5.1 Bounce More Capable?
robob
Post by robob »
Hello All,
I am still runing 4.6.1 on my MacBook Pro. In other DAW's one can convert sample depth and rate in one prodedure. In 4.6.1 one must first downsample then sample rate convert or vice versa. This is time consuming and requires one more step. Does 5.1 solve this?
Thanks,
Robert A. Ober
jarok
Post by jarok »
Hi
No it does not solve it.
It is still worth it to upgrade DP to 5.11.
You will get better performance with it on your MacBook Pro.
jarok
robob
Post by robob »
jarok wrote:Hi
jarok
They should work on that, it is most annoying.
I am an IT Consultant who only does a bit of AV work. I usually have 8 channels or less of audio going with no MIDI or synths so the performance is okay for me. When I have a good month I probably will do the update.
I was suprised that my new Ultralite ( I also have the original 896) came with a PPC version of Audiodesk. Motu should take a time out from all the soft synth work and fix some things.
Thanks for the reply,
Robert A. Ober
emulatorloo
Post by emulatorloo »
robob wrote:Motu should take a time out from all the soft synth work and fix some things.
Well, then, let me be the second person to tell you. . .you really should upgrade to 5.11
it FLIES on a macbook pro. I mean really FLIES.
I think you are asking for trouble by running 4.6 under rosetta emulation. Maybe it works today, but it sounds like an accident ready to happen.
Best of luck and best regards.
