Assign VI to a output bundle / MIDI track
hi, i work a lot with audio, but unfortunaly not with MIDI. I just bought GarageKey MIDI keys and just want to work with some tracks MIDI, but the only sound I can get is from the Apple Software Synth, piano and drums. How do you send your MIDI track to an Virtual Instrument, like the standard bassline or whatever...
thanx a lot!
i work with DP5.12, Mac OSX 10.4
thanx a lot!
re
The only assigning i can do is the apple synth and an IAC driver.
In the instrument track there are only outputs (audio) to remap, so that's not what you mean i guess??
re
maybe you can e-mail me a screenshot, cause i think i just don't understand the whole idea behind MIDI in dp, because so far i only did audio...
gijs (@) setitonfire.net
- Dwetmaster
Once you instantiate your VI, Make sure sure it assigned to a proper output (Stereo Out, stereo bus...)via the bundles. Thyen it should be avaiilable as a the MIDI output in the Track Overview, The Sequence Editor or the mixer. The MIDI output is located at the same place where you find the I/O Audio on your track.
