MOTU UPDATE YOUR FIRMWARE & WINDOWS XP DRIVER
Jidis
Re: No testing on Windows.
Post by Jidis »
leloup wrote:I got so tired of constantly troubleshooting my parallel MTPAV that, today, I went out and spent the money again on a USB version. And guess what, still having problems. I don't think there's any testing on the Windows platform at all.
This is similar to what a few users had to say when I looked for info to make my parallel work. Worst part is, "buy the USB version" is the usual recommendation to people who have fought with that half-ass unified driver and the parallel boxes. It works fine for most, but there were several mentions of it "disappearing", needing to be "reset", etc. I'm almost wondering if the USB install is all part of that same crap code that was hacked to get them a WDM version of the old VXD, or whatever they had for 95. I remember we did have to run the USB installer to install the parallel one (nice "original" idea there huh?).
Gotta wonder what the heck it is with these "disappearing acts" anyway. They span way too many different pieces of MOTU gear to make any sense. My theory is: Either a disgruntled ex-employee left some weird virus thing on all the test machines, or someone got sick and missed some crucial day in programming classes where they discussed that particular port access or sharing crap. 8) (just joking- that one was a bit too rude, even for me)
BTW--> WHO actually decided that parallel ports were no longer available on PC's after 2K came out? I personally don't have any here without them, but I don't run laptops either (those probably even have working adapters available). Worse yet, IIRC, many people who were heavy on sequencing and MIDI timing, actually preferred that over USB. I bet if the 8-pin serial connections stuck around after the beige G3, that driver would still work. :x
George
PS- For anyone interested, someone pointed me to an EgoSys (ESi) box a while back, which was only around $150. It was an 8x8 USB in a 1U rack box, and he said it used some standard USB MIDI access for XP, which he said was acceptably "reliable". FWIW, this was also a guy who had designed and built his own (free) version of a 2x2 USB interface circuit, along with a slew of other MIDI controller designs, and had bench tested several MIDI interfaces as well. To my knowledge, he's never steered me in the wrong direction on stuff like that. :D
(May be something cheap to look at, for anyone out shopping, and it doesn't sound as if it could get "killed" by any poor support in the future.)
Okay... I changed my mind. I made a new forum called "MOTU Hardware & Windows." I am looking for volunteers to make moderator status to help me move Windows posts from the old "hardware" forum that I have renamed "MOTU Hardware & Mac OSX"
Message me if interested in helping out with this.
lmoe
Post by lmoe »
I am curently using 2 896HD's daisy chained with Sonar 5 and have no problems at all. My OS is XP pro sp1. I record at 24/96. I notice #2 loses it's clock for a second sometimes, but I think I've cured that by diabling my network card. You should be able to do what you are trying to do. I had to tweek some of my setting when I originally hooked them up but, now they work like a charm. (BTW at those high sampling rates FW bus can only handle 2 interfaces) As an aside I went into BIOS and disabled everything that didn't have anything attached (serial /parallel/onboard sound/etc)
Hard2Hear
Post by Hard2Hear »
I just wanted to add that we do motherboard testing for our Pro Audio systems and we do many many xeon systems for our live boxes. When we tested that asus board you have in your sig, it failed our compatability and audio standards with several interfaces. So we don't use the ASUS board with our Xeon systems.
edwardb
Post by edwardb »
What boards do you suggest for xeon systems ?
Asus PC-DL Deluxe Server Motherboard
Dual Intel Xeon 3.2 Ghz 2Mb L3 Cache 533 Fsb
Intel 875 Chipset, 4 Gb Ram, 256 Mb Agp 8X Video
Belkin Firewire Pci
Maxtor Sata 7200 rpm 16 Mb Cache 250 Gb X 3
Dual Motu 896HD Firewire Interface
Presonus Digimax LT Pre-Amp
Windows Xp Pro Sp1, Sonar 6 Producer
Native Instruments Komplete 3
terry1
Post by terry1 »
edwardb
Sorry in advance, I wasn't going to read this long draw out thread. But I'm assuming you are running win xp sp2. If so did you down load the sp2 patch. supposaly it degraded fire wire greatly to the point it could be causing most of your problems. Just a thought! :? :?
