normal time for DP to start up?
kgdrum
Post by kgdrum »
Mr.Clifford - "I downloaded that AU plug-in manager so that I could disable AU plugs that I don't use much in DP. You can save different configurations of plug-ins. "
hi what is this AU manager/do you have a link?
thanks KG
martian
Post by martian »
Well the honking mac used to doppler by me on starting session....
but now it's honking like it's in a traffic jam.!!!
I mean the sessions open up and all but take a while
On the subject of pluggins - I'm with da monkey man - pretty much my machine is as has come from apple...
I did try wave arts - but it got jettisoned when I was debugging a month ago - was probably a quicktime issue
actually I'm just bummed out that ambience didn't work ! That was my favorite reverb - I'd send the guy another $20 if he'd port it to UB..
But yes - it takes eons to start Dp...
might try timing this tomorrow...
err it might be the wrong guy
but
I'll be back.....
http://www.fork-media.com
Frodo
Post by Frodo »
martian wrote:Well the honking mac used to doppler by me on starting session....
Just curious-- same plugins now as in the early days of the MacPro, or have you installed more stuff since the bog started?
And-- approx how long does it take for yours to boot up?
martian
Post by martian »
it took 2 mins 2day
I just have the basics - DP's basic set and the AU that are in the OS..
it used to be quicker
today time at 2 mins....
I hadn't timed it before but it seemed longer...
it loads up plugins - I see them whizz by - then it freezes - and thaws to the reading project bar after around 2 mins..
martian
Post by martian »
wow definitely an issue!!!
I opened up DP on my imac intel - around 45s
on my mac pro - 3 minutes 30 something!!!!
trashing prefs hasn't helped...
they are basically the same system - plugin's etc - ( only diff is that rewire is installed on mac pro....
in both cases I just launcehed DP not opening any project,,,
hmmm - what have we here?
martian
Post by martian »
and now yesterday - after a crash I reboot and it opened in approx 30 secs!!!
something weird here!!!
PBenz
Post by PBenz »
Does anyone know where I can find that Audio Units Manager? I searched for it and came up with this link: http://www.grantedsw.com/aum/, but unfortunately that site appears to be gone.
I'm brand new to DP - my competitive crossgrade copy arrived yesterday, and the only thing I'm somewhat disappointed in is the startup time. Cubase 4 started in 15 seconds: DP takes 60. And yes, it's all the plugs-ins: it seems to take a long time to load Altiverb and 2 different Waves shells. I also have the UA plug-ins but it seems to load them pretty quickly.
I look at it this way: if DP's stability is good and I don't have to restart it all the time, then this will be a non-issue.
DP 5.11, Dual 2.5Ghz PowerMac, RME Fireface 800, DW Drums
House O' Benz
spirit
Post by spirit »
DP in DAE mode seems like it takes 2x as long as in MAS mode- like it has to look at each component for DAE and then look at each component (or at least plug's/VI's) again for DP. With a big session with VI's etc. this can be 10+ minutes. For a similar session in PT it seems about half the time.
Tritonemusic
Post by Tritonemusic »
PBenz wrote:Does anyone know where I can find that Audio Units Manager? I searched for it and came up with this link: http://www.grantedsw.com/aum/, but unfortunately that site appears to be gone.
Give me a PM with your email and I'll send it to you. It's only 500k.
PBenz
Post by PBenz »
Thanks, 666 - you have a PM.
House O' Benz
TOD
Post by TOD »
Mine takes about 90 seconds on a G5 dual 2.7 w/ 6 1/2 gigs of RAM OSX49.
I noted that Altiverb takes at least 30% of the start up time, (I think loading all those IR's).
I'm a plug-••••• and it continues to take longer, but that's a welcome trade for increased stability in 5.11
DP 5.13 dual G5 2.7 synced to dual 1.42 via SMPTE, Muse Receptor (filled with Stylus RMX, Trilogy, Atmosphere, Elektrik piano, Disco DSP), OSX.410, Ableton LIVE, Apogee Big Ben, Apogee mini DAC, MachV, Symphonic, Ethno, M-Tron, Mx-4,Latigo, Jupiter Vi, iDrum, Microtonic, Kontakt3, Bassline, Bassline Pro, Ultra Focus, Novation Basstation, Novation Drum Station, Nord Lead2, JD-990, EMU Proteus, Orbit 2, MicroKorg, UAD, Poco, Altiverb, VW2, Waves, Ozone, to name a few :)
Yeah, Altiverb takes awhile. As a Waves AU (as opposed to MAS) user, I have seen a dramatic reduction in DP startup time. As noted earlier in this thead, the tradeoff is slightly slower instantiation of each plug in a session. It appears that MAS pre-loads the plugs and AU loads 'em when you need 'em. This would explain DP's longer startup times.
As long as we're not crashing, I'm Alfred E. Neuman (or Neumann in audio circles): What? Me Worry? :D
HC Markus
https://rbohemia.com
PBenz
Post by PBenz »
Ah ha! Thanks, HCMarkus, for pointing that out. After moving my Waves MAS plug-ins out of the MAS directory and using the AU versions, I see exactly what you're saying.
House O' Benz
martian
Post by martian »
since the initial week of 4 mins start up it's now back to 20s and it's all just a distant memory...
oh •••• did I just type that.... prolly gonna happen again now!!!
martian wrote:since the initial week of 4 mins start up it's now back to 20s and it's all just a distant memory...
Yup, good call martian.
It's the ol' cursentator's comm. :lol:
