duplicate audio file question
Hello,
I there an equivalent to Protools "duplicate" command in DP where a selected soundbite copies itself and gets pasted end to end ?
I know it's possible with Option-Control-Drag but it's not easy at all when you want to do it on very very small fragments of soundbites and for a long duration...
thanks,
poldo
thanks,
poldo
- Dwetmaster
Re: duplicate audio file question
I didn't know that...poldo wrote:I know it's possible with Option-Control-Drag
- Shooshie
And *I* didn't know *THAT!*wurliuchi wrote:There's Paste Repeat under the Edit window. You simply select a soundbite or time range and Copy, then select a new time range (however long you want) (sometimes it's easier to just add to the current selection) and Paste Repeat. The time range will fill with as many repeats as needed.
- Dwetmaster
It's funny Shooshie, I would've sworn that you actually had this in the tip sheet?Shooshie wrote:And *I* didn't know *THAT!*