cfdude
The real problem if you use firewire
Post by cfdude »
Here's the deal. I spent a lot of money trying to get two travelers working together and I thought this was MOTU's fault. The problem is that Microsoft really screwed up their firewire drivers in SP2. I could not get the two to sync together at all. I did the RME fix and installed the SP1A drivers and Wow! works like advertised. Anyone who uses firewire should go back to the SP1A drivers. Forget the Microsoft patch, it doesn't work. I think MOTU should be telling this to people! RME certainly does. It beats having $1700 in boat anchors.
terry1
Post by terry1 »
cfdude
Sorry to hear the patch did not work. Well at least sp1 works and i don't believe any thing in sp2 improved it as a daw. So it would not be any loss in not having sp2. What is really weird about it is I'm using a presonus firebox and it hasn't hiccuped once. But motu has to have things a certain way other wise it won't work properly. What i don't understand is whats in motu that makes it so finicky. could it be the drivers.
cfdude
Post by cfdude »
I had a presonus firepod and their firmware sucks. I could not get the spdif to work on it with the latest firmware. I had to get a firmware downgrader. Also a potentiometer went bad on the input, so I had to fix that also. I guess none of them are perfect.
terry1
Post by terry1 »
cfdude
Your right! Whats really bad it just seems to turn into a hit or miss thing no matter what you get. When i started this i pick up another interface base on some pretty high recommendation. boy were they wrong. It kept crashing all the time. when i pick up my presonus now it all good. but just the same i hear a ton of complaints from about every interface user out there.
Sneaker
Post by Sneaker »
I just bought a 2408 mk3 two weeks ago and I have had nothing but problems with it. I am also sorry I didn't do more research before I bought it, the driver issues are causing me a headache and every time I shut down my PC I get a blue screen.
Even though I followed all the instructions step by step it never worked right. When I spend a decent amount of money on something I expect it to work and if it doesn't work I expect the company to help me out.
Well... you guessed it, it doesn't work right and the company isn't helping me. I have no patience for a company not standing behind their product and I am not the only one having issues.
I don't have the time to try and hunt down programmers at MOTU to talk to them about drivers for Windows, I want to focus on making music not figuring out MOTU's problems with there products.
I just wanted to post here to let everyone know I am having issues as well and that I am returning the 2408. It's a shame, I was really beginning to like the product minus the issues I am having but I can not support a company that doesn't care.
I am looking into RME, I use Cubase and I think that is the better option at this point.
tk
Pops, clicks, solved
Post by tk »
Please try the solution at http://thoughtyard.com/twiki/bin/view/M ... TechReview.
I originally had terrible clicks and pops and other problems, now everything works great.
Sneaker
Post by Sneaker »
MOTU got back to me and suggested I update my graphics card drivers to try to resolve the issue. Too little too late, I ended up going with a RME Fireface 800 and I am returning the 2408.
I hope inthe future they work out the issues because like I said before I was really beginning to like the 2408. It seems like it works good for some PC users and others have nothing but problems.
MOTU still has some excellent products but I don't think they are up to speed on the PC side yet... I have a MIDI express 128 that I love I am rather sad the 2408 didn't work out.
http://www.soundonsound.com/sos/oct03/articles/motu.htm
This is the first time I've had the chance to try out some MOTU audio interfaces, but I was keen to do so, partly because as Mike points out in the main text they have attracted a reputation of being problematic when used with PCs. My first visit was to the MOTU web site to download the latest PCI-424 PC drivers, and although the impression is given that there are multiple drivers available, in fact a single 1.7MB file supports Windows 98SE, ME, 2000 and XP, and the latest version 1.02 drivers dated 26th March 2003 were already on the supplied CD-ROM install disc.
