Hi All,
Is it possible to send all sound from the MOTU out to an FX unit (kaoss 3) then route it back into the MOTU and monitor it?
I'm sure I can rig it within Cubase but I intend to use the 828 as a standalone device for live performance, so I wanna know if there's a way to do it directly.
Thanks in advance
Jake
828 mkii - routing to outboard effects
I was successful in doing this.
I set Mix B's main output to be Analogue 3+4. Analogue Out 3+4 is wired to the input of the Kaoss.
Then I turned up all the other analogue inputs in Mix B and panned accordingly.
Then I selected mix A again, and muted every channel except Analogue 3+4. The main output for Mix A is SPDIF, I use SPDIF to monitor.
Works fine.
Jake
Works fine.
Jake
