clicks / pops recording with SM57
Hello, I am using:
SM57 into M-Audio FastTrack Pro into DP 5.12 mono track
When recording a french horn (even at very low levels), I am getting clicks and pops -- sometimes during long notes sometimes during the ends of notes, etc. I cannot figure it out, perhaps I am micing too closely to the horn? Has anyone encountered this problem with this setup before.
Thank you for the help!
I am using a PPC 2.0GHZ, and my work priority was set to High. I've searched the help menu and DP manual, but I can't find an explanation as to what this specific setting means. Why would having it set to High adversely affect the recording, and do you know what specifically I am "prioritizing" in this menu selection. Any supplemental documentation as to this setting would be greatly appreciated!
I have a good handle on my MIDI but am truly a novice when it comes to recording.
Thanks,
Jason
Thanks,
Jason
The work priority setting is the processor thread priority. DP is optimized for dual processor machines. In most cases, if you are running a single processor machine, you have to use a medium or low setting. This will have no effect on sound quality (IMO). Set it to medium, and that should help with clicks and pops.
