by kelldammit »
jaygro wrote:I just ordered a Duet. I'll let you know what I think when it gets to my door.
jay
i just got mine the other day. you'll LOVE it. the fanout cables seem a little thin, but man, it sounds great, the headphone amp can drive my akg 240m's plenty loud, and the integration with osx is a thoughtful touch.
kell
Mr. Quimper
Post by Mr. Quimper »
jgest wrote: :shock: Wow, looks divine.
I don't know how it sounds, but it looks good on paper! :lol:
For what it's worth, it's almost $400 cheaper than Ensemble through Sweetwater.
2.5Ghz Quad-Core/20GB DDR3/10.11.6/DP 9.5
