clock problems with 896HD
We have been experiencing interface problems with our dual 896HDs with DP. Somehow, the clock gets screwed up when DP loads, and then about 4 minutes into a previously recorded tune, all the tracks sound like static even though the soundbites look OK. There is also clock issues with the 896s losing sync, but syncing back up when the hardware drivers window is opened. All in all, we seem to get these clock problems from time to time. Has anyone else seen this?
- burn em
Are you clocking over adat optical? If so remove the offending cable and clean the ports with compressed air. If that doesn't solve it, try a new adat cable. If that's the cause, liberally apply scissors to the old adat cable.
You would be better off clocking over word clock anyways.
But... this is all assuming you are clocking over adat. Some more info would be useful.
Macbook Pro i7 17"-10.6.8 16Gb DP 7.24 ][ G5 dual 2 ghz pci, 4Gb-10.4.11 DP 7.12
Nomad Factory ][ Airwindows Gatelope (The best drums gate. buy it!) ][ Altiverb 6
MOTU 828 mkIII, 828 mkI x3, 8Pre ][ Apogee AD16, DA16 & Duet ][ MC Mix ][ API 3124+ ][ Toft ATB 24
