How to insert with 896hd?
Ok! Once I‘m into the mixing session I would like to insert some external FX, how could I do? I tried to out the track and in the out from the FX processor, but it was really delayed... is there any other way? Normally I work 1024 sample rate and 24bit/48Khz, and I can‘t work without direct monitoring because I have an incredible long latency problems!!!
Hi there!Musca wrote:Hi, what software are you using? what drivers does your software employ to drive the 896hd? what routing did you do in the soft and in the device?
I‘m working thru Cubase SX and Nuendo 3, and it‘s the lastest drivers version. I would like to insert, for example, my Joemeek comp to ch.1 during the mix, so I need no latency problems.
www.myspace/darkdani
www.darksunweb.com
Dynamita Studio
MAC Pro 2,66 Intel Xeon
Macbook Pro 2,16
Dual MOTU 896hd // Truth 2031a
Focusrite ISA´n´Joemeek preamps
Lots of plugs / AKG ´n´ Shure mics
www.darksunweb.com
Dynamita Studio
Macbook Pro 2,16