Unusually, you have to run a Setup.exe file before installing the PCI-424 card, as Windows apparently doesn't perform a full install via Plug and Play (for instance, Windows 98 at one stage declared it to be a "PCI Early non-VGA Device"). I did this under Windows XP, opting to install the ASIO, WDM-MME, and GSIF drivers, but subsequently had to power down and up a couple of times before the card was correctly recognised, and then had to power the 24I/O down and up as well before this was detected, whereupon MOTU's PCI Setup Wizard utility (designed to detect what I/O devices are connected to the PCI-424) crashed my PC part-way through the procedure ••” a very rare occurrence!
I took great care to ensure that the PCI-424 had its own unique interrupt, and during the next few hours I tried cleaning the PCI card's contacts, re-seating it in its slot, swapping Audiowire cables and switching to the 2408 Mk3 and HD192, but apart from the HD192 being momentarily recognised and then crashing my PC again, it was no go. At this point I gave up and contacted Musictrack for a second opinion, and they suspected that the PCI-424 card might be faulty.
Sure enough, the replacement that arrived the next morning performed perfectly first time, but I did notice that the offending card had a revision 1 circuit board, while its replacement was revision 3 ••” I advise anyone buying a second-hand MOTU system to check this carefully before parting with any cash. Now that I could recognise the various I/O boxes I performed some critical listening tests, and was well impressed with what I heard using the ASIO, GSIF and WDM drivers. Cubase and ASIO were still working well down to 1.5ms latency, although after running Sonar's Wave Profiler I only managed a 23.2ms effective latency with the WDM drivers.
I then used Rightmark's Audio Analyser to perform some tests using the MME-WDM drivers, but once again ran into problems, only managing to complete a few before it dropped out with an error message. However, those that did finish were impressive, with a flatter frequency response than any other card I've tested to date, particularly at the bottom end where it was only 0.2dB down at 4Hz, and comparing the MOTU 24I/O box blind with my Echo Mia card I could easily pick it out as having much lower jitter (I could hear a lot further into reverb tails) and a tighter bass end. I measured dynamic range for the 24I/O at 24-bit/44.1kHz as an excellent 106dBA, but unfortunately I didn't manage to successfully run any other 24-bit tests at higher sample rates.
Motu's PCI Audio utility for changing sample rate, buffer size, and so on also gave me considerable problems, often leaving my PC permanently running with 100 percent CPU overhead even after I closed it down, and I never did get the MME-WDM drivers to function wholeheartedly, having to switch to Direct X ones to run the MOTU I/O units simultaneously with my Echo Mia under Cubase SX for comparison purposes. After a total of at least 12 hours' testing, two PCI-424 cards, and three different MOTU I/O boxes I threw in the towel, and can only recommend that PC users tread very carefully. Like many other PC musicians, you may have no problems installing and running MOTU products, particularly with the ASIO and GSIF drivers, but do make sure you can get a full refund if you run into problems like mine. This is most definitely a case of caveat emptor! Martin Walker
A big selling point for me:
http://www.soundonsound.com/sos/dec04/a ... reface.htm
RME have always had possibly the best driver support of any range of audio cards I've ever come across, with regular updates and consistent reliability, and this extends to the Fireface. As it's a fairly new product, RME were continually posting new driver updates throughout the review period, including Mac OS X-compatible drivers towards the end. Occasionally, newer drivers will require you to flash the Fireface's firmware as RME add new functionality (such as Windows XP SP2 compatibility ••” see 'Firewire 800 Compatibility' box), although this takes just a few moments with the software updates downloadable from RME web site. Like the HDSP 9652, the Fireface features Secure BIOS technology, meaning that even if the firmware update fails, rebooting the Fireface will restore the old firmware so that you can continue to use the unit or try the updating procedure again.
The Fireface's drivers offer multi-client compatibility with ASIO 2.0, MME and GSIF 2.0 driver models for Windows 2000/XP users, and Core Audio and MIDI support for Mac OS X users running at least 10.3. GSIF 2.0 (GigaSampler Interface) is the latest driver model used by Gigastudio 3 (Gigastudio 2.5 used the GSIF 1.7 model), and, as with previous versions of GSIF, offers extremely low latency by operating at a kernel level. One of the new features of GSIF 2.0 is kernel-level MIDI support, so the Fireface's MIDI ports can now be addressed at a lower level by Gigastudio 3 for improved latency, and RME were actually the first developer to support GSIF 2.0, with suitable drivers having been publicly available even during the beta-testing stages of Gigastudio 3.
