Mutiple Microlites
Kaszper
Mutiple Microlites
Post by Kaszper »
No, not the small aircraft...
I gather Motu's Microlite MIDI interface is chainable to give you access to more MIDI devices. Does anyone have experience of doing so?
magicd
Post by magicd »
You can't chain microLite interfaces to each other. You can connect multiple micro Lites (or any other models of MOTU USB MIDI interfaces) via a powered USB hub or directly to separate USB connections on the computer.
Each interface will then show up as a separate device in Audio MIDI Setup.
Magic Dave
SixStringGeek
Post by SixStringGeek »
magicd wrote:You can't chain microLite interfaces to each other. You can connect multiple micro Lites (or any other models of MOTU USB MIDI interfaces) via a powered USB hub or directly to separate USB connections on the computer.
Magic Dave
Only they don't work with hubs. Not even one on a hub by itself. Drops MIDI like crazy. Totally failed to drive one Mackie Control Universal properly or a MIDI control keyboard - tried all manner of USB hubs - many brands - powered. No luck.
BradLyons
Post by BradLyons »
I have a pair of MidiExpress128's (previously the Microlites) working on a powered hub with no issues---then again, I'm a lowly WindowsXP user :twisted:
Thank you,
Brad Lyons
db AUDIO & VIDEO
-Systems Advisor, CTS
emulatorloo
Post by emulatorloo »
BradLyons wrote:I'm a lowly WindowsXP user :twisted:
ME TOO!
And then I am so damned happy when I can turn off that "Gates of Hell" XP box and get back to my mac! :lol:
(Brad, relax and enjoy that new macbook pro they forced on you -- I think you are going to find it is nice to have both platforms)
Kaszper
Post by Kaszper »
Thanks, chaps.
Looks like I'm going to have to invest in a bigger MIDI interface. Your recommendations would of course be much appreciated![/b]
magicd
Post by magicd »
<ahem> I work for MOTU.
MOTU makes three categories of MIDI interface. The basic job of a MIDI interface is to get MIDI in and out of the computer.
Fastlane - 2X2
microLite - 5X5
Express 128 - 8X8
The next step up is a combination MIDI interface and patch bay. You typically need patch bay functions if you use your MIDI gear when you are NOT using your computer. Patch bay functions allow you to route MIDI inputs directly to MIDI outputs.
micro Express 4X6
Express XT 8X8
These two interfaces also have basic LTC/MTC sync functions
The fancy box is the MTP AV
The MTP AV is an 8X8 MIDI interface/patch bay. You can connect a pair of MTPs to become a single larger 16X16 interface.
The MTP AV can be programmed from the front panel (good feature for a patch bay at gigs).
The MTP AV has video sync, word clock, ADAT sync, and LTC/MTC sync
Hope that helps!
Magic Dave
BradLyons
Post by BradLyons »
I've been using MOTU MIDI interfaces for oh goodness..... 11-years? IMHO, I feel they are the BEST ones on the market with the best drivers and the best reliability/compatability. They cover from the most basic of MIDI interface to advanced needs.
So Mister MagicDave, any chance of bringing back a modernized Digital Timepiece? :lol:
Thank you,
Brad Lyons
db AUDIO & VIDEO
Kaszper
Post by Kaszper »
magicd wrote:Hope that helps!
Indeed ••“ although you forgot one thing:
"The MTP AV costs six hundred bleeding bucks!"
I think the 128 Express is the baby for me.
SixStringGeek
BradLyons wrote:I have a pair of MidiExpress128's (previously the Microlites) working on a powered hub with no issues---then again, I'm a lowly WindowsXP user :twisted:
Check previous thread on Mackie Control Universal + Extenders with a micro lite on a powered hub with any kind of Intel mac. It doesn't work. MOTU tech support also insists it doesn't work and required removal of the hub - which does make it work. Even a controller keyboard on a hub alone doesn't work.
Thread here:
http://www.motunation.com/forum/viewtop ... highlight=
SixStringGeek
Kaszper wrote:I think the 128 Express is the baby for me.
I have one - if you just need 8 MIDI busses - its great.
Kaszper
Post by Kaszper »
SixStringGeek wrote:I have one ••“ if you just need 8 MIDI busses, it's great.
I need more MIDI ins and outs, if that's the same thing!
Thanks for the rec.
SixStringGeek
Thanks for the rec.
A MIDI bus = one in/out w/16 channels. You get 8x that or 128 separately addressable MIDI devices.
vmil
Post by vmil »
hi everyone
i'm just about to buy a new MIDI interface - microlite is top of the list - does microlite have the MIDI timestamp technology as supported by osx? the dealers are less than clear....
thanks
v
