Dear Waves...
David Polich
Post by David Polich »
Thanks so much for doing the test! I feel better now ... 8) .
buzzsmith
Post by buzzsmith »
Like 666, I'm running a 1.25 ghz dual MDD and am OK with Waves, DP 5.11 and OSX 10.4.8.
Just my 2•!
=buzz=
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Post by Shooshie »
David Polich wrote:Yes, Shoosh, that's correct. I'm still on my PPC Mac, I don't have an Intel Mac.
I addressed that, too, in the same post. DP 5.11, Waves 5.1(?) in MAS, everything worked (see the very top of that post). But I was answering multiple posts in one, as there seems to be lingering doubt as to the viability of Waves plugins in both PPC and Intel versions with DP 5.11. I'm just saying that there is a version that works for each of them. MAS for PPC, and AU for Intel. Mas presets do not "stick" for AU plugins, btw.
On the other hand, I have not tested automation in the AU version for Intel.
That's all for now...
dweiss
Post by dweiss »
Automation's always a crapshoot with Waves. The SSL plugs automation doesn't work anywhere in any version.
Phil O
Post by Phil O »
Shooshie, be careful. I, like you, installed Waves 5.9 on my Intel Mac and thought all was fine. But as luck would have it, at the worst possible time (I had a client leaning over my shoulder), DP quit. When I tried to re-open the project, no dice. :cry:
Well that was the first incident but not the only one. After several unexpected quits over several weeks, I noticed they always happened when adjusting something in a Waves pluggin. I've since then uninstalled Waves and have had no problems. Be warned, my friend.
taggart
Post by taggart »
Phil O wrote:Shooshie, be careful. I, like you,
Uh, should we be worried about Shooshie? Is Phil O a danger to himself and others? I mean, I've had stalkers in my day but...Wait a sec...My bad! Didn't see the comma after the "I" Sorry, folks! Shooshie can relax, now. :shock:
Taggart
Mac Mini
DP 11
Reason, and various plug-ins, VI's and such.
Post by Shooshie »
Phil O wrote:Shooshie, be careful. I, like you, installed Waves 5.9 on my Intel Mac and thought all was fine. But as luck would have it, at the worst possible time (I had a client leaning over my shoulder), DP quit. When I tried to re-open the project, no dice. :cry:
Thanks for the warning. I'll always save before messing with Waves.
Phil O
Post by Phil O »
Woah! I do believe a sacrifice to the punctuation gods is in order.
Whew! Close call. :shock:
Phil O
Post by Phil O »
Shooshie wrote:Thanks for the warning. I'll always save before messing with Waves.
No problem, man. Let us know how it goes. I'd be interested to know if you experience the same problems.
mattfort
Post by mattfort »
Hmmm.... I have not had one problem like that UNLESS it involves switching between a netshell and AU.... Then again, maybe switching from MAS to AU will cause this as well...
2.66 Mac Pro, 10.6.5, 16 G RAM, DP 7.22, 6 SATA internal drives (2 RAIDS & 2 singles), Ozone 4, 2 UAD 2 Quad card with most of the plugs, Waves Diamond(V7), V- Series (V6) & SSL4000(V7), PLAY 1.25, EMI TG12413, URS CSPro, Autotune Evo, Scarbee KGB, EWQLSO Platinum Pro XP, Drumagog, BFD2, NI Komplete 7, Breverb, Ivory w/ Italian Grand, USB Plugsound Pro & Synths Anth, Ampeg SVX, Amplitube3 (And Fender), Altiverb, Melodyne, MOTU 24 I/O with Black Lion Mod.
taggart
Post by taggart »
:lol: :lol: :lol:
Taggart
Mac Mini
DP 11
Post by Shooshie »
As everyone probably knows by now from my previous posts, I installed the Waves AU plugins (version 5.9, for Intel Macs) and they are currently working with DP 5.11 on my MacPro Xeon 2.66. I have the Platinum bundle, and about 4 individual plugins on top of that. So far, they've been working just fine. But since Phil told me it will crash DP, I've wanted to get the lowdown on the problem. So, I just got off the phone with Waves tech support. Here are the words from the horse's mouth:
Waves AU version is [translate: "is probably"] compatible with Intel Macs and DP 5.11 in all cases EXCEPT:
1) automation
2) those plugins that use MIDI (vocoder, trigger, side-chains, etc. )
The 1st simply doesn't work, and the 2nd can crash Digital Performer.
The rest, he said, should work without incident. Based on my preferred plugins, the MIDI problem is really not a problem with me as I only occasionally use those kinds of plugins. As for Automation, I can jury-rig at least some of the automation by putting the plugin on an Aux, sending tracks to the Aux, and automating the fader instead of the plugin. That doesn't fix it, I know, but it's at least a small form of automation still available to Waves users until the MAS version comes out, which I expect in the next few months.
About MAS: He said it is in the works, it is a priority (he said this enthusiastically, for those who look for every clue), but he would not commit to a time frame.
Asked about the difficulty of using the waves website to upgrade products and authorize iLoks, he said that the next version of Waves plugins will fix that. He said they're going to make it much easier to authorize. I told him my story, which took me all night to get the damned authorizer to work, and I asked him if he had heard that story before. He said, "of course! That story pays my salary!" But they are going to make it easier to upgrade and authorize via the website.
So, YES, your Platinum Bundle will work with DP 5.11 on the Intel Machines (and on the earlier machines -- G5, G4). Just avoid the plugins that use MIDI, and prepare to go without plugin automation for a while, until MAS is done.
I'm still using it, and still haven't had an incident, but I'm still saving files and backing-up like crazy.
Phil O
Post by Phil O »
Wow! Great work Shoosh. Thanks so much for that info. :D
I may just re-install and try again.
Phil Jeffers
Post by Phil Jeffers »
buzzsmith wrote:Like 666, I'm running a 1.25 ghz dual MDD and am OK with Waves, DP 5.11 and OSX 10.4.8.
Just my 2•!
=buzz=
OK here too, on PPC G5, 5.11 and OS X 10.4.8
There will be new Waves updaters soon for DP (next month).
Phil Jeffers
Sorry, I just realised that I'm repeating myself. I already said this in this post (and probably a couple of posts too). Anyways... they work!