The multi-client nature of the drivers allow ASIO, MME and GSIF applications to be used simultaneously (it's even possible to run multiple ASIO applications at the same time) so long as each application runs at the same sample rate and doesn't share the same audio channels with another application. This latter limitation can be overcome by RME's included Total Mix system (described in the main text), which allows you to reroute or mix a playback channel to a different physical output.
arth
Re: Pops, clicks, solved
Post by arth »
tk wrote:Please try the solution at http://thoughtyard.com/twiki/bin/view/M ... TechReview.
Following the link brings me to an error page stating "Access Denied".
srenity_sam
Post by srenity_sam »
Well James Steele and Edwardb...
Thanks for getting a separate PC/MOTU area going...now let me vent a little...
(sorry to post in more than one thread...I'm confused!)
See New Topic "WinXP x64 / Traveler / Sonar 6.2PE. Anyone else have this same combination, and working? Not me!
Judging from the many "issues" about MOTU/PC combos, one would conclude MOTU should stick w/Mac's. Oh, I've done some stuff, but not without some goofy glitch or shut-down error about every time I turn my system on.
See signature showing my gear. Fairly new stuff...I started this around 12/06. Have had mostly head/heartaches with goofy glitches the entire time. The Sonica computer is being sent back to them a SECOND time. I don't know if they'll let me have it back, because they've been telling me that MOTU's drivers are problematic, and keep trying to convince me to switch to RME. But I've been stubborn, 'cause I like the Traveler layout vs the FF400, and don't wanna pop the extra $$ for a FF800.
You cannot get MOTU to respond (like others have noted), and Cakewalk Sonar techs are making suggestions that fix nothing either. Frankly, the following things make it LOOK like all 3 digital items have some problem:
1. 5+ times now, the CPU's will stutter...freezing the audio (if playing), mouse cursor, typing, EVERYTHING for 1/4 second about every 1 second. Shutting down Sonar or turning off the Traveler does NOT fix it. Only a total reboot does. Is this the computer?
2. The Audio Dropout popup will happen EVEN if I just loaded the first project and have NOT hit play yet...and also when audio is playing. Closing it allows me to proceed, but it's annoying. Changing buffer size doesn't help. Very intermittent...different projects. Is this the MOTU drivers?
3. Sonar's TTS-1 softsynth's HELP file cannot be access via the synth's interface HELP button (ERROR; Cannot find Help Files)...but are intact and where they belong (broken link?). Sonar's Pentagon-1 softsynth has terrible glitch problems on certain patches causing Sonar's meters to peg at 99.5db and stay there until the Audio Engine AND the synth are both disengaged...it's very scary! And, there is NO External Encoder Config Utility under Sonar's Tools menu...it's supposed to be! Could this and all the 20+ SONARPDR.exe shutdown faults in kernel32.dll be a defective Sonar installation DVD?
Anyway, it's been months now, and we've tried everything. So the Sonica president wants their system back, and if they cannot get it to work with the Traveler, Pres. Maureen Wilder has threatened to refund my money. Where in the hell am I going to find another 2U rack system with those powerful guts for <$1800?!? I've looked everywhere online, and have only seen 4U size available, and for more $$. OK, ok...I know I'm venting...but I've been thru the wringer :evil: . Who knows if all this madness could've been avoided if I had just gone with an RME interface in the first place. Sonica assures me it could have. :roll:
So I just figured I'd put my 2 cents in. I will repost an update once I actually have a working system (hopefully this year!)...
WinXP Home on Sweetwater CSR Core 2 Duo / MOTU Traveler v1.07 w/latest drivers / Sonar 6.2.1 PE DAW / Ensoniq VFX-sd keyboard / Ovation 1755 A-E 12str / Breedlove AD-25SM A-E / Ibanez Pro-Line elect / tons of outboard analog gear. Produced 22 songs in the last 2 years.
