DP will not save time formats??
Hi All!
I seem to be having a bit of a problem: I recently upgraded to DP 5 (5.11 now) and I am having trouble getting the program to save the time formats in a project.
By this I mean that I can start a new project and adjust the main and secondary counters to display the time format I want (usually frames and real time) and also adjust the marker window, etc. to display the format I want. When I save the file and open it later, however, both counters and all of the other time displays have reset to their defaults.
Is there a way to change this so that it saves with the file, or am I doing something wrong? This is obviously not a huge deal, but it is annoying.
Thanks a bunch!
-Mike
Thanks a bunch!
-Mike
Arrg!
Re: DP will not save time formats??
What ? You don't like that new feature introduced in 5.x ?.... hum.... Unfortunately, that's a very annoying bug that wasn't here in pre 5 versions... We have to live with it until MOTU fixes it. I don't understand why it hasn't been addressed yet, since we're at 5.11 now... It's been a while...celticrogues wrote:Is there a way to change this so that it saves with the file, or am I doing something wrong? This is obviously not a huge deal, but it is annoying.
Mac Pro 5,1 12-core 2.4 GHz//40GB RAM//RX 560//macOS 10.13.6//SSDs//MOTU 896//Keylab 88//Faderport 8
Pro Tools 2018.7//LPX 10.4.1//DP 9.51
NI Komplete Ultimate 11//Albion One//Soundiron Choirs//Pianoteq//Analog Lab//VSL SE & Chamber Strings//etc
- Mr_Clifford
It should, yes, except it doesn't...Mr_Clifford wrote:If you set it up with the 'time format' dialogue it should stick. option-command-T I believe.
Yeah this is what I have been doing - thanks morpheo for reassuring me that I am not just doing something stupid. I guess I'll just wait until MOTU decides that this should be fixedMr_Clifford wrote:If you set it up with the 'time format' dialogue it should stick. option-command-T I believe.
Cheers,
-Mike
Arrg!
Is this what you're discussing?
Is this what you're discussing? I'm able to save 1 timeformat but unable to see any, as you can see. (or not, rather)
(Wanted to try out the subject field in an existing thread. I therefore wrote a headline of my own just to see where it goes. Ok! I got a small headline of my own).
Windows 11, DP 11
https://www.youtube.com/channel/UCOI37x ... 8vAQJwNm_A
Same problem here...
mines fine too...
it's weird how some things affect some user not others...
something installed in common?
http://www.fork-media.com
If I save the time format to the project it works fine. If I simply set the time format and don't save the format but save the file, it reverts to measures on next launch.
I would like the program to default to FRAMES (or maybe real time). There doesn't seem to be a way to do that.
MLC solution is good
"If I save the time format to the project it works fine. If I simply set the time format and don't save the format but save the file, it reverts to measures on next launch. "
If you are a TV guy I bet most of your projects could be made from a template - Dont use the DP ones! make your own get everything as you like..
now to create a new project - open YOUR template and save as ( and Duplicate - I'm a film guy so I have BEEPS etc and automation set up - (insert vol etc on each track... compressor etc on your Voice Over channel (s)..
SFX to sfx sub, foley to foley sub, ambiences to ambience submaster
I even have the time formats saved to project (oops sorry! ) I'd actually forgotten about this glitch!
And now something completely different.
This goes beyond my knowledge. Suddenly I have a Time Format named Samples Copy. I know that I've accidentally pushed the key-command for showing sample time in all windows (I meant to toggle solo mode). Then I started exploring those time format shortcuts, analyzing what they did. But I'm totally shure of not having made any copying.
Well, at least I have a format to duplicate. So I hopefully I'll be able to make dozens of presets.
Windows 11, DP 11
