mixing down to cd
mixing down to cd
Ok, been at the recording stuff for a while now, but I still have boatloads of trouble taking my mixdowns, exporting them as a stereo wave file to be put on a CD, and being at healthy level of Db without it clipping extensively its either waaaay to quiet or distoring like heavy metal. Ive tried bussing it when recording to boost up Db, it will end up clipping, ive tried every which way of proper gain staging, still clips. Any ideas?
Do I need something like peak pro, or some mastering program? Im lost and haven't gotten as far as intensive mixing and mastering. Anything will help, I have an 896hd with sonar 5 for you sonar users
Dell-based PC
Sonar 5 Producer
896HD
Alesis AI3
Blue Robbie
Trident S20
Rode NTK
BCF2000 ( I know, I know.....)
Sonar 5 Producer
896HD
Alesis AI3
Blue Robbie
Trident S20
Rode NTK
If I understand you correctly, you need to implement some sort of mastering hardware or software, particularly a mastering limiter. Software's the least expensive place to start. Check out iZotope Ozone, IK T-Racks or WaveArts FinalPlug. There are other options, but that will get you started down the path.
Peak Pro is for Mac OSX.
Sonar huh? Interesting.
You do realize this is a Macintosh-oriented MOTU-Digital Performer board, right? Not a lot of Sonar users except maybe in the hardware forum.
so should one convert sample rate in dp or in peak pro if given the option. which would be best?
MOTU 2408MK3 (PCI-424) / MOTU 1296 / BLACKLION MICRO CLOCK / PRESONUS M80 / FOCUSRITE OCTOPRE / FOCUSRITE VOICEMASTER PRO/ PRESONUS CENTRAL STATION / UAD-1 (2)/ WAVES Platinum / PSP All PLUGS / IK Multimedia (All of them)/ DIGITAL PERFORMER 7.22 / PEAK Pro 6 / MACHFIVE 1.2.3 / DUAL G5 2.0 w/ 5 gigs Ram - OS 10.5.8 / RODE NT1 / RODE NTK / SHURE 57'S / SHURE 58'S / AKG C1000'S / SENNHEISER 421'S / SEINNHEISER E602 / BLUE BLUEBIRD/ BLUE SNOWBALL / AUDIX D2 (2) / EVENT TR8'S / WHARFDALE DIAMOND 6'S
msmith92 wrote:so should one convert sample rate in dp or in peak pro if given the option. which would be best?
Flippant Response: Whichever sounds better to you.
MOTU talked a lot about the quality of its sample rate conversion back when it was a big deal in DP. You can easily perform this test with DP and Peak: Convert rate, re-convert to original rate, invert phase of and mix at equal level with the original. Anything you hear is distortion.
I would suggest, however, the best method is to record your CD-destined tracks at 44.1k, 'cause they're gonna' end up at that rate anyway. Braodcast/DVD record at 48k.
normally i do record at 44.1. for some reason this project was started at 48 and we've stuck with it. the mastering house i'm sending it to asked for 48 so i guess it'll work out.
i'll try that test though. good information. thanks.
Pick up a used BBE Sonic Maximizer (external hardware) on eBay for about $75 and route your mix through it (and back into an unused input). Put all 4 of the control knobs on about 6-7 and there you go! I use one on all our rehearsal demo's (when I don't have time to run through the mastering process) and it makes an incredible difference. Really is as advertised and cheaper and easier than any mastering software IMO.
