![Evil or Very Mad :evil:](./images/smilies/icon_evil.gif)
If you hate the way DP converts bwavs to sdII, join me!
---edited for clarity---
David Polich wrote:Not sure what you're complaining about. I can import .WAV files into DP just fine. Please explain further what your situation is.
you are right, that‘s what I meant, see above.James Steele wrote:I think what you're after is DP to playback WAV files without having to import to SD2. I don't know much about the issue, but it seems like from what I've read, Broadcast WAV is what they should consider doing due to the timestamping and the fact that this format is becoming pretty ubiquitous.
What they said...vier-personen wrote:you are right, that‘s what I meant, see above.James Steele wrote:I think what you're after is DP to playback WAV files without having to import to SD2. I don't know much about the issue, but it seems like from what I've read, Broadcast WAV is what they should consider doing due to the timestamping and the fact that this format is becoming pretty ubiquitous.
bwav is what I encounter at practically every recording situation I was attending in the last years - except if I pull out my DP...
Motu was a no show at AES last year.....I wonder if they'll show this year?gearboy wrote:I'll talk to them at AES. I'm sure that'll help.
