Beep-Beep
- lampostudio
Beep-Beep
Does anyone know why I hear a very faint, constant beeping sound coming from my speakers. I thought at first it was my untralite but even when I have all my MOTU interfaces turned off I keep hearing a beeping. I am using a Mackie big knob changing the gain on the big knob does not change the volume of the beep but if I turn the big knob off it stops. I tried going directly from the ultralite to my Mackie HR824 speakers the beeping is still there.
any ideas?
any ideas?
Do you have any demo plugins running? Sometimes, demo versions of plugins will place beeps intermittently to prevent people from actually mixing with them before they are paid for.
The only other thing I could suggest is to first isolate the audio channel/track through which the beeps are heard. Then, isolate the specific device sending signal on that channel or track which is generating the beeps by disabling one device or plugin at a time.
If it's hardware, perhaps some sort of hardware reset is in order. Perhaps a driver, if available, might need to be reinstalled or updated.
- lampostudio
I remember reading about this beeping problem when the G5s first came out. But I can't remember what the solution was (sorry). And I never bought a G5 myself.
EDIT: I just Googled "G5 beeping" and found this:
http://docs.info.apple.com/article.html?artnum=86523
Kind regards.
Kind regards.
Dave Bourke
– ideation –
Mac Pro Quad Xeon 2.66 GHz, 5 Gb, OS X 10.5.8, iMac 24" 2.4 GHz Intel Core Duo, OS X 10.6.2, Mac G4 dual 800 MHz Quicksilver, DP 7.11, PCIe-424/24i, UAD-2 Quad/UAD-1e, PowerCore Firewire.
– ideation –
- lampostudio
- Spikey Horse
- lampostudio
There might be on busy projects. If the CPU is in self-preservation mode it could place its own conservation above cycles needed by DP. That's not to say that it *will* be a problem, but if it is a problem you could always experiment with another setting such as Automatic.lampostudio wrote:Is there a downside to running DP5 with this reduced setting?
Good sleuthing on the power supply doc, btw!
