ACOUSTIC GUITAR NOISE
Also, honestly, considering that really heavy compression has become the norm for most recordings, is it any surprise that incidental noises are being amplified beyond belief?
I do acknowledge that heavy compression can create really cool sounds, so what I do is apply an EQ to the channel in question: find the annoying frequency, and draw heavy dips at that frequency into the automation.... they are usually very evident in the waveform.
Stephen
PS it also works for vocal sibilance and breaths
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Actually, the only times i have done it are on solo vocal/acoustic geetar, and yes, he was a crap player and a crap engineer. Funny, i just worked with a client who wanted reverb on his electric bass. Needless to say, i did no such thing....
3GHz 8 core, 6GB ram, DP 5.13, OSX.4.11, PTLE 7.4.2, Rosetta 200 digi003, waves platinum, mach five, distressors, ADL 1000, API, Calrec, UA mic pres, neumann, AT, shure, Sennheiser and rode mics...old guitars and drums...nord rack 2, s90, micro korg...yaddda yadda.
http://myspace.com/monkeydenrecording
- Spikey Horse
I have basically two rules with regard to any type of player or instrument 'mechanical' noise.
- When using samples go to great lengths to get these noises IN the mix so it sounds as real and natural as possible.
- If using real instruments airbrush them OUT so it sounds as clinical and flawless as possible.
.....strange old business
well, then it must be a mic problem which brings us back to the original post. could you reply to that? what mic technique do you suggest?
MOTU 2408MK3 (PCI-424) / MOTU 1296 / BLACKLION MICRO CLOCK / PRESONUS M80 / FOCUSRITE OCTOPRE / FOCUSRITE VOICEMASTER PRO/ PRESONUS CENTRAL STATION / UAD-1 (2)/ WAVES Platinum / PSP All PLUGS / IK Multimedia (All of them)/ DIGITAL PERFORMER 7.22 / PEAK Pro 6 / MACHFIVE 1.2.3 / DUAL G5 2.0 w/ 5 gigs Ram - OS 10.5.8 / RODE NT1 / RODE NTK / SHURE 57'S / SHURE 58'S / AKG C1000'S / SENNHEISER 421'S / SEINNHEISER E602 / BLUE BLUEBIRD/ BLUE SNOWBALL / AUDIX D2 (2) / EVENT TR8'S / WHARFDALE DIAMOND 6'S
experimentation will be your best bet. Try different stereo patterns like X/Y at the 12th fret, ORTF, or spaced pair. You may or may not be wondering: "where does the tone of an acoustic guitar come from" Answer: everywhere on the guitar and the room (and the player). For me an important place to have mic'd is the face of the body of the guitar. There is a lot of tonal content there. Sometimes if you record the D.I., you can blend it in lightly to add attack to the sound.
Tip: Listen to the song and it will help you decide what type of sound you should be trying for.
Okay, now we're getting somewhere.
Nine times out of ten, the mic is simply too close to the guitar. One error we have all made is trying to get a lot of level out of a mic'd acoustic, because we "know" that you have to print hot levels in digital. Which is not a hard and fast rule. I recently recorded a live cello over at another studio and most of the time it was just hovering around -9 db on the input meter. But it sounded fine and wasn't a problem in the mix.
When you mic too close, you run the risk that when your guitar player DOES strum harder or pick harder, it will clip. The guitar is really really dynamic, unlike a keyboard or sampled drum sound. So, farther away, with some room sound, is safer.
I've been able to record really up-close and personal acoustic tracks, but the situation was always the same - the guitarist was a fantastic player with a lot of control and experience, and the guitar itself was a very high-end model like a 6 grand Taylor or Martin. And oh yes - the guitar was well intonated. A poorly intonated or poorly set-up guitar never works well for recording.
Another problematic situation is trying to record an acoustic in stereo. Most of the time this just results in a guitar sound that is too big, and you run the risk of phase issues and additional noise from the second microphone. Unless it's a solo guitar and vocal recording, recording in mono is the best way to go. Most Nashville producers record acoustic tracks in mono. The "wide" sound is achieved by doubling the acoustic part, either by copying the track and panning things hard left and right, or by having the player double it physically. From my own experience, I've always been happier with acoustic tracks I recorded in mono.
I have one more suggestion - you may want to check into the Fishman Aura, a processor box for recording acoustic guitar which uses a convolution technology to reproduce what sounds like a mic'd guitar. Believe me, it really does work, I've used it on my band's CD for acoustic guitars. The Aura comes with its own compressor and EQ, and is programmable. More info here:
http://www.fishman.com
- gearboy
Ongoing debate about this. something called "filling the bits" which is, well, incorrect.David Polich wrote:One error we have all made is trying to get a lot of level out of a mic'd acoustic, because we "know" that you have to print hot levels in digital. Which is not a hard and fast rule.
solution:
Record at 24-bit and keep your peaks between -18dB and -12dB in Digital Performer. Your recordings will sound much more open when stacking lots of tracks, and you won't clip your plug-ins.
Also, regarding acoustic guitar, use the room to your advantage. Let the mics and instrument breathe a little.
Jeff
My recording blog: http://www.ipressrecord.com
- Atardecer
regards
James
James O.
www.myspace.com/fixederror
I'll give on that one. Yes, I love a great stereo recording of a beautiful acoustic guitar as much as the next guy. Depends on where you're going with the tune.
Interestingly, I've used PSP's "Pseudostereo" plug-in to "stereoize" mono tracks and it's worked well. Takes some fussing about with the parameters of the plug-in. The plug-in saved my ass on a live jazz album I mixed, the keyboard player's Roland digital piano was recorded in mono, and the PSP plug-in (plus some creative EQ) was just the ticket.
That squeak noise while certainly a PART of the acoustic guitar sound can really contain a lot of energy and has always been reduced as a rule on acoustic guitar recordings. It can actually become even more noticable with a compressor. A de-essor has been used by many an engineer but you will sometimes hit the detail of the preformance that you want. Same is true if you go after it with EQ. Small condensor mics like km184s properly placed can reduce the amount recorded. Most folks go after it like they do breaths in a vocal part:
If you record with out any dynamics and are planning on compressing ITB then I would make a separate track for the breaths/squeaks that is parked at a much lower level without compression. Then it can be diaded in as desired. Many a producer approached vocals that way these days.
Good luck!
Good luck!
Dual 2G-G5/2G ram/Digidesign HD2 Accel/Sony DMX R-100/MeyerHD-1&NS-10s - Hafler Ars Nova/DP5.12/PT7.3.1/2.0+TByte/GigaS3
